Thank you very much!
I encountered a new problem when running. It seems that GPU memory isn’t enough because I run it in a big model(called CESM) and the input data is big, too. I can’t understand the error message exactly.
Are there any improper parts in my code?
My CUDA Fortran codes are as follows:
module mix_sub1
use cudafor
contains
attributes(global) subroutine mmul_kernel( ny_block,nx_block,FX,n,CX,SF_SUBM_X,TZ,ieast,ktp,kbt,k,bid,iwest,kp1,nt,km)
integer, value :: ny_block,nx_block,n,ieast,iwest,ktp,kbt,k,bid,kp1,nt,km
real(selected_real_kind(12)),device :: FX(nx_block,ny_block,nt),SF_SUBM_X(nx_block,ny_block,2,ktp,k,bid), &
TZ(nx_block,ny_block,km,nt,bid),CX(nx_block,ny_block)
integer :: i, j, tx, ty, jp1, ip1,ki,kj
tx = threadidx%x
ty = threadidx%y
i = (blockidx%x-1) * blockdim%x + tx
j = (blockidx%y-1) * blockdim%y + ty
do kj = 1, ny_block, 16
do ki = 1, nx_block-1
FX(ki,kj,n) = CX(ki,kj) &
* ( SF_SUBM_X(ki ,kj,ieast,ktp,k,bid) * TZ(ki,kj,k,n,bid) &
+ SF_SUBM_X(ki ,kj,ieast,kbt,k,bid) * TZ(ki,kj,kp1,n,bid) &
+ SF_SUBM_X(ki+1,kj,iwest,ktp,k,bid) * TZ(ki+1,kj,k,n,bid) &
+ SF_SUBM_X(ki+1,kj,iwest,kbt,k,bid) * TZ(ki+1,kj,kp1,n,bid) )
enddo
enddo
call syncthreads()
end subroutine mmul_kernel
subroutine mmul(ny_block,nx_block,FX,n,CX,SF_SUBM_X,TZ,ieast,ktp,kbt,k,bid,iwest,kp1,nt,km)
real(selected_real_kind(12)), dimension(:,:,:,:,:,:) :: SF_SUBM_X
real(selected_real_kind(12)), dimension(:,:,:,:,:) :: TZ
real(selected_real_kind(12)), dimension(:,:,:) :: FX
real(selected_real_kind(12)), dimension(:,:) :: CX
integer :: ny_block,nx_block,n,ieast,iwest,ktp,kbt,k,bid,kp1,nt,km
real(selected_real_kind(12)), device, allocatable, dimension(:,:,:,:,:,:) :: SF_SUBM_Xdev
real(selected_real_kind(12)), device, allocatable, dimension(:,:,:,:,:) :: TZdev
real(selected_real_kind(12)), device, allocatable, dimension(:,:,:) :: FXdev
real(selected_real_kind(12)), device, allocatable, dimension(:,:) :: CXdev
type(dim3) :: dimGrid, dimBlock
integer :: r
real ctimeall, ctimekernel, flops, mflopskernel, mflopsall
integer c1, c2, c3, c4
call system_clock( count=c1 )
allocate( FXdev(nx_block,ny_block,nt),SF_SUBM_Xdev(nx_block,ny_block,2,ktp,k,bid),TZdev(nx_block,ny_block,km,nt,bid),CXdev(nx_block,ny_block))
SF_SUBM_Xdev = SF_SUBM_X(1:nx_block,1:ny_block,1:2,1:ktp,1:k,1:bid)
TZdev = TZ(1:nx_block,1:ny_block,1:km,1:nt,1:bid)
CXdev = CX(1:nx_block,1:ny_block)
dimGrid = dim3( ny_block/16, (nx_block-1)/16, 1 )
dimBlock = dim3( 16, 16, 1 )
call system_clock( count=c2 )
call mmul_kernel<<<dimGrid,dimBlock>>>(ny_block,nx_block,FXdev,n,CXdev,SF_SUBM_Xdev,TZdev,ieast,ktp,kbt,k,bid,iwest,kp1,nt,km)
r = cudathreadsynchronize()
call system_clock( count=c3 )
FX(1:nx_block,1:ny_block,1:nt) = FXdev
call system_clock( count=c4 )
flops = float(ncol) * float(km)
ctimekernel = c3 - c2
mflopskernel = flops / ctimekernel
ctimeall = c4 - c1
mflopsall = flops / ctimeall
print *, 'Kernel time excluding data xfer:', ctimekernel, ' microseconds'
print *, 'Megaflops excluding data xfer: ', mflopskernel
print *, 'Total time including data xfer: ', ctimeall, ' microseconds'
print *, 'Megaflops including data xfer: ', mflopsall
deallocate(FXdev,SF_SUBM_Xdev,TZdev,CXdev)
end subroutine mmul
end module mix_sub1
And here come the error messages
(seq_comm_setcomm) initialize ID ( 1 GLOBAL ) pelist = 0 15 1 ( npes = 16) ( nthreads = 1)
(seq_comm_setcomm) initialize ID ( 2 CPL ) pelist = 0 15 1 ( npes = 16) ( nthreads = 1)
(seq_comm_setcomm) initialize ID ( 17 ATM ) pelist = 0 15 1 ( npes = 16) ( nthreads = 1)
(seq_comm_joincomm) initialize ID ( 18 CPLATM ) join IDs = 2 17 ( npes = 16) ( nthreads = 1)
(seq_comm_jcommarr) initialize ID ( 3 ALLATMID ) join multiple comp IDs ( npes = 16) ( nthreads = 1)
(seq_comm_joincomm) initialize ID ( 10 CPLALLATMID ) join IDs = 2 3 ( npes = 16) ( nthreads = 1)
(seq_comm_setcomm) initialize ID ( 19 LND ) pelist = 0 15 1 ( npes = 16) ( nthreads = 1)
(seq_comm_joincomm) initialize ID ( 20 CPLLND ) join IDs = 2 19 ( npes = 16) ( nthreads = 1)
(seq_comm_jcommarr) initialize ID ( 4 ALLLNDID ) join multiple comp IDs ( npes = 16) ( nthreads = 1)
(seq_comm_joincomm) initialize ID ( 11 CPLALLLNDID ) join IDs = 2 4 ( npes = 16) ( nthreads = 1)
(seq_comm_setcomm) initialize ID ( 21 OCN ) pelist = 0 15 1 ( npes = 16) ( nthreads = 1)
(seq_comm_joincomm) initialize ID ( 22 CPLOCN ) join IDs = 2 21 ( npes = 16) ( nthreads = 1)
(seq_comm_jcommarr) initialize ID ( 5 ALLOCNID ) join multiple comp IDs ( npes = 16) ( nthreads = 1)
(seq_comm_joincomm) initialize ID ( 12 CPLALLOCNID ) join IDs = 2 5 ( npes = 16) ( nthreads = 1)
(seq_comm_setcomm) initialize ID ( 23 ICE ) pelist = 0 15 1 ( npes = 16) ( nthreads = 1)
(seq_comm_joincomm) initialize ID ( 24 CPLICE ) join IDs = 2 23 ( npes = 16) ( nthreads = 1)
(seq_comm_jcommarr) initialize ID ( 6 ALLICEID ) join multiple comp IDs ( npes = 16) ( nthreads = 1)
(seq_comm_joincomm) initialize ID ( 13 CPLALLICEID ) join IDs = 2 6 ( npes = 16) ( nthreads = 1)
(seq_comm_setcomm) initialize ID ( 25 GLC ) pelist = 0 15 1 ( npes = 16) ( nthreads = 1)
(seq_comm_joincomm) initialize ID ( 26 CPLGLC ) join IDs = 2 25 ( npes = 16) ( nthreads = 1)
(seq_comm_jcommarr) initialize ID ( 7 ALLGLCID ) join multiple comp IDs ( npes = 16) ( nthreads = 1)
(seq_comm_joincomm) initialize ID ( 14 CPLALLGLCID ) join IDs = 2 7 ( npes = 16) ( nthreads = 1)
(seq_comm_setcomm) initialize ID ( 27 ROF ) pelist = 0 15 1 ( npes = 16) ( nthreads = 1)
(seq_comm_joincomm) initialize ID ( 28 CPLROF ) join IDs = 2 27 ( npes = 16) ( nthreads = 1)
(seq_comm_jcommarr) initialize ID ( 8 ALLROFID ) join multiple comp IDs ( npes = 16) ( nthreads = 1)
(seq_comm_joincomm) initialize ID ( 15 CPLALLROFID ) join IDs = 2 8 ( npes = 16) ( nthreads = 1)
(seq_comm_setcomm) initialize ID ( 29 WAV ) pelist = 0 15 1 ( npes = 16) ( nthreads = 1)
(seq_comm_joincomm) initialize ID ( 30 CPLWAV ) join IDs = 2 29 ( npes = 16) ( nthreads = 1)
(seq_comm_jcommarr) initialize ID ( 9 ALLWAVID ) join multiple comp IDs ( npes = 16) ( nthreads = 1)
(seq_comm_joincomm) initialize ID ( 16 CPLALLWAVID ) join IDs = 2 9 ( npes = 16) ( nthreads = 1)
(seq_comm_printcomms) 1 0 16 1 GLOBAL:
(seq_comm_printcomms) 2 0 16 1 CPL:
(seq_comm_printcomms) 3 0 16 1 ALLATMID:
(seq_comm_printcomms) 4 0 16 1 ALLLNDID:
(seq_comm_printcomms) 5 0 16 1 ALLOCNID:
(seq_comm_printcomms) 6 0 16 1 ALLICEID:
(seq_comm_printcomms) 7 0 16 1 ALLGLCID:
(seq_comm_printcomms) 8 0 16 1 ALLROFID:
(seq_comm_printcomms) 9 0 16 1 ALLWAVID:
(seq_comm_printcomms) 10 0 16 1 CPLALLATMID:
(seq_comm_printcomms) 11 0 16 1 CPLALLLNDID:
(seq_comm_printcomms) 12 0 16 1 CPLALLOCNID:
(seq_comm_printcomms) 13 0 16 1 CPLALLICEID:
(seq_comm_printcomms) 14 0 16 1 CPLALLGLCID:
(seq_comm_printcomms) 15 0 16 1 CPLALLROFID:
(seq_comm_printcomms) 16 0 16 1 CPLALLWAVID:
(seq_comm_printcomms) 17 0 16 1 ATM:
(seq_comm_printcomms) 18 0 16 1 CPLATM:
(seq_comm_printcomms) 19 0 16 1 LND:
(seq_comm_printcomms) 20 0 16 1 CPLLND:
(seq_comm_printcomms) 21 0 16 1 OCN:
(seq_comm_printcomms) 22 0 16 1 CPLOCN:
(seq_comm_printcomms) 23 0 16 1 ICE:
(seq_comm_printcomms) 24 0 16 1 CPLICE:
(seq_comm_printcomms) 25 0 16 1 GLC:
(seq_comm_printcomms) 26 0 16 1 CPLGLC:
(seq_comm_printcomms) 27 0 16 1 ROF:
(seq_comm_printcomms) 28 0 16 1 CPLROF:
(seq_comm_printcomms) 29 0 16 1 WAV:
(seq_comm_printcomms) 30 0 16 1 CPLWAV:
(t_initf) Read in prof_inparm namelist from: drv_in
8 MB memory alloc in MB is 8.00seq_flds_mod: read seq_cplflds_inparm namelist from: drv_in
8 MB memory dealloc in MB is 0.00
Memory block size conversion in bytes is 1020.02
seq_flds_mod: read seq_cplflds_userspec namelist from: drv_in
8 MB memory alloc in MB is 8.008 MB memory dealloc in MB is 0.00
Memory block size conversion in bytes is 1020.51
Memory block size conversion in bytes is 1019.52
Memory block size conversion in bytes is 1018.53
8 MB memory alloc in MB is 8.008 MB memory alloc in MB is 8.00
Memory block size conversion in bytes is 1051.20
Memory block size conversion in bytes is 1018.03
Memory block size conversion in bytes is 1019.02
Memory block size conversion in bytes is 1017.54
Memory block size conversion in bytes is 1049.63
seq_flds_mod: seq_flds_a2x_states=
Sa_z:Sa_u:Sa_v:Sa_tbot:Sa_ptem:Sa_shum:Sa_pbot:Sa_dens:Sa_pslv
seq_flds_mod: seq_flds_a2x_fluxes=
Faxa_rainc:Faxa_rainl:Faxa_snowc:Faxa_snowl:Faxa_lwdn:Faxa_swndr:
Faxa_swvdr:Faxa_swndf:Faxa_swvdf:Faxa_swnet:Faxa_bcphidry:
Faxa_bcphodry:Faxa_bcphiwet:Faxa_ocphidry:Faxa_ocphodry:
Faxa_ocphiwet:Faxa_dstwet1:Faxa_dstwet2:Faxa_dstwet3:
Faxa_dstwet4:Faxa_dstdry1:Faxa_dstdry2:Faxa_dstdry3:Faxa_dstdry4
seq_flds_mod: seq_flds_x2a_states=
Sf_lfrac:Sf_ifrac:Sf_ofrac:Sx_avsdr:Sx_anidr:Sx_avsdf:Sx_anidf:Sx_tref:Sx_qref:So_t:Sx_t:Sl_fv:Sl_ram1:Sl_snowh:Si_snowh:So_ssq:So_re:Sx_u10:So_ustar
seq_flds_mod: seq_flds_x2a_fluxes=
Faxx_taux:Faxx_tauy:Faxx_lat:Faxx_sen:Faxx_lwup:Faxx_evap:Fall_flxdst1:Fall_flxdst2:Fall_flxdst3:Fall_flxdst4
seq_flds_mod: seq_flds_l2x_states=
Sl_avsdr:Sl_anidr:Sl_avsdf:Sl_anidf:Sl_tref:Sl_qref:Sl_t:Sl_fv:Sl_ram1:Sl_snowh:Sl_u10
seq_flds_mod: seq_flds_l2x_fluxes=
Fall_swnet:Fall_taux:Fall_tauy:Fall_lat:Fall_sen:Fall_lwup:Fall_evap:Fall_flxdst1:Fall_flxdst2:Fall_flxdst3:Fall_flxdst4:Flrl_rofliq:Flrl_rofice
seq_flds_mod: seq_flds_x2l_states=
Sa_z:Sa_u:Sa_v:Sa_tbot:Sa_ptem:Sa_shum:Sa_pbot:Slrr_volr
seq_flds_mod: seq_flds_x2l_fluxes=
Faxa_swvdr:Faxa_swndf:Faxa_swvdf:Faxa_bcphidry:Faxa_bcphodry:
Faxa_bcphiwet:Faxa_ocphidry:Faxa_ocphodry:Faxa_ocphiwet:
Faxa_dstwet1:Faxa_dstwet2:Faxa_dstwet3:Faxa_dstwet4:Faxa_dstdry1:
Faxa_dstdry2:Faxa_dstdry3:Faxa_dstdry4:Flrr_flood
seq_flds_mod: seq_flds_i2x_states=
Si_avsdr:Si_anidr:Si_avsdf:Si_anidf:Si_tref:Si_qref:Si_t:Si_snowh:Si_u10:Si_ifrac
seq_flds_mod: seq_flds_i2x_fluxes=
Faii_swnet:Fioi_swpen:Faii_taux:Fioi_taux:Faii_tauy:Fioi_tauy:Faii_lat:Faii_sen:Faii_lwup:Faii_evap:Fioi_melth:Fioi_meltw:Fioi_salt
seq_flds_mod: seq_flds_x2i_states=
Sa_z:Sa_u:Sa_v:Sa_tbot:Sa_ptem:Sa_shum:Sa_pbot:Sa_dens:So_t:So_s:So_u:So_v:So_dhdx:So_dhdy
seq_flds_mod: seq_flds_x2i_fluxes=
Faxa_rain:Faxa_snow:Faxa_lwdn:Faxa_swndr:Faxa_swvdr:Faxa_swndf:
Faxa_swvdf:Faxa_bcphidry:Faxa_bcphodry:Faxa_bcphiwet:Faxa_ocphidry:
Faxa_ocphodry:Faxa_ocphiwet:Faxa_dstwet1:Faxa_dstwet2:Faxa_dstwet3:
Faxa_dstwet4:Faxa_dstdry1:Faxa_dstdry2:Faxa_dstdry3:Faxa_dstdry4:Fioo_q
seq_flds_mod: seq_flds_o2x_states=
So_t:So_s:So_u:So_v:So_dhdx:So_dhdy:So_bldepth
seq_flds_mod: seq_flds_o2x_fluxes=
Fioo_q
seq_flds_mod: seq_flds_x2o_states=
Sa_pslv:So_duu10n:Si_ifrac:Sw_lamult:Sw_ustokes:Sw_vstokes:Sw_hstokes
seq_flds_mod: seq_flds_x2o_fluxes=
Faxa_rain:Faxa_snow:Faxa_prec:Faxa_lwdn:Foxx_swnet:Faxa_bcphidry:
Faxa_bcphodry:Faxa_bcphiwet:Faxa_ocphidry:Faxa_ocphodry:Faxa_ocphiwet:
Faxa_dstdry2:Faxa_dstdry3:Faxa_dstdry4:Foxx_taux:Foxx_tauy:Foxx_lat:
Foxx_sen:Foxx_lwup:Foxx_evap:Fioi_melth:Fioi_meltw:Fioi_salt:Forr_roff:Forr_ioff
seq_flds_mod: seq_flds_s2x_states=
seq_flds_mod: seq_flds_s2x_fluxes=
seq_flds_mod: seq_flds_x2s_states=
seq_flds_mod: seq_flds_x2s_fluxes=
seq_flds_mod: seq_flds_g2x_states=
seq_flds_mod: seq_flds_g2x_fluxes=
seq_flds_mod: seq_flds_x2g_states=
seq_flds_mod: seq_flds_x2g_fluxes=
seq_flds_mod: seq_flds_xao_states=
So_tref:So_qref:So_ssq:So_re:So_u10:So_duu10n:So_ustar
seq_flds_mod: seq_flds_xao_albedo=
So_avsdr:So_anidr:So_avsdf:So_anidf
seq_flds_mod: seq_flds_r2x_states=
Slrr_volr
seq_flds_mod: seq_flds_r2x_fluxes=
Forr_roff:Forr_ioff:Flrr_flood
seq_flds_mod: seq_flds_x2r_states=
seq_flds_mod: seq_flds_x2r_fluxes=
seq_flds_mod: seq_flds_w2x_states=
seq_flds_mod: seq_flds_w2x_fluxes=
seq_flds_mod: seq_flds_x2w_states=
Sa_u:Sa_v:Sa_tbot:Si_ifrac:So_t:So_u:So_v:So_bldepth
seq_flds_mod: seq_flds_x2w_fluxes=
init_overflows_kmt: KMT = 34 at global (i,j) = 60 4 changed to 33 init_overflows_kmt: KMT = 36 at global (i,j) = 98 4 changed to 35
init_overflows_kmt: KMT = 36 at global (i,j) = 99 4 changed to 35
init_overflows_kmt: KMT = 36 at global (i,j) = 100 4 changed to 35
init_overflows_kmt: KMT = 34 at global (i,j) = 61 4 changed to 33
init_overflows_kmt: KMT = 34 at global (i,j) = 62 4 changed to 33
init_overflows_kmt: KMT = 38 at global (i,j) = 12 93 changed to 37
init_overflows_kmt: KMT = 38 at global (i,j) = 12 94 changed to 37
init_overflows_kmt: KMT = 38 at global (i,j) = 12 95 changed to 37
init_overflows_kmt: KMT = 33 at global (i,j) = 7 109 changed to 32
init_overflows_kmt: KMT = 33 at global (i,j) = 7 110 changed to 32
init_overflows_kmt: KMT = 33 at global (i,j) = 7 111 changed to 32
Overflow: Ross Sea Source region mask at global (ij)= 59 2 Overflow: Weddell Sea Source region mask at global (ij)= 98 2
Overflow: Weddell Sea Source region mask at global (ij)= 99 2
Overflow: Weddell Sea Source region mask at global (ij)=100 2
Overflow: Weddell Sea Source region mask at global (ij)= 98 3
Overflow: Weddell Sea Source region mask at global (ij)= 99 3
Overflow: Weddell Sea Source region mask at global (ij)=100 3
Overflow: Weddell Sea Source adjacent mask at global (ij)= 98 3
Overflow: Weddell Sea Source adjacent mask at global (ij)= 99 3
Overflow: Weddell Sea Source adjacent mask at global (ij)=100 3
Overflow: Weddell Sea Inflow region mask at global (ij)= 98 5
Overflow: Weddell Sea Inflow region mask at global (ij)= 99 5
Overflow: Weddell Sea Inflow region mask at global (ij)=100 5
Overflow: Weddell Sea Inflow region mask at global (ij)= 98 6
Overflow: Weddell Sea Inflow region mask at global (ij)= 99 6
Overflow: Weddell Sea Inflow region mask at global (ij)=100 6
Overflow: Weddell Sea Entrainment region mask at global (ij)= 96 6
Overflow: Weddell Sea Entrainment region mask at global (ij)= 97 6
Overflow: Weddell Sea Entrainment region mask at global (ij)= 98 6
Overflow: Weddell Sea Entrainment adjacent mask at global (ij)= 96 6
Overflow: Weddell Sea Entrainment adjacent mask at global (ij)= 97 6
Overflow: Weddell Sea Entrainment adjacent mask at global (ij)= 98 6
Overflow: Weddell Sea Inflow region mask at global (ij)= 98 7
Overflow: Weddell Sea Inflow region mask at global (ij)= 99 7
Overflow: Weddell Sea Inflow region mask at global (ij)=100 7
Overflow: Weddell Sea Entrainment region mask at global (ij)= 96 7
Overflow: Weddell Sea Entrainment region mask at global (ij)= 97 7
Overflow: Weddell Sea Entrainment region mask at global (ij)= 98 7
Overflow: Weddell Sea Entrainment region mask at global (ij)= 96 8
Overflow: Weddell Sea Entrainment region mask at global (ij)= 97 8
Overflow: Weddell Sea Entrainment region mask at global (ij)= 98 8
Overflow: Weddell Sea Product adjacent mask at global (ij)= 96 7
Overflow: Weddell Sea Product adjacent mask at global (ij)= 97 7
Overflow: Weddell Sea Product adjacent mask at global (ij)= 98 7
Overflow: Weddell Sea Product adjacent mask at global (ij)= 96 8
Overflow: Weddell Sea Product adjacent mask at global (ij)= 97 8
Overflow: Weddell Sea Product adjacent mask at global (ij)= 98 8
Overflow: Weddell Sea Product adjacent mask at global (ij)= 96 9
Overflow: Weddell Sea Product adjacent mask at global (ij)= 97 9
Overflow: Weddell Sea Product adjacent mask at global (ij)= 98 9
Overflow: Weddell Sea Product adjacent mask at global (ij)= 98 10
Overflow: Weddell Sea Product adjacent mask at global (ij)= 98 11
Overflow: Ross Sea Source region mask at global (ij)= 60 2
Overflow: Ross Sea Source region mask at global (ij)= 61 2
Overflow: Ross Sea Source region mask at global (ij)= 62 2
Overflow: Ross Sea Source region mask at global (ij)= 59 3
Overflow: Ross Sea Source region mask at global (ij)= 60 3
Overflow: Ross Sea Source region mask at global (ij)= 61 3
Overflow: Ross Sea Source region mask at global (ij)= 62 3
Overflow: Ross Sea Source adjacent mask at global (ij)= 60 3
Overflow: Ross Sea Source adjacent mask at global (ij)= 61 3
Overflow: Ross Sea Source adjacent mask at global (ij)= 62 3
Overflow: Ross Sea Inflow region mask at global (ij)= 60 5
Overflow: Ross Sea Inflow region mask at global (ij)= 61 5
Overflow: Ross Sea Inflow region mask at global (ij)= 62 5
Overflow: Ross Sea Inflow region mask at global (ij)= 60 6
Overflow: Ross Sea Inflow region mask at global (ij)= 61 6
Overflow: Ross Sea Inflow region mask at global (ij)= 62 6
Overflow: Ross Sea Entrainment region mask at global (ij)= 59 6
Overflow: Ross Sea Entrainment region mask at global (ij)= 60 6
Overflow: Ross Sea Entrainment region mask at global (ij)= 61 6
Overflow: Ross Sea Entrainment adjacent mask at global (ij)= 59 6
Overflow: Ross Sea Entrainment adjacent mask at global (ij)= 60 6
Overflow: Ross Sea Entrainment adjacent mask at global (ij)= 61 6
Overflow: Ross Sea Inflow region mask at global (ij)= 60 7
Overflow: Ross Sea Inflow region mask at global (ij)= 61 7
Overflow: Ross Sea Inflow region mask at global (ij)= 62 7
Overflow: Ross Sea Entrainment region mask at global (ij)= 59 7
Overflow: Ross Sea Entrainment region mask at global (ij)= 60 7
Overflow: Ross Sea Entrainment region mask at global (ij)= 61 7
Overflow: Ross Sea Entrainment region mask at global (ij)= 59 8
Overflow: Ross Sea Entrainment region mask at global (ij)= 60 8
Overflow: Ross Sea Entrainment region mask at global (ij)= 61 8
Overflow: Ross Sea Product adjacent mask at global (ij)= 59 7
Overflow: Ross Sea Product adjacent mask at global (ij)= 60 7
Overflow: Ross Sea Product adjacent mask at global (ij)= 61 7
Overflow: Ross Sea Product adjacent mask at global (ij)= 59 8
Overflow: Ross Sea Product adjacent mask at global (ij)= 60 8
Overflow: Ross Sea Product adjacent mask at global (ij)= 61 8
Overflow: Ross Sea Product adjacent mask at global (ij)= 59 9
Overflow: Ross Sea Product adjacent mask at global (ij)= 60 9
Overflow: Ross Sea Product adjacent mask at global (ij)= 61 9
Overflow: Ross Sea Product adjacent mask at global (ij)= 59 10
Overflow: Ross Sea Product adjacent mask at global (ij)= 60 10
Overflow: Ross Sea Product adjacent mask at global (ij)= 61 10
Overflow: Denmark Strait Inflow region mask at global (ij)= 3 104
Overflow: Denmark Strait Inflow region mask at global (ij)= 4 104
Overflow: Denmark Strait Inflow region mask at global (ij)= 5 104
Overflow: Denmark Strait Entrainment region mask at global (ij)= 3 104
Overflow: Denmark Strait Entrainment region mask at global (ij)= 4 104
Overflow: Denmark Strait Entrainment region mask at global (ij)= 5 104
Overflow: Denmark Strait Inflow region mask at global (ij)= 3 105
Overflow: Denmark Strait Inflow region mask at global (ij)= 4 105
Overflow: Denmark Strait Inflow region mask at global (ij)= 5 105
Overflow: Denmark Strait Entrainment region mask at global (ij)= 3 105
Overflow: Denmark Strait Entrainment region mask at global (ij)= 4 105
Overflow: Denmark Strait Entrainment region mask at global (ij)= 5 105
Overflow: Denmark Strait Entrainment adjacent mask at global (ij)= 5 105
Overflow: Denmark Strait Inflow region mask at global (ij)= 3 106
Overflow: Denmark Strait Inflow region mask at global (ij)= 4 106
Overflow: Denmark Strait Inflow region mask at global (ij)= 5 106
Overflow: Denmark Strait Entrainment region mask at global (ij)= 3 106
Overflow: Denmark Strait Entrainment region mask at global (ij)= 4 106
Overflow: Denmark Strait Entrainment region mask at global (ij)= 5 106
Overflow: Denmark Strait Entrainment adjacent mask at global (ij)= 5 106
Overflow: Denmark Strait Inflow region mask at global (ij)= 3 107
Overflow: Denmark Strait Inflow region mask at global (ij)= 4 107
Overflow: Denmark Strait Inflow region mask at global (ij)= 5 107
Overflow: Denmark Strait Entrainment region mask at global (ij)= 3 107
Overflow: Denmark Strait Entrainment region mask at global (ij)= 4 107
Overflow: Denmark Strait Entrainment region mask at global (ij)= 5 107
Overflow: Denmark Strait Entrainment adjacent mask at global (ij)= 5 107
Overflow: Denmark Strait Source region mask at global (ij)= 8 109
Overflow: Denmark Strait Source region mask at global (ij)= 9 109
Overflow: Denmark Strait Source region mask at global (ij)= 10 109
Overflow: Denmark Strait Source adjacent mask at global (ij)= 8 109
Overflow: Denmark Strait Source region mask at global (ij)= 8 110
Overflow: Denmark Strait Source region mask at global (ij)= 9 110
Overflow: Denmark Strait Source region mask at global (ij)= 10 110
Overflow: Denmark Strait Source adjacent mask at global (ij)= 8 110
Overflow: Denmark Strait Source region mask at global (ij)= 8 111
Overflow: Denmark Strait Source region mask at global (ij)= 9 111
Overflow: Denmark Strait Source region mask at global (ij)= 10 111
Overflow: Denmark Strait Source adjacent mask at global (ij)= 8 111
Overflow: Denmark Strait Source region mask at global (ij)= 8 112
Overflow: Denmark Strait Source region mask at global (ij)= 9 112
Overflow: Denmark Strait Source region mask at global (ij)= 10 112
Overflow: Denmark Strait Source adjacent mask at global (ij)= 8 112
Overflow: Denmark Strait Product adjacent mask at global (ij)= 4 102
Overflow: Denmark Strait Product adjacent mask at global (ij)= 4 103
Overflow: Denmark Strait Product adjacent mask at global (ij)= 4 104
Overflow: Denmark Strait Product adjacent mask at global (ij)= 3 102
Overflow: Denmark Strait Product adjacent mask at global (ij)= 3 103
Overflow: Denmark Strait Product adjacent mask at global (ij)= 3 104
Overflow: Denmark Strait Product adjacent mask at global (ij)= 2 100
Overflow: Denmark Strait Product adjacent mask at global (ij)= 2 101
Overflow: Denmark Strait Product adjacent mask at global (ij)= 2 102
Overflow: Denmark Strait Product adjacent mask at global (ij)= 1 95
Overflow: Denmark Strait Product adjacent mask at global (ij)= 1 96
Overflow: Denmark Strait Product adjacent mask at global (ij)= 1 97
Overflow: Faroe Bank Channel Inflow region mask at global (ij)= 7 93
Overflow: Faroe Bank Channel Inflow region mask at global (ij)= 8 93
Overflow: Faroe Bank Channel Inflow region mask at global (ij)= 9 93
Overflow: Faroe Bank Channel Inflow region mask at global (ij)= 10 93
Overflow: Faroe Bank Channel Source region mask at global (ij)= 13 93
Overflow: Faroe Bank Channel Source region mask at global (ij)= 14 93
Overflow: Faroe Bank Channel Source region mask at global (ij)= 15 93
Overflow: Faroe Bank Channel Source adjacent mask at global (ij)= 13 93
Overflow: Faroe Bank Channel Entrainment region mask at global (ij)= 7 93
Overflow: Faroe Bank Channel Entrainment region mask at global (ij)= 8 93
Overflow: Faroe Bank Channel Entrainment region mask at global (ij)= 9 93
Overflow: Faroe Bank Channel Entrainment region mask at global (ij)= 10 93
Overflow: Faroe Bank Channel Entrainment adjacent mask at global (ij)= 10 93
Overflow: Faroe Bank Channel Inflow region mask at global (ij)= 7 94
Overflow: Faroe Bank Channel Inflow region mask at global (ij)= 8 94
Overflow: Faroe Bank Channel Inflow region mask at global (ij)= 9 94
Overflow: Faroe Bank Channel Inflow region mask at global (ij)= 10 94
Overflow: Faroe Bank Channel Source region mask at global (ij)= 13 94
Overflow: Faroe Bank Channel Source region mask at global (ij)= 14 94
Overflow: Faroe Bank Channel Source region mask at global (ij)= 15 94
Overflow: Faroe Bank Channel Source adjacent mask at global (ij)= 13 94
Overflow: Faroe Bank Channel Entrainment region mask at global (ij)= 7 94
Overflow: Faroe Bank Channel Entrainment region mask at global (ij)= 8 94
Overflow: Faroe Bank Channel Entrainment region mask at global (ij)= 9 94
Overflow: Faroe Bank Channel Entrainment region mask at global (ij)= 10 94
Overflow: Faroe Bank Channel Entrainment adjacent mask at global (ij)= 10 94
Overflow: Faroe Bank Channel Inflow region mask at global (ij)= 7 95
Overflow: Faroe Bank Channel Inflow region mask at global (ij)= 8 95
Overflow: Faroe Bank Channel Inflow region mask at global (ij)= 9 95
Overflow: Faroe Bank Channel Inflow region mask at global (ij)= 10 95
Overflow: Faroe Bank Channel Source region mask at global (ij)= 13 95
Overflow: Faroe Bank Channel Source region mask at global (ij)= 14 95
Overflow: Faroe Bank Channel Source region mask at global (ij)= 15 95
Overflow: Faroe Bank Channel Source adjacent mask at global (ij)= 13 95
Overflow: Faroe Bank Channel Entrainment region mask at global (ij)= 7 95
Overflow: Faroe Bank Channel Entrainment region mask at global (ij)= 8 95
Overflow: Faroe Bank Channel Entrainment region mask at global (ij)= 9 95
Overflow: Faroe Bank Channel Entrainment region mask at global (ij)= 10 95
Overflow: Faroe Bank Channel Entrainment adjacent mask at global (ij)= 10 95
Overflow: Faroe Bank Channel Source region mask at global (ij)= 13 96
Overflow: Faroe Bank Channel Source region mask at global (ij)= 14 96
Overflow: Faroe Bank Channel Source region mask at global (ij)= 15 96
Overflow: Faroe Bank Channel Entrainment region mask at global (ij)= 7 96
Overflow: Faroe Bank Channel Entrainment region mask at global (ij)= 8 96
Overflow: Faroe Bank Channel Entrainment region mask at global (ij)= 9 96
Overflow: Faroe Bank Channel Entrainment region mask at global (ij)= 10 96
Overflow: Faroe Bank Channel Source region mask at global (ij)= 13 97
Overflow: Faroe Bank Channel Source region mask at global (ij)= 14 97
Overflow: Faroe Bank Channel Source region mask at global (ij)= 15 97
Overflow: Faroe Bank Channel Product adjacent mask at global (ij)= 9 93
Overflow: Faroe Bank Channel Product adjacent mask at global (ij)= 9 94
Overflow: Faroe Bank Channel Product adjacent mask at global (ij)= 9 95
Overflow: Faroe Bank Channel Product adjacent mask at global (ij)= 8 93
Overflow: Faroe Bank Channel Product adjacent mask at global (ij)= 8 94
Overflow: Faroe Bank Channel Product adjacent mask at global (ij)= 8 95
Overflow: Faroe Bank Channel Product adjacent mask at global (ij)= 7 93
Overflow: Faroe Bank Channel Product adjacent mask at global (ij)= 7 94
Overflow: Faroe Bank Channel Product adjacent mask at global (ij)= 7 95
Overflow: Faroe Bank Channel Product adjacent mask at global (ij)= 5 90
Overflow: Faroe Bank Channel Product adjacent mask at global (ij)= 5 91
Overflow: Faroe Bank Channel Product adjacent mask at global (ij)= 5 92
Overflow: Faroe Bank Channel Product adjacent mask at global (ij)= 3 89
Overflow: Faroe Bank Channel Product adjacent mask at global (ij)= 4 89
Overflow: Faroe Bank Channel Product adjacent mask at global (ij)= 5 89
0: ALLOCATE: 22968 bytes requested; status = 35(CUDA driver version is insufficient for CUDA runtime version)
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= PID 21503 RUNNING AT localhost.localdomain
= EXIT CODE: 127
= CLEANING UP REMAINING PROCESSES
= YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
