Hi there,
I am using the Jetson TX2 to receive CAN messages with the WaveShare SN65HVD230 as a transceiver.
I am getting messages from another CAN node (which is proven to work properly, we tested that) every 50ms (a system timestamp). These messages obviously should be received in the correct order so that I can work with them. Even though they are sent correctly (validated with another computer & tool) they are being received in the wrong order, meaning that lower numbered timestamps will be received and displayed after higher numbered timestamps.
I am using
candump can0
in order to receive the messages. Since I am quiet new to CAN, is there anything that you know would create such an issue ? Maybe a wrong baud rate ? Or similar things ? I hope this isn’t really bad. If you have any further questions, feel free to ask. Thanks.
