I’m using Jetson TX2 to run AI models for object detection and other user cases. I want to send the metadata (using postman) that generated from the AI model to another cloud based environment. But I always see the error “unexpected token:u”. I tried to send the same request from Windows system and Ubuntu 16.04, all worked fine. I believe this issue sits in TX2. Can you help to suggest any options?
Many thanks!
