Can jetson xavier run ReID?
Hi guys:
I want to access two video streams on xavier to re-identify pedestrian targets. Is there any example of ReID successfully deployed on xavier?
You can try DeepStream SDK. The reference deepstream-app is run with resnet10. You can try the default sample first, and replace with your model.
Multiple-source case is supported also.
