Can Jetson Orin Nano I2C change frequence dynamicly?
Hi,there will be connect different device on Jetson Orin Nano I2C. If there communicate frequence is different, can I2C frequence dynamic change to meet different? (device will be disable while I2C is not on work frequence.)
For exsample, sensor A is 400kHz, Sensor B is 1000kHz. A and B is connected to I2C port 0. Can Jetson Orin Nano communicate A in 400kHz (B is disable) and then communicate B in 1000kHz (A is disable)?
Sorry current don’t support this kind of case. However suppose you can try to modify the kernel driver for it. But your slave device driver need HW support to disable by regulator.
