Hi forum,
I am now using custom carrier board. I planned to boot from sdcard, which already have a system. I changed extlinux.conf: APPEND ${cbootargs} quiet root=/dev/mmcblk1p1. The rest of file remained the same. But it did not work
I checked. The sdcard is /dev/mmcblk1p1. And lsblk shows there is a system on it. But still it kept boot from emmc, which is /dev/mmcblk0p1
This is the console output
[10:48:01:311] [0000.206] [L4T TegraBoot] (version 00.00.2018.01-l4t-e82258de)
[10:48:01:317] [0000.211] Processing in cold boot mode Bootloader 2
[10:48:01:327] [0000.216] A02 Bootrom Patch rev = 1023
[10:48:01:327] [0000.219] Power-up reason: software reset
[10:48:01:336] [0000.223] No Battery Present
[10:48:01:336] [0000.226] pmic max77620 reset reason
[10:48:01:336] [0000.229] pmic max77620 NVERC : 0x0
[10:48:01:349] [0000.232] RamCode = 0
[10:48:01:349] [0000.235] Platform has DDR4 type RAM
[10:48:01:349] [0000.238] max77620 disabling SD1 Remote Sense
[10:48:01:349] [0000.242] Setting DDR voltage to 1125mv
[10:48:01:362] [0000.246] Serial Number of Pmic Max77663: 0x308a5
[10:48:01:362] [0000.254] Entering ramdump check
[10:48:01:372] [0000.257] Get RamDumpCarveOut = 0x0
[10:48:01:372] [0000.260] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[10:48:01:372] [0000.265] Last reboot was clean, booting normally!
[10:48:01:384] [0000.270] Sdram initialization is successful
[10:48:01:384] [0000.274] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[10:48:01:395] [0000.280] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[10:48:01:395] [0000.286] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[10:48:01:405] [0000.292] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[10:48:01:414] [0000.297] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[10:48:01:414] [0000.303] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[10:48:01:424] [0000.309] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[10:48:01:424] [0000.315] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[10:48:01:443] [0000.331] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[10:48:01:456] [0000.337] Platform-DebugCarveout: 0
[10:48:01:456] [0000.340] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[10:48:01:456] [0000.346] Non secure mode, and RB not enabled.
[10:48:01:477] [0000.363] Csd NumOfBlocks=0
[10:48:01:672] [0000.558] *** Booting BFS0.
[10:48:01:682] [0000.561] Read PT from (0:3)
[10:48:01:682] [0000.567] Using BFS PT to query partitions
[10:48:01:691] [0000.571] PT: Partition LNX NOT found !
[10:48:02:300] [0001.171] *** Booting KFS0.
[10:48:02:311] [0001.174] BoardID = 3448, SKU = 0x2
[10:48:02:311] [0001.177] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[10:48:02:320] [0001.183] Read GPT from (0:3)
[10:48:02:320] [0001.190] Using GPT Primary to query partitions
[10:48:02:330] [0001.195] Loading Tboot-CPU binary
[10:48:02:338] [0001.202] Verifying TBC in OdmNonSecureSBK mode
[10:48:02:347] [0001.212] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[10:48:02:349] [0001.219] Bootloader downloaded successfully.
[10:48:02:359] [0001.223] Downloaded Tboot-CPU binary to 0xa0000258
[10:48:02:359] [0001.228] MAX77620_GPIO5 configured
[10:48:02:368] [0001.232] CPU power rail is up
[10:48:02:368] [0001.235] CPU clock enabled
[10:48:02:378] [0001.238] Performing RAM repair
[10:48:02:378] [0001.241] Updating A64 Warmreset Address to 0xa00002e9
[10:48:02:378] [0001.246] BoardID = 3448, SKU = 0x2
[10:48:02:388] [0001.250] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[10:48:02:388] [0001.256] Loading NvTbootBootloaderDTB
[10:48:02:406] [0001.273] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[10:48:02:479] [0001.346] Bootloader DTB Load Address: 0x83000000
[10:48:02:492] [0001.351] BoardID = 3448, SKU = 0x2
[10:48:02:492] [0001.354] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[10:48:02:502] [0001.360] Loading NvTbootKernelDTB
[10:48:02:510] [0001.376] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[10:48:02:585] [0001.449] Kernel DTB Load Address: 0x83100000
[10:48:02:589] [0001.453] BoardID = 3448, SKU = 0x2
[10:48:02:598] [0001.457] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[10:48:02:606] [0001.464] Loading cboot binary
[10:48:02:614] [0001.475] Verifying EBT in OdmNonSecureSBK mode
[10:48:02:654] [0001.516] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[10:48:02:661] [0001.523] Bootloader downloaded successfully.
[10:48:02:669] [0001.528] BoardID = 3448, SKU = 0x2
[10:48:02:669] [0001.531] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[10:48:02:678] [0001.537] PT: Partition NCT NOT found !
[10:48:02:684] [0001.541] Warning: Find Partition via PT Failed
[10:48:02:684] [0001.545] Next binary entry address: 0x92c00258
[10:48:02:693] [0001.550] BoardId: 3448
[10:48:02:693] [0001.554] Overriding pmu board id with proc board id
[10:48:02:701] [0001.559] Display board id is not available
[10:48:02:709] [0001.563] BoardID = 3448, SKU = 0x2
[10:48:02:709] [0001.567] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[10:48:02:723] [0001.580] Verifying SC7EntryFw in OdmNonSecureSBK mode
[10:48:02:776] [0001.637] /bpmp deleted
[10:48:02:786] [0001.639] SC7EntryFw header found loaded at 0xff700000
[10:48:02:979] [0001.834] OVR2 PMIC
[10:48:02:989] [0001.836] Bpmp FW successfully loaded
[10:48:02:989] [0001.840] BoardID = 3448, SKU = 0x2
[10:48:02:997] [0001.843] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[10:48:02:997] [0001.850] WB0 init successfully at 0xff780000
[10:48:03:006] [0001.854] Set NvDecSticky Bits
[10:48:03:006] [0001.858] GSC2 address ff53fffc value c0edbbcc
[10:48:03:015] [0001.864] GSC MC Settings done
[10:48:03:015] [0001.867] BoardID = 3448, SKU = 0x2
[10:48:03:023] [0001.870] Not Nano-SD or !QSPI-ONLY, check GPT table first ...
[10:48:03:023] [0001.877] TOS Image length 53680
[10:48:03:033] [0001.880] Monitor size 53680
[10:48:03:033] [0001.883] OS size 0
[10:48:03:042] [0001.888] Secure Os AES-CMAC Verification Success!
[10:48:03:042] [0001.893] TOS image cipher info: plaintext
[10:48:03:049] [0001.897] Loading and Validation of Secure OS Successful
[10:48:03:059] [0001.913] SC7 Entry Firmware - 0xff700000, 0x4000
[10:48:03:073] [0001.917] NvTbootPackSdramParams: start.
[10:48:03:073] [0001.922] NvTbootPackSdramParams: done.
[10:48:03:073] [0001.926] Tegraboot started after 134739 us
[10:48:03:083] [0001.930] Basic modules init took 1476204 us
[10:48:03:083] [0001.934] Sec Bootdevice Read Time = 559 ms, Read Size = 14649 KB
[10:48:03:093] [0001.940] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[10:48:03:093] [0001.946] Next stage binary read took 7378 us
[10:48:03:103] [0001.950] Carveout took -28686 us
[10:48:03:103] [0001.953] CPU initialization took 383222 us
[10:48:03:112] [0001.957] Total time taken by TegraBoot 1838118 us
[10:48:03:112]
[10:48:03:112] [0001.962] Starting CPU & Halting co-processor
[10:48:03:121]
[10:48:03:121] 64NOTICE: BL31: v1.3(release):5b49e7f80
[10:48:03:132] NOTICE: BL31: Built : 08:37:40, Feb 19 2021
[10:48:03:132] ERROR: Error initializing runtime service trusty_fast
[10:48:03:235] [0002.084] RamCode = 0
[10:48:03:245] [0002.089] LPDDR4 Training: Read DT: Number of tables = 2
[10:48:03:245] [0002.094] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[10:48:03:259] [0002.106] EMC Training Successful
[10:48:03:261] [0002.110] 408000 not found in DVFS table
[10:48:03:268] [0002.116] RamCode = 0
[10:48:03:276] [0002.120] DT Write: emc-table@204000 succeeded
[10:48:03:283] [0002.125] DT Write: emc-table@1600000 succeeded
[10:48:03:283] [0002.129] LPDDR4 Training: Write DT: Number of tables = 2
[10:48:03:290] [0002.189]
[10:48:03:298] [0002.190] Debug Init done
[10:48:03:298] [0002.193] Marked DTB cacheable
[10:48:03:298] [0002.196] Bootloader DTB loaded at 0x83000000
[10:48:03:308] [0002.201] Marked DTB cacheable
[10:48:03:308] [0002.203] Kernel DTB loaded at 0x83100000
[10:48:03:316] [0002.207] DeviceTree Init done
[10:48:03:323] [0002.220] Pinmux applied successfully
[10:48:03:333] [0002.225] gicd_base: 0x50041000
[10:48:03:333] [0002.228] gicc_base: 0x50042000
[10:48:03:333] [0002.231] Interrupts Init done
[10:48:03:342] [0002.235] Using base:0x60005090 & irq:208 for tick-timer
[10:48:03:342] [0002.241] Using base:0x60005098 for delay-timer
[10:48:03:352] [0002.245] platform_init_timer: DONE
[10:48:03:352] [0002.248] Timer(tick) Init done
[10:48:03:362] [0002.252] osc freq = 38400 khz
[10:48:03:362] [0002.256]
[10:48:03:362] [0002.257] Welcome to L4T Cboot
[10:48:03:362] [0002.260]
[10:48:03:362] [0002.261] Cboot Version: 00.00.2018.01-t210-39562017
[10:48:03:373] [0002.266] calling constructors
[10:48:03:373] [0002.269] initializing heap
[10:48:03:373] [0002.272] initializing threads
[10:48:03:382] [0002.275] initializing timers
[10:48:03:382] [0002.278] creating bootstrap completion thread
[10:48:03:392] [0002.282] top of bootstrap2()
[10:48:03:392] [0002.285] CPU: ARM Cortex A57
[10:48:03:392] [0002.288] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[10:48:03:401] [0002.293] initializing platform
[10:48:03:447] [0002.346] Config for emmc ddr50 mode completed
[10:48:03:451] [0002.351] sdmmc bdev is already initialized
[10:48:03:460] [0002.355] Enable APE clock
[10:48:03:460] [0002.358] Un-powergate APE partition
[10:48:03:468] [0002.361] of_register: registering tegra_udc to of_hal
[10:48:03:468] [0002.366] of_register: registering inv20628-driver to of_hal
[10:48:03:476] [0002.372] of_register: registering ads1015-driver to of_hal
[10:48:03:484] [0002.377] of_register: registering lp8557-bl-driver to of_hal
[10:48:03:484] [0002.383] of_register: registering bq2419x_charger to of_hal
[10:48:03:494] [0002.389] of_register: registering bq27441_fuel_gauge to of_hal
[10:48:03:503] [0002.400] gpio framework initialized
[10:48:03:512] [0002.404] of_register: registering tca9539_gpio to of_hal
[10:48:03:512] [0002.409] of_register: registering tca9539_gpio to of_hal
[10:48:03:522] [0002.414] of_register: registering i2c_bus_driver to of_hal
[10:48:03:522] [0002.420] of_register: registering i2c_bus_driver to of_hal
[10:48:03:530] [0002.426] of_register: registering i2c_bus_driver to of_hal
[10:48:03:538] [0002.431] pmic framework initialized
[10:48:03:538] [0002.435] of_register: registering max77620_pmic to of_hal
[10:48:03:547] [0002.440] regulator framework initialized
[10:48:03:547] [0002.444] of_register: registering tps65132_bl_driver to of_hal
[10:48:03:555] [0002.450] initializing target
[10:48:03:562] [0002.456] gpio_driver_register: register 'tegra_gpio_driver' driver
[10:48:03:571] [0002.466] fixed regulator driver initialized
[10:48:03:585] [0002.484] initializing OF layer
[10:48:03:588] [0002.487] NCK carveout not present
[10:48:03:597] [0002.491] Skipping dts_overrides
[10:48:03:597] [0002.495] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[10:48:03:613] [0002.512] I2C Bus Init done
[10:48:03:623] [0002.514] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[10:48:03:630] [0002.525] I2C Bus Init done
[10:48:03:630] [0002.527] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[10:48:03:639] [0002.538] I2C Bus Init done
[10:48:03:647] [0002.540] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[10:48:03:656] [0002.551] I2C Bus Init done
[10:48:03:656] [0002.553] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[10:48:03:665] [0002.564] I2C Bus Init done
[10:48:03:673] [0002.567] of_children_init: Ops found for compatible string maxim,max77620
[10:48:03:680] [0002.577] max77620_init using irq 118
[10:48:03:688] [0002.582] register 'maxim,max77620' pmic
[10:48:03:688] [0002.586] gpio_driver_register: register 'max77620-gpio' driver
[10:48:03:696] [0002.592] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[10:48:03:704] [0002.603] I2C Bus Init done
[10:48:03:711] [0002.606] NCK carveout not present
[10:48:03:718] [0002.616] Find /i2c@7000c000's alias i2c0
[10:48:03:721] [0002.620] get eeprom at 1-a0, size 256, type 0
[10:48:03:730] [0002.629] Find /i2c@7000c500's alias i2c2
[10:48:03:739] [0002.633] get eeprom at 3-a0, size 256, type 0
[10:48:03:739] [0002.637] get eeprom at 3-ae, size 256, type 0
[10:48:03:747] [0002.642] pm_ids_update: Updating 1,a0, size 256, type 0
[10:48:03:755] [0002.647] I2C slave not started
[10:48:03:755] [0002.650] I2C write failed
[10:48:03:755] [0002.653] Writing offset failed
[10:48:03:765] [0002.656] eeprom_init: EEPROM read failed
[10:48:03:765] [0002.660] pm_ids_update: eeprom init failed
[10:48:03:765] [0002.664] pm_ids_update: Updating 3,a0, size 256, type 0
[10:48:03:794] [0002.694] pm_ids_update: The pm board id is 3448-0002-401
[10:48:03:807] [0002.701] Adding plugin-manager/ids/3448-0002-401=/i2c@7000c500:module@0x50
[10:48:03:819] [0002.709] pm_ids_update: pm id update successful
[10:48:03:819] [0002.714] pm_ids_update: Updating 3,ae, size 256, type 0
[10:48:03:844] [0002.744] eeprom_init: EEPROM incompatible version found
[10:48:03:858] [0002.749] pm_ids_update: eeprom init failed
[10:48:03:879] [0002.779] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[10:48:03:885] [0002.785] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[10:48:03:895] [0002.793] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[10:48:03:904] [0002.798] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[10:48:03:911] [0002.807] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:55:9a:a5
[10:48:03:919] [0002.813] Plugin Manager: Parse ODM data 0x000a4000
[10:48:03:927] [0002.825] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[10:48:03:943] [0002.840] Find /i2c@7000c000's alias i2c0
[10:48:03:945] [0002.844] get eeprom at 1-a0, size 256, type 0
[10:48:03:954] [0002.853] Find /i2c@7000c500's alias i2c2
[10:48:03:962] [0002.857] get eeprom at 3-a0, size 256, type 0
[10:48:03:969] [0002.861] get eeprom at 3-ae, size 256, type 0
[10:48:03:969] [0002.866] pm_ids_update: Updating 1,a0, size 256, type 0
[10:48:03:978] [0002.871] I2C slave not started
[10:48:03:978] [0002.874] I2C write failed
[10:48:03:978] [0002.877] Writing offset failed
[10:48:03:987] [0002.880] eeprom_init: EEPROM read failed
[10:48:03:987] [0002.884] pm_ids_update: eeprom init failed
[10:48:03:996] [0002.888] pm_ids_update: Updating 3,a0, size 256, type 0
[10:48:04:018] [0002.918] pm_ids_update: The pm board id is 3448-0002-401
[10:48:04:032] [0002.924] Adding plugin-manager/ids/3448-0002-401=/i2c@7000c500:module@0x50
[10:48:04:032] [0002.931] pm_ids_update: pm id update successful
[10:48:04:042] [0002.936] pm_ids_update: Updating 3,ae, size 256, type 0
[10:48:04:066] [0002.966] eeprom_init: EEPROM incompatible version found
[10:48:04:080] [0002.971] pm_ids_update: eeprom init failed
[10:48:04:101] [0003.001] Add serial number:1422921018541 as DT property
[10:48:04:115] [0003.008] Applying platform configs
[10:48:04:123] [0003.015] platform-init is not present. Skipping
[10:48:04:123] [0003.020] calling apps_init()
[10:48:04:141] [0003.041] Found 17 GPT partitions in "sdmmc3_user"
[10:48:04:146] [0003.046] Proceeding to Cold Boot
[10:48:04:154] [0003.049] starting app android_boot_app
[10:48:04:154] [0003.053] Device state: unlocked
[10:48:04:163] [0003.056] display console init
[10:48:04:170] [0003.064] could not find regulator
[10:48:04:170] [0003.067] hdmi cable connected
[10:48:04:187] [0003.083] edid read success
[10:48:04:202] [0003.101] DT entry for leds-pwm not found
[10:48:04:206] [0003.105] edid read success
[10:48:04:215] [0003.108] width = 640, height = 480, frequency = 25174825
[10:48:04:215] [0003.113] width = 3840, height = 2160, frequency = 594000000
[10:48:04:226] [0003.119] width = 3840, height = 2160, frequency = 297000000
[10:48:04:226] [0003.124] width = 1920, height = 1080, frequency = 148500000
[10:48:04:237] [0003.130] width = 1920, height = 1080, frequency = 148351648
[10:48:04:237] [0003.136] width = 1920, height = 1080, frequency = 74175824
[10:48:04:248] [0003.141] width = 1920, height = 1080, frequency = 74175824
[10:48:04:248] [0003.147] width = 1920, height = 1080, frequency = 148351648
[10:48:04:257] [0003.152] width = 720, height = 576, frequency = 26973026
[10:48:04:264] [0003.158] width = 720, height = 480, frequency = 26973026
[10:48:04:264] [0003.163] width = 1280, height = 720, frequency = 74175824
[10:48:04:275] [0003.169] width = 640, height = 480, frequency = 25174825
[10:48:04:275] [0003.174] width = 3840, height = 2160, frequency = 593406593
[10:48:04:287] [0003.180] width = 3840, height = 2160, frequency = 296703296
[10:48:04:287] [0003.185] width = 3840, height = 2160, frequency = 296703296
[10:48:04:296] [0003.191] width = 3840, height = 2160, frequency = 296703296
[10:48:04:303] [0003.197] width = 3840, height = 2160, frequency = 296703296
[10:48:04:303] [0003.202] Best mode Width = 1920, Height = 1080, freq = 148351648
[10:48:04:314] [0003.210] tmds-config node not found
[10:48:04:324] [0003.214] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting 'avdd-io-hdmi-dp' regulator to 1050000 micro volts
[10:48:04:338] [0003.229] setting 'vdd-1v8' regulator to 1800000 micro volts
[10:48:04:338] [0003.236] could not find regulator
[10:48:04:346] [0003.240] could not find regulator
[10:48:04:346] [0003.243] could not find regulator
[10:48:04:372] [0003.271] using default cmu settings
[10:48:04:375] [0003.275] dc_hdmi_enable, starting HDMI initialisation
[10:48:04:385] [0003.281] dc_hdmi_enable, HDMI initialisation complete
[10:48:04:394] [0003.286] list and configure display window
[10:48:04:403] [0003.295] display console init completed
[10:48:04:411] [0003.306] subnode volume_up is not found !
[10:48:04:411] [0003.310] subnode back is not found !
[10:48:04:419] [0003.314] subnode volume_down is not found !
[10:48:04:419] [0003.318] subnode menu is not found !
[10:48:04:428] [0003.321] Gpio keyboard init success
[10:48:04:469] [0003.369] found decompressor handler: lz4-legacy
[10:48:04:484] [0003.383] decompressing blob (type 1)...
[10:48:04:553] [0003.453] load_bmp_blob: panelresolution=1080 type=3
[10:48:04:603] [0003.502] decompressor handler not found
[10:48:04:607] [0003.506] load_firmware_blob: Firmware blob loaded, entries=2
[10:48:04:616] [0003.512] XUSB blob version 0 size 124416 @ 0x934b928c
[10:48:04:624] [0003.518] -------> se_aes_verify_sbk_clear: 747
[10:48:04:624] [0003.522] se_aes_verify_sbk_clear: Error
[10:48:04:632] [0003.526] SE operation failed
[10:48:04:632] [0003.529] bl_battery_charging: connected to external power supply
[10:48:04:650] [0003.545] device_query_partition_size: failed to open partition sdmmc3_user:MSC !
[10:48:04:653] [0003.552] MSC Partition not found
[10:48:04:663] [0003.562] device_query_partition_size: failed to open partition sdmmc3_user:USP !
[10:48:04:673] [0003.569] USP partition read failed!
[10:48:04:683] [0003.573] blob_init: blob-partition USP header read failed
[10:48:04:683] [0003.578] android_boot Unable to update recovery partition
[10:48:04:694] [0003.584] kfs_getpartname: name = LNX
[10:48:04:694] [0003.587] Loading kernel from LNX
[10:48:04:781] [0003.680] load kernel from storage
[10:48:04:793] [0003.690] decompressor handler not found
[10:48:04:824] [0003.724] Successfully loaded kernel and ramdisk images
[10:48:04:830] [0003.729] board ID = D78, board SKU = 2
[10:48:04:838] [0003.734] load_bmp_blob: panelresolution=1080 type=3
[10:48:05:330] [0004.230] display bmp image done
[10:48:05:334] [0004.233] NCK carveout not present
[10:48:05:344] [0004.236] Skipping dts_overrides
[10:48:05:344] [0004.239] NCK carveout not present
[10:48:05:353] [0004.249] Find /i2c@7000c000's alias i2c0
[10:48:05:354] [0004.253] get eeprom at 1-a0, size 256, type 0
[10:48:05:371] [0004.263] Find /i2c@7000c500's alias i2c2
[10:48:05:371] [0004.267] get eeprom at 3-a0, size 256, type 0
[10:48:05:378] [0004.271] get eeprom at 3-ae, size 256, type 0
[10:48:05:378] [0004.276] pm_ids_update: Updating 1,a0, size 256, type 0
[10:48:05:387] [0004.281] I2C slave not started
[10:48:05:387] [0004.284] I2C write failed
[10:48:05:396] [0004.287] Writing offset failed
[10:48:05:396] [0004.290] eeprom_init: EEPROM read failed
[10:48:05:396] [0004.294] pm_ids_update: eeprom init failed
[10:48:05:405] [0004.298] pm_ids_update: Updating 3,a0, size 256, type 0
[10:48:05:428] [0004.328] pm_ids_update: The pm board id is 3448-0002-401
[10:48:05:444] [0004.335] Adding plugin-manager/ids/3448-0002-401=/i2c@7000c500:module@0x50
[10:48:05:444] [0004.343] pm_ids_update: pm id update successful
[10:48:05:452] [0004.348] pm_ids_update: Updating 3,ae, size 256, type 0
[10:48:05:478] [0004.378] eeprom_init: EEPROM incompatible version found
[10:48:05:483] [0004.383] pm_ids_update: eeprom init failed
[10:48:05:513] [0004.413] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[10:48:05:519] [0004.419] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[10:48:05:529] [0004.427] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[10:48:05:536] [0004.432] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[10:48:05:544] [0004.441] updating /chosen/nvidia,ethernet-mac node 48:b0:2d:55:9a:a5
[10:48:05:552] [0004.447] Plugin Manager: Parse ODM data 0x000a4000
[10:48:05:567] [0004.459] shim_cmdline_install: /chosen/bootargs: earlycon=uart8250,mmio32,0x70006000
[10:48:05:568] [0004.468] Add serial number:1422921018541 as DT property
[10:48:05:577] [0004.477] "bpmp" doesn't exist, creating
[10:48:05:587] [0004.483] Updated bpmp info to DTB
[10:48:05:595] [0004.487] Updated initrd info to DTB
[10:48:05:595] [0004.491] "proc-board" doesn't exist, creating
[10:48:05:602] [0004.497] Updated board info to DTB
[10:48:05:602] [0004.500] "pmu-board" doesn't exist, creating
[10:48:05:612] [0004.506] Updated board info to DTB
[10:48:05:612] [0004.509] "display-board" doesn't exist, creating
[10:48:05:620] [0004.515] Updated board info to DTB
[10:48:05:620] [0004.519] "reset" doesn't exist, creating
[10:48:05:629] [0004.523] Updated reset info to DTB
[10:48:05:629] [0004.527] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1
[10:48:05:668] [0004.566] DTB cmdline: earlycon=uart8250,mmio32,0x70006000
[10:48:05:677] [0004.572] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[10:48:05:697] [0004.588] Updated bootarg info to DTB
[10:48:05:697] [0004.592] Adding uuid 00000001643073021c000000140501c0 to DT
[10:48:05:705] [0004.598] Adding eks info 0 to DT
[10:48:05:705] [0004.603] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[10:48:05:715] [0004.609] Updated memory info to DTB
[10:48:05:725] [0004.617] set vdd_core voltage to 1075 mv
[10:48:05:725] [0004.621] setting 'vdd-core' regulator to 1075000 micro volts
[10:48:05:734] [0004.627] Found secure-pmc; disable BPMP
[10:48:06:107]
[10:48:06:118]
[10:48:06:118] U-Boot 2020.04-g6b630d64fd (Feb 19 2021 - 08:37:46 -0800)
[10:48:06:118]
[10:48:06:118] SoC: tegra210
[10:48:06:118] Model: NVIDIA Jetson Nano Developer Kit
[10:48:06:118] Board: NVIDIA P3450-0000
[10:48:06:134] DRAM: 4 GiB
[10:48:06:444] MMC: sdhci@700b0000: 1, sdhci@700b0600: 0
[10:48:06:448] Loading Environment from SPI Flash... *** Warning - spi_flash_probe_bus_cs() failed, using default environment
[10:48:06:459]
[10:48:06:459] In: serial
[10:48:06:470] Out: serial
[10:48:06:470] Err: serial
[10:48:06:470] Net: No ethernet found.
[10:48:06:470] Hit any key to stop autoboot: 2 <0x08><0x08><0x08> 1 <0x08><0x08><0x08> 0
[10:48:08:478] Card did not respond to voltage select!
[10:48:08:531] switch to partitions #0, OK
[10:48:08:533] mmc0(part 0) is current device
[10:48:08:788] Scanning mmc 0:1...
[10:48:08:889] Found /boot/extlinux/extlinux.conf
[10:48:08:893] Retrieving file: /boot/extlinux/extlinux.conf
[10:48:08:948] 912 bytes read in 20 ms (43.9 KiB/s)
[10:48:08:952] 1: primary kernel
[10:48:08:962] Retrieving file: /boot/initrd
[10:48:09:168] 7159841 bytes read in 181 ms (37.7 MiB/s)
[10:48:09:172] Retrieving file: /boot/Image
[10:48:09:983] 34404360 bytes read in 777 ms (42.2 MiB/s)
[10:48:09:995] append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 quiet root=/dev/mmcblk1p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[10:48:10:051] Retrieving file: /boot/dtb/kernel_tegra210-p3448-0000-p3449-0000-b00.dtb
[10:48:10:113] 249239 bytes read in 24 ms (9.9 MiB/s)
[10:48:10:186] ## Flattened Device Tree blob at 83000000
[10:48:10:190] Booting using the fdt blob at 0x83000000
[10:48:10:201] ERROR: reserving fdt memory region failed (addr=0 size=0)
[10:48:10:211] Using Device Tree in place at 0000000083000000, end 000000008303fd96
[10:48:10:219] copying carveout for /host1x@50000000/dc@54200000...
[10:48:10:219] copying carveout for /host1x@50000000/dc@54240000...
[10:48:10:270] DT property /chosen/nvidia,bluetooth-mac missing in source; can't copy
[10:48:10:285] DT property /chosen/nvidia,wifi-mac missing in source; can't copy
[10:48:10:291] DT property /psci/nvidia,system-lp0-disable missing in source; can't copy
[10:48:10:304]
[10:48:10:304] Starting kernel ...
[10:48:10:304]
[10:48:10:410] [ 0.000000] Booting Linux on physical CPU 0x0
[10:48:10:414] [ 0.000000] Linux version 4.9.201-tegra (pico1@pico1-NUC7i7BNH) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #2 SMP PREEMPT Thu Jan 20 15:53:15 HKT 2022
[10:48:10:436] [ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[10:48:10:449] [ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[10:48:10:449] [ 0.000000] OF: fdt: - 80000000 , 7ee00000
[10:48:10:460] [ 0.000000] OF: fdt: - 100000000 , 7f200000
[10:48:10:460] [ 0.000000] Found tegra_fbmem: 00800000@92cb4000
[10:48:10:470] [ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[10:48:10:470] [ 0.000000] bootconsole [uart8250] enabled
[10:48:10:482] [ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[10:48:10:491] [ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[10:48:10:500] [ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[10:48:10:509] [ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[10:48:10:527] [ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[10:48:10:527] [ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[10:48:10:538] [ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[10:48:10:551] [ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[10:48:10:792] [ 0.000000] psci: probing for conduit method from DT.
[10:48:10:805] [ 0.000000] psci: PSCIv1.0 detected in firmware.
[10:48:10:805] [ 0.000000] psci: Using standard PSCI v0.2 function IDs
[10:48:10:814] [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[10:48:10:814] [ 0.000000] psci: SMC Calling Convention v1.1
[10:48:10:823] [ 0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[10:48:10:844] [ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[10:48:10:850] [ 0.000000] Speculative Store Bypass Disable mitigation not required
[10:48:10:859] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[10:48:10:868] [ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[10:48:10:933] [ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[10:48:10:933] [ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[10:48:10:942] [ 0.000000] log_buf_len min size: 32768 bytes
[10:48:10:942] [ 0.000000] log_buf_len: 131072 bytes
[10:48:10:954] [ 0.000000] early log buf free: 29336(89%)
[10:48:10:954] [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[10:48:10:965] [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[10:48:10:974] [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[10:48:11:066] [ 0.000000] Memory: 3560264K/4159488K available (15294K kernel code, 2942K rwdata, 6744K rodata, 8576K init, 609K bss, 124088K reserved, 475136K cma-reserved)
[10:48:11:081] [ 0.000000] Virtual kernel memory layout:
[10:48:11:090] [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[10:48:11:099] [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[10:48:11:107] [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[10:48:11:107] [ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009610000 ( 6784 KB)
[10:48:11:117] [ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e70000 ( 8576 KB)
[10:48:11:127] [ 0.000000] .data : 0xffffff8009e70000 - 0xffffff800a14f808 ( 2943 KB)
[10:48:11:138] [ 0.000000] .bss : 0xffffff800a14f808 - 0xffffff800a1e7cbc ( 610 KB)
[10:48:11:138] [ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[10:48:11:149] [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[10:48:11:157] [ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[10:48:11:167] [ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[10:48:11:176] [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[10:48:11:188] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[10:48:11:188] [ 0.000000] Preemptible hierarchical RCU implementation.
[10:48:11:198] [ 0.000000] Build-time adjustment of leaf fanout to 64.
[10:48:11:198] [ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[10:48:11:208] [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[10:48:11:217] [ 0.000000] NR_IRQS:64 nr_irqs:64 0
[10:48:11:226] [ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[10:48:11:238] [ 0.000000] t210 clock and reset probe
[10:48:11:248] [ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[10:48:11:259] [ 0.000000] clk_cbus_recalc_rate: no gbus parent
[10:48:11:268] [ 0.000000] clk_cbus_recalc_rate: no gbus parent
[10:48:11:277] [ 0.000000] clk_cbus_recalc_rate: no gbus parent
[10:48:11:287] [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[10:48:11:296] [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[10:48:11:304] [ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[10:48:11:315] [ 0.010063] Console: colour dummy device 80x25
[10:48:11:326] [ 0.014715] console [tty0] enabled
[10:48:11:326] [ 0.018225] bootconsole [uart8250] disabled
[10:48:12:470] [ 0.000000] Booting Linux on physical CPU 0x0
[10:48:12:474] [ 0.000000] Linux version 4.9.201-tegra (pico1@pico1-NUC7i7BNH) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #2 SMP PREEMPT Thu Jan 20 15:53:15 HKT 2022
[10:48:12:504] [ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[10:48:12:504] [ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 32,
[10:48:12:513] [ 0.000000] OF: fdt: - 80000000 , 7ee00000
[10:48:12:513] [ 0.000000] OF: fdt: - 100000000 , 7f200000
[10:48:12:523] [ 0.000000] Found tegra_fbmem: 00800000@92cb4000
[10:48:12:523] [ 0.000000] earlycon: uart8250 at MMIO32 0x0000000070006000 (options '')
[10:48:12:532] [ 0.000000] bootconsole [uart8250] enabled
[10:48:12:532] [ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[10:48:12:542] [ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb0_carveout': base 0x0000000000000000, size 0 MiB
[10:48:12:552] [ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[10:48:12:563] [ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node 'fb1_carveout': base 0x0000000000000000, size 0 MiB
[10:48:12:574] [ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[10:48:12:584] [ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[10:48:12:594] [ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[10:48:12:605] [ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[10:48:12:614] [ 0.000000] psci: probing for conduit method from DT.
[10:48:12:614] [ 0.000000] psci: PSCIv1.0 detected in firmware.
[10:48:12:622] [ 0.000000] psci: Using standard PSCI v0.2 function IDs
[10:48:12:622] [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[10:48:12:631] [ 0.000000] psci: SMC Calling Convention v1.1
[10:48:12:631] [ 0.000000] percpu: Embedded 24 pages/cpu s57560 r8192 d32552 u98304
[10:48:12:641] [ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[10:48:12:650] [ 0.000000] Speculative Store Bypass Disable mitigation not required
[10:48:12:650] [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[10:48:12:659] [ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1
[10:48:12:711] [ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[10:48:12:722] [ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[10:48:12:734] [ 0.000000] log_buf_len min size: 32768 bytes
[10:48:12:734] [ 0.000000] log_buf_len: 131072 bytes
[10:48:12:734] [ 0.000000] early log buf free: 29336(89%)
[10:48:12:744] [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[10:48:12:744] [ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[10:48:12:753] [ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[10:48:12:762] [ 0.000000] Memory: 3560264K/4159488K available (15294K kernel code, 2942K rwdata, 6744K rodata, 8576K init, 609K bss, 124088K reserved, 475136K cma-reserved)
[10:48:12:779] [ 0.000000] Virtual kernel memory layout:
[10:48:12:779] [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[10:48:12:788] [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[10:48:12:797] [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f70000 ( 15296 KB)
[10:48:12:797] [ 0.000000] .rodata : 0xffffff8008f70000 - 0xffffff8009610000 ( 6784 KB)
[10:48:12:811] [ 0.000000] .init : 0xffffff8009610000 - 0xffffff8009e70000 ( 8576 KB)
[10:48:12:811] [ 0.000000] .data : 0xffffff8009e70000 - 0xffffff800a14f808 ( 2943 KB)
[10:48:12:822] [ 0.000000] .bss : 0xffffff800a14f808 - 0xffffff800a1e7cbc ( 610 KB)
[10:48:12:832] [ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[10:48:12:842] [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[10:48:12:842] [ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[10:48:12:853] [ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[10:48:12:862] [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[10:48:12:871] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[10:48:12:871] [ 0.000000] Preemptible hierarchical RCU implementation.
[10:48:12:883] [ 0.000000] Build-time adjustment of leaf fanout to 64.
[10:48:12:883] [ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[10:48:12:893] [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[10:48:12:893] [ 0.000000] NR_IRQS:64 nr_irqs:64 0
[10:48:12:904] [ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[10:48:12:915] [ 0.000000] t210 clock and reset probe
[10:48:12:915] [ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[10:48:12:927] [ 0.000000] clk_cbus_recalc_rate: no gbus parent
[10:48:12:939] [ 0.000000] clk_cbus_recalc_rate: no gbus parent
[10:48:12:939] [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[10:48:12:949] [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[10:48:12:959] [ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[10:48:12:969] [ 0.010063] Console: colour dummy device 80x25
[10:48:12:969] [ 0.014715] console [tty0] enabled
[10:48:12:980] [ 0.018225] bootconsole [uart8250] disabled
[10:48:12:980] [ 0.022558] kmemleak: Kernel memory leak detector disabled
[10:48:12:989] [ 0.022588] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=76800)
[10:48:12:998] [ 0.022610] pid_max: default: 32768 minimum: 301
[10:48:12:998] [ 0.023080] Security Framework initialized
[10:48:13:008] [ 0.023305] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[10:48:13:008] [ 0.023322] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[10:48:13:017] [ 0.024548] ftrace: allocating 47208 entries in 185 pages
[10:48:13:028] [ 0.194711] ASID allocator initialised with 65536 entries
[10:48:13:028] [ 0.232742] tegra-id: chipid=22117.
[10:48:13:039] [ 0.232773] tegra-id: opt_subrevision=0.
[10:48:13:039] [ 0.232797] Tegra Speedo/IDDQ fuse revision 4
[10:48:13:039] [ 0.232807] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[10:48:13:049] [ 0.232817] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[10:48:13:058] [ 0.232829] Tegra: CPU Speedo Value 2100, SoC Speedo Value 1989, GPU Speedo Value 2097
[10:48:13:058] [ 0.232840] Tegra: CPU IDDQ Value 2056, SoC IDDQ Value 2160, GPU IDDQ Value 2715
[10:48:13:068] [ 0.232866] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[10:48:13:076] [ 0.232890] DTS File Name: /home/pico1/Downloads/public_sources_3251_nano/Linux_for_Tegra/source/public/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[10:48:13:094] [ 0.232922] DTB Build time: Jan 21 2022 09:25:39
[10:48:13:103] [ 0.281348] CPU1: Booted secondary processor [411fd071]
[10:48:13:112] [ 0.313248] CPU2: Booted secondary processor [411fd071]
[10:48:13:112] [ 0.345202] CPU3: Booted secondary processor [411fd071]
[10:48:13:122] [ 0.345298] Brought up 4 CPUs
[10:48:13:122] [ 0.345352] SMP: Total of 4 processors activated.
[10:48:13:122] [ 0.345369] CPU features: detected feature: 32-bit EL0 Support
[10:48:13:134] [ 0.345644] CPU: All CPU(s) started at EL2
[10:48:13:134] [ 0.345672] alternatives: patching kernel code
[10:48:13:144] [ 0.354151] devtmpfs: initialized
[10:48:13:144] [ 0.396836] Initilizing CustomIPI irq domain
[10:48:13:144] [ 0.397276] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[10:48:13:156] [ 0.397321] futex hash table entries: 1024 (order: 4, 65536 bytes)
[10:48:13:166] [ 0.408830] pinctrl core: initialized pinctrl subsystem
[10:48:13:166] [ 0.409561] OS set in device tree is not L4T.
[10:48:13:175] [ 0.410021] regulator-dummy: no parameters
[10:48:13:175] [ 0.410317] Initializing plugin-manager
[10:48:13:185] [ 0.410489] Plugin module not found
[10:48:13:185] [ 0.410686] node /plugin-manager/fragement@0 match with board >=3448-0002-100
[10:48:13:195] [ 0.411261] node /plugin-manager/fragment@1 match with board >=3448-0002-101
[10:48:13:195] [ 0.411708] node /plugin-manager/fragment@3 match with board >=3448-0002-100
[10:48:13:205] [ 0.412423] node /plugin-manager/fragement@7 match with odm-data enable-pmic-wdt
[10:48:13:214] [ 0.412650] node /plugin-manager/fragement@8 match with odm-data enable-pmic-wdt
[10:48:13:222] [ 0.413252] node /plugin-manager/fragement@10 match with board >=3448-0002-300
[10:48:13:230] [ 0.415116] node /plugin-manager/fragement@13 match with board >=3448-0002-300
[10:48:13:230] [ 0.418993] NET: Registered protocol family 16
[10:48:13:241] [ 0.431980] pstore: using zlib compression
[10:48:13:241] [ 0.432515] console [pstore-1] enabled
[10:48:13:252] [ 0.432533] pstore: Registered ramoops as persistent store backend
[10:48:13:252] [ 0.432552] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[10:48:13:261] [ 0.449364] cpuidle: using governor menu
[10:48:13:261] [ 0.453125] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[10:48:13:271] [ 0.455280] vdso: 2 pages (1 code @ ffffff8008f77000, 1 data @ ffffff8009e74000)
[10:48:13:280] [ 0.455328] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[10:48:13:280] [ 0.457947] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[10:48:13:290] [ 0.460663] Serial: AMBA PL011 UART driver
[10:48:13:298] [ 0.461190] tegra_powergate_init: DONE
[10:48:13:298] [ 0.461223] DTS File Name: /home/pico1/Downloads/public_sources_3251_nano/Linux_for_Tegra/source/public/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-b00.dts
[10:48:13:317] [ 0.461264] DTB Build time: Jan 21 2022 09:25:39
[10:48:13:328] [ 0.463490] Tegra reboot handler registered.
[10:48:13:328] [ 0.468299] iommu: Adding device tegra-carveouts to group 0
[10:48:13:337] [ 0.468479] platform tegra-carveouts: domain=ffffffc0f97f83d8 allocates as[0]=ffffffc0f90b40a8
[10:48:13:345] [ 0.468860] iommu: Adding device smmu_test to group 1
[10:48:13:345] [ 0.468926] platform smmu_test: domain=ffffffc0f97f8618 allocates as[0]=ffffffc0f90b4110
[10:48:13:354] [ 0.469829] mc: mapped MMIO address: 0xffffff800802e000 -> 0x70019000
[10:48:13:362] [ 0.469902] mc: mapped MMIO address: 0xffffff8008065000 -> 0x7001c000
[10:48:13:371] [ 0.469972] mc: mapped MMIO address: 0xffffff8008079000 -> 0x7001d000
[10:48:13:382] [ 0.469993] nv-tegra-mc 70019000.mc: No mssnvlink node
[10:48:13:382] [ 0.470027] mc-err: mcerr ops are set to t21x
[10:48:13:382] [ 0.480656] iommu: Adding device 70090000.xusb to group 2
[10:48:13:394] [ 0.480979] iommu: Adding device 70006000.serial to group 3
[10:48:13:394] [ 0.481071] platform 70006000.serial: domain=ffffffc0f911e558 allocates as[0]=ffffffc0f90b4178
[10:48:13:403] [ 0.481709] iommu: Adding device 70006040.serial to group 4
[10:48:13:412] [ 0.482006] iommu: Adding device 70006200.serial to group 5
[10:48:13:419] [ 0.482250] iommu: Adding device sound to group 6
[10:48:13:419] [ 0.482316] platform sound: domain=ffffffc0f911ea98 allocates as[0]=ffffffc0f90b41e0
[10:48:13:428] [ 0.482898] iommu: Adding device 7000d400.spi to group 7
[10:48:13:436] [ 0.483175] iommu: Adding device 7000d600.spi to group 8
[10:48:13:436] [ 0.483472] iommu: Adding device 70410000.spi to group 9
[10:48:13:445] [ 0.483795] iommu: Adding device 50000000.host1x to group 10
[10:48:13:454] [ 0.484088] iommu: Adding device 54080000.vi to group 11
[10:48:13:454] [ 0.484496] iommu: Adding device 54600000.isp to group 12
[10:48:13:465] [ 0.484774] iommu: Adding device 54680000.isp to group 13
[10:48:13:465] [ 0.485110] iommu: Adding device tegradc.0 to group 14
[10:48:13:475] [ 0.485177] platform tegradc.0: domain=ffffffc0f912a9d8 allocates as[0]=ffffffc0f90b4248
[10:48:13:475] [ 0.489417] platform tegradc.0: IOVA linear map 0x0000000092cb4000(800000)
[10:48:13:486] [ 0.489828] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[10:48:13:495] [ 0.490185] iommu: Adding device tegradc.1 to group 15
[10:48:13:495] [ 0.490249] platform tegradc.1: domain=ffffffc0f912ac18 allocates as[0]=ffffffc0f90b42b0
[10:48:13:505] [ 0.494445] platform tegradc.1: IOVA linear map 0x0000000092cb4000(800000)
[10:48:13:514] [ 0.494853] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[10:48:13:524] [ 0.495128] iommu: Adding device 54340000.vic to group 16
[10:48:13:524] [ 0.495352] iommu: Adding device 544c0000.nvenc to group 17
[10:48:13:536] [ 0.495574] iommu: Adding device 54500000.tsec to group 18
[10:48:13:536] [ 0.495812] iommu: Adding device 54100000.tsecb to group 19
[10:48:13:545] [ 0.496024] iommu: Adding device 54480000.nvdec to group 20
[10:48:13:545] [ 0.496269] iommu: Adding device 54380000.nvjpg to group 21
[10:48:13:555] [ 0.497372] iommu: Adding device 546c0000.i2c to group 22
[10:48:13:563] [ 0.497735] iommu: Adding device 57000000.gpu to group 23
[10:48:13:563] [ 0.497801] platform 57000000.gpu: domain=ffffffc0f9138c18 allocates as[0]=ffffffc0f90b4318
[10:48:13:573] [ 0.497856] platform 57000000.gpu: domain=ffffffc0f9138c18 allocates as[1]=ffffffc0f90b4380
[10:48:13:583] [ 0.497919] platform 57000000.gpu: domain=ffffffc0f9138c18 allocates as[2]=ffffffc0f90b43e8
[10:48:13:594] [ 0.497975] platform 57000000.gpu: domain=ffffffc0f9138c18 allocates as[3]=ffffffc0f90b4450
[10:48:13:594] [ 0.498902] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[10:48:13:605] [ 0.498943] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[10:48:13:614] [ 0.498969] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[10:48:13:622] [ 0.498987] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[10:48:13:622] [ 0.499003] tegra-pmc: ### PMC reset status reg: 0x3
[10:48:13:630] [ 0.549432] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[10:48:13:639] [ 0.549467] tegra-pmc: Clear bootloader IO dpd settings
[10:48:13:649] [ 0.549499] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[10:48:13:649] [ 0.549573] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[10:48:13:658] [ 0.549885] iommu: Adding device 70012000.se to group 24
[10:48:13:658] [ 0.550741] iommu: Adding device 7000c000.i2c to group 25
[10:48:13:668] [ 0.551076] iommu: Adding device 7000c400.i2c to group 26
[10:48:13:676] [ 0.551408] iommu: Adding device 7000c500.i2c to group 27
[10:48:13:676] [ 0.551723] iommu: Adding device 7000c700.i2c to group 28
[10:48:13:686] [ 0.552078] iommu: Adding device 7000d000.i2c to group 29
[10:48:13:686] [ 0.552391] iommu: Adding device 7000d100.i2c to group 30
[10:48:13:695] [ 0.552741] iommu: Adding device sdhci-tegra.3 to group 31
[10:48:13:703] [ 0.552814] platform sdhci-tegra.3: domain=ffffffc0f91e6e58 allocates as[0]=ffffffc0f90b44b8
[10:48:13:712] [ 0.553352] iommu: Adding device sdhci-tegra.2 to group 32
[10:48:13:712] [ 0.553427] platform sdhci-tegra.2: domain=ffffffc0f91f3018 allocates as[0]=ffffffc0f90b4520
[10:48:13:722] [ 0.554431] iommu: Adding device 700d0000.xudc to group 33
[10:48:13:730] [ 0.558481] vdd-ac-bat: 5000 mV
[10:48:13:730] [ 0.558971] vdd-5v0-sys: 5000 mV
[10:48:13:740] [ 0.560107] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[10:48:13:740] [ 0.560174] vdd-5v0-hdmi: 5000 mV
[10:48:13:740] [ 0.560644] vdd-1v8-sys: 1800 mV
[10:48:13:752] [ 0.561070] vdd-fan: supplied by vdd-5v0-sys
[10:48:13:752] [ 0.561143] vdd-fan: 5000 mV
[10:48:13:752] [ 0.561608] vdd-usb-vbus: supplied by vdd-5v0-sys
[10:48:13:761] [ 0.561658] vdd-usb-vbus: 5000 mV
[10:48:13:761] [ 0.562319] vdd-usb-vbus2: 5000 mV
[10:48:13:761] [ 0.590348] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[10:48:13:772] [ 0.592866] gpio gpiochip0: gpio-line-names specifies 240 line names but there are 256 lines on the chip
[10:48:13:781] [ 0.595239] GPIO line 151 (camera-control-output-low) hogged as output/low
[10:48:13:790] [ 0.595283] GPIO line 152 (camera-control-output-low) hogged as output/low
[10:48:13:798] [ 0.595340] GPIO line 6 (system-suspend-gpio) hogged as output/high
[10:48:13:798] [ 0.595744] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[10:48:13:808] [ 0.601220] random: fast init done
[10:48:13:808] [ 0.603929] eventlib_kernel: keventlib is initialized, test id: 0
[10:48:13:818] [ 0.604309] SCSI subsystem initialized
[10:48:13:818] [ 0.604863] usbcore: registered new interface driver usbfs
[10:48:13:829] [ 0.604934] usbcore: registered new interface driver hub
[10:48:13:829] [ 0.605031] usbcore: registered new device driver usb
[10:48:13:840] [ 0.609008] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[10:48:13:840] [ 0.613500] vdd-core: 600 <--> 1162 mV at 1075 mV
[10:48:13:850] [ 0.614487] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[10:48:13:861] [ 0.617221] vdd-ddr-1v1: 1150 mV
[10:48:13:861] [ 0.621220] vdd-pre-reg-1v35: 1350 mV
[10:48:13:861] [ 0.625226] vdd-1v8: 1800 mV
[10:48:13:861] [ 0.629218] avdd-sys-1v2: 1200 mV
[10:48:13:873] [ 0.633219] vdd-pex-1v0: 1050 mV
[10:48:13:873] [ 0.633863] vddio-sdmmc-ap: 1800 <--> 3300 mV at 3300 mV
[10:48:13:873] [ 0.634412] max77620-ldo3: at 3100 mV
[10:48:13:884] [ 0.637220] vdd-rtc: 850 <--> 1100 mV at 1000 mV
[10:48:13:884] [ 0.637811] max77620-ldo5: at 3100 mV
[10:48:13:895] [ 0.641220] vddio-sdmmc3-ap: 1800 <--> 3300 mV at 3300 mV
[10:48:13:895] [ 0.645216] avdd-1v05-pll: 1050 mV
[10:48:13:895] [ 0.649219] avdd-io-hdmi-dp: 1050 mV
[10:48:13:906] [ 0.651698] GPIO line 505 (spmic-default-output-high) hogged as output/high
[10:48:13:906] [ 0.652009] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[10:48:13:915] [ 0.652311] max77620 4-003c: max77620 probe successful
[10:48:13:924] [ 0.655092] media: Linux media interface: v0.10
[10:48:13:924] [ 0.655163] Linux video capture interface: v2.00
[10:48:13:935] [ 0.656083] pps_core: LinuxPPS API ver. 1 registered
[10:48:13:935] [ 0.656109] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[10:48:13:946] [ 0.656147] PTP clock support registered
[10:48:13:946] [ 0.659374] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[10:48:13:956] [ 0.660313] Advanced Linux Sound Architecture Driver Initialized.
[10:48:13:965] [ 0.661096] Bluetooth: Core ver 2.22
[10:48:13:965] [ 0.661169] NET: Registered protocol family 31
[10:48:13:976] [ 0.661185] Bluetooth: HCI device and connection manager initialized
[10:48:13:976] [ 0.661213] Bluetooth: HCI socket layer initialized
[10:48:13:985] [ 0.661235] Bluetooth: L2CAP socket layer initialized
[10:48:13:985] [ 0.661301] Bluetooth: SCO socket layer initialized
[10:48:13:994] [ 0.663147] tegra210_dvfs: no clock found for sdmmc2_ddr
[10:48:13:994] [ 0.663185] tegra210_dvfs: no clock found for sdmmc4_ddr
[10:48:14:004] [ 0.663246] tegra210_dvfs: no clock found for sdmmc1_ddr
[10:48:14:004] [ 0.663272] tegra210_dvfs: no clock found for sdmmc3_ddr
[10:48:14:013] [ 0.667385] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[10:48:14:024] [ 0.668950] vdd-3v3-sys: supplied by vdd-5v0-sys
[10:48:14:024] [ 0.669041] vdd-3v3-sys: 3300 mV
[10:48:14:033] [ 0.669572] vdd-1v8-sys: supplied by vdd-3v3-sys
[10:48:14:033] [ 0.673329] vdd-usb-vbus2: supplied by vdd-3v3-sys
[10:48:14:042] [ 0.673877] vdd-3v3-sd: supplied by vdd-3v3-sys
[10:48:14:042] [ 0.673935] vdd-3v3-sd: 3300 mV
[10:48:14:051] [ 0.674888] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[10:48:14:051] [ 0.674951] avdd-io-edp-1v05: 1050 mV
[10:48:14:051] [ 0.675410] vdd-usb-hub-en: supplied by vdd-1v8-sys
[10:48:14:060] [ 0.675461] vdd-usb-hub-en: 5000 mV
[10:48:14:060] [ 0.676854] camchar: rtcpu character device driver loaded
[10:48:14:069] [ 0.677748] extcon-gpio-states extcon:extcon@1: Cable state:0, cable id:0
[10:48:14:077] [ 0.679120] clocksource: Switched to clocksource arch_sys_counter
[10:48:14:085] [ 0.720506] VFS: Disk quotas dquot_6.6.0
[10:48:14:085] [ 0.720676] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[10:48:14:095] [ 0.721169] nvmap_heap_init: nvmap_heap_init: created heap block cache
[10:48:14:103] [ 0.721622] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[10:48:14:112] [ 0.721684] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[10:48:14:122] [ 0.721905] cma: enabled page replacement for spfn=d7000, epfn=f0000
[10:48:14:131] [ 0.721926] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[10:48:14:141] [ 0.721952] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[10:48:14:141] [ 0.721996] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[10:48:14:152] [ 0.722021] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[10:48:14:160] [ 0.722052] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[10:48:14:169] [ 0.722072] nvmap_page_pool_init: Total RAM pages: 1008850
[10:48:14:178] [ 0.722090] nvmap_page_pool_init: nvmap page pool size: 126106 pages (492 MB)
[10:48:14:178] [ 0.722197] nvmap_background_zero_thread: PP zeroing thread starting.
[10:48:14:188] [ 0.722606] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[10:48:14:197] [ 0.723615] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[10:48:14:206] [ 0.732154] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[10:48:14:214] [ 0.732685] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[10:48:14:226] [ 0.733080] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[10:48:14:226] [ 0.733383] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[10:48:14:235] [ 0.733597] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[10:48:14:244] [ 0.733902] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[10:48:14:255] [ 0.733922] pre_t19x_iso_plat_init(): max_iso_bw=11520000KB
[10:48:14:255] [ 0.734380] NET: Registered protocol family 2
[10:48:14:268] [ 0.735428] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[10:48:14:268] [ 0.735665] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[10:48:14:280] [ 0.736234] TCP: Hash tables configured (established 32768 bind 32768)
[10:48:14:280] [ 0.736399] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[10:48:14:289] [ 0.736496] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[10:48:14:289] [ 0.736924] NET: Registered protocol family 1
[10:48:14:299] [ 0.737673] RPC: Registered named UNIX socket transport module.
[10:48:14:307] [ 0.737698] RPC: Registered udp transport module.
[10:48:14:307] [ 0.737714] RPC: Registered tcp transport module.
[10:48:14:316] [ 0.737729] RPC: Registered tcp NFSv4.1 backchannel transport module.
[10:48:14:316] [ 0.738011] Trying to unpack rootfs image as initramfs...
[10:48:14:326] [ 1.043394] Freeing initrd memory: 6992K
[10:48:14:326] [ 1.053664] host1x 50000000.host1x: initialized
[10:48:14:336] [ 1.055579] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[10:48:14:343] [ 1.058935] audit: initializing netlink subsys (disabled)
[10:48:14:343] [ 1.059061] audit: type=2000 audit(0.899:1): initialized
[10:48:14:353] [ 1.059909] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[10:48:14:362] [ 1.069890] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[10:48:14:362] [ 1.071423] ntfs: driver 2.1.32 [Flags: R/W].
[10:48:14:371] [ 1.072231] 9p: Installing v9fs 9p2000 file system support
[10:48:14:371] [ 1.075850] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[10:48:14:381] [ 1.076020] io scheduler noop registered
[10:48:14:381] [ 1.076320] io scheduler cfq registered (default)
[10:48:14:392] [ 1.079058] gic 702f9000.agic: GIC IRQ controller registered
[10:48:14:392] [ 1.082076] iommu: Adding device 702ef000.adsp to group 34
[10:48:14:404] [ 1.090832] iommu: Adding device aconnect@702c0000:adsp_audio to group 35
[10:48:14:404] [ 1.090998] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[10:48:14:413] [ 1.091830] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x9228c12
[10:48:14:422] [ 1.091862] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[10:48:14:430] [ 1.093548] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[10:48:14:438] [ 1.093689] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[10:48:14:445] [ 1.093803] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[10:48:14:453] [ 1.094020] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[10:48:14:463] [ 1.094132] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[10:48:14:476] [ 1.094240] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[10:48:14:486] [ 1.094344] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[10:48:14:494] [ 1.094456] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[10:48:14:502] [ 1.094566] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[10:48:14:511] [ 1.094674] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[10:48:14:519] [ 1.100814] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[10:48:14:527] [ 1.102607] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[10:48:14:536] [ 1.104653] tegra-pcie 1003000.pcie: 4x1, 1x1 configuration
[10:48:14:536] [ 1.105942] tegra-pcie 1003000.pcie: PCIE: Enable power rails
[10:48:14:545] [ 1.106314] tegra-pcie 1003000.pcie: probing port 0, using 4 lanes
[10:48:14:555] [ 1.107665] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[10:48:14:563] [ 1.107919] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=1500000, max_bw=1500000
[10:48:14:571] [ 1.108203] Adding domain tsec-pd to PM domain host1x-pd
[10:48:14:580] [ 1.110586] tegra-pcie 1003000.pcie: probing port 1, using 1 lanes
[10:48:14:580] [ 1.111656] tsec 54500000.tsec: initialized
[10:48:14:590] [ 1.113287] tsec 54100000.tsecb: initialized
[10:48:14:590] [ 1.114044] Adding domain nvdec-pd to PM domain host1x-pd
[10:48:14:600] [ 1.117916] nvdec 54480000.nvdec: initialized
[10:48:14:600] [ 1.119035] Adding domain vic03-pd to PM domain host1x-pd
[10:48:14:610] [ 1.119261] Adding domain msenc-pd to PM domain host1x-pd
[10:48:14:610] [ 1.119442] Adding domain nvjpg-pd to PM domain host1x-pd
[10:48:14:619] [ 1.123970] falcon 54340000.vic: initialized
[10:48:14:619] [ 1.125269] falcon 544c0000.nvenc: initialized
[10:48:14:632] [ 1.126650] falcon 54380000.nvjpg: initialized
[10:48:14:632] [ 1.131060] tegra_cec 70015000.tegra_cec: dt=1 start=0x70015000 end=0x70015FFF irq=98
[10:48:14:644] [ 1.131169] tegra_cec 70015000.tegra_cec: Enable clock result: 0.
[10:48:14:644] [ 1.131219] tegra_cec 70015000.tegra_cec: tegra_cec_init started
[10:48:14:654] [ 1.131396] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[10:48:14:654] [ 1.131514] display board info: id 0x0, fab 0x0
[10:48:14:666] [ 1.131535] tegra_cec 70015000.tegra_cec: cec_add_sysfs ret=0
[10:48:14:666] [ 1.131555] tegra_cec 70015000.tegra_cec: probed
[10:48:14:677] [ 1.131590] generic_infoframe_type: 0x87
[10:48:14:677] [ 1.131752] tegradc tegradc.0: DT parsed successfully
[10:48:14:677] [ 1.131815] tegradc tegradc.0: Display dc.ffffff800ab80000 registered with id=0
[10:48:14:689] [ 1.132380] tegradc tegradc.0: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350781
[10:48:14:697] [ 1.140381] tegradc tegradc.0: probed
[10:48:14:709] [ 1.140386] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[10:48:14:709] [ 1.147525] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 22 channels
[10:48:14:720] [ 1.148811] tegra-fuse-burn 7000f800.efuse:efuse-burn: shutdown limit check disabled
[10:48:14:731] [ 1.148851] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[10:48:14:731] [ 1.149316] kfuse 7000fc00.kfuse: initialized
[10:48:14:743] [ 1.150989] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[10:48:14:743] [ 1.152156] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[10:48:14:754] [ 1.153798] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[10:48:14:764] [ 1.153846] vdd-cpu: 708 <--> 1322 mV at 708 mV
[10:48:14:764] [ 1.154358] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[10:48:14:774] [ 1.156051] vdd-gpu: applied init 1000000uV constraint
[10:48:14:774] [ 1.156079] vdd-gpu: 708 <--> 1323 mV at 997 mV
[10:48:14:784] [ 1.156514] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[10:48:14:794] [ 1.161813] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[10:48:14:794] [ 1.162012] No Device Node present for smmu client: serial8250 !!
[10:48:14:804] [ 1.162044] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[10:48:14:814] [ 1.162122] iommu: Adding device serial8250 to group 36
[10:48:14:814] [ 1.165990] console [ttyS0] disabled
[10:48:14:826] [ 1.166217] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[10:48:14:826] [ 1.637631] tegra-pcie 1003000.pcie: link 0 down, retrying
[10:48:14:837] [ 2.042188] tegra-pcie 1003000.pcie: link 0 down, retrying
[10:48:14:837] [ 2.143140] tegra_cec 70015000.tegra_cec: Can't find physical addresse.
[10:48:14:848] [ 2.143144] tegra_cec 70015000.tegra_cec: tegra_cec_init Done.
[10:48:14:848] [ 2.446630] tegra-pcie 1003000.pcie: link 0 down, retrying
[10:48:14:858] [ 2.448650] tegra-pcie 1003000.pcie: link 0 down, ignoring
[10:48:14:867] [ 2.554889] tegra-pcie 1003000.pcie: PCI host bridge to bus 0000:00
[10:48:14:867] [ 2.554899] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[10:48:14:877] [ 2.554904] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[10:48:14:887] [ 2.554909] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[10:48:14:887] [ 2.554915] pci_bus 0000:00: root bus resource [bus 00-ff]
[10:48:14:897] [ 2.555330] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[10:48:14:906] [ 2.567230] pci 0000:00:02.0: BAR 15: assigned [mem 0x20000000-0x200fffff 64bit pref]
[10:48:14:914] [ 2.567236] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[10:48:14:914] [ 2.567245] pci 0000:01:00.0: BAR 4: assigned [mem 0x20000000-0x20003fff 64bit pref]
[10:48:14:926] [ 2.567265] pci 0000:01:00.0: BAR 2: assigned [mem 0x20004000-0x20004fff 64bit pref]
[10:48:14:936] [ 2.567284] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[10:48:14:936] [ 2.567294] pci 0000:00:02.0: PCI bridge to [bus 01]
[10:48:14:948] [ 2.567300] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[10:48:14:948] [ 2.567308] pci 0000:00:02.0: bridge window [mem 0x20000000-0x200fffff 64bit pref]
[10:48:14:959] [ 2.567661] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[10:48:14:970] [ 2.567665] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[10:48:14:970] [ 3.663276] console [ttyS0] enabled
[10:48:14:980] [ 3.663899] Console: switching to colour frame buffer device 240x67
[10:48:14:980] [ 3.668422] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[10:48:14:991] [ 3.668758] serial-tegra 70006200.serial: RX in PIO mode
[10:48:15:002] [ 3.668858] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[10:48:15:002] [ 3.669795] [drm] Initialized
[10:48:15:012] [ 3.690519] brd: module loaded
[10:48:15:012] [ 3.704476] tegradc tegradc.0: fb registered
[10:48:15:024] [ 3.704666] loop: module loaded
[10:48:15:024] [ 3.704772] tegra_profiler: version: 1.143, samples/io: 48/28
[10:48:15:024] [ 3.707197] tegra_profiler: auth: init
[10:48:15:036] [ 3.708701] THERMAL EST: found 2 subdevs
[10:48:15:036] [ 3.708710] THERMAL EST num_resources: 0
[10:48:15:036] [ 3.708717] [THERMAL EST subdev 0]
[10:48:15:048] [ 3.708724] [THERMAL EST subdev 1]
[10:48:15:048] [ 3.709193] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[10:48:15:058] [ 3.709197] THERMAL EST: thz register success.
[10:48:15:058] [ 3.709375] THERMAL EST: end of probe, return err: 0
[10:48:15:067] [ 3.710543] sd: No Scsi addr parsed to reserve index
[10:48:15:067] [ 3.710583] hisi_sas: driver version v1.6
[10:48:15:077] [ 3.720103] tegra-qspi 70410000.spi: Prod settings list not found
[10:48:15:077] [ 3.721275] qspi_mtd spi32766.0: unrecognized JEDEC id 000000
[10:48:15:087] [ 3.724336] libphy: Fixed MDIO Bus: probed
[10:48:15:087] [ 3.725021] tun: Universal TUN/TAP device driver, 1.6
[10:48:15:098] [ 3.725023] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[10:48:15:098] [ 3.726583] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[10:48:15:108] [ 3.726587] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[10:48:15:108] [ 3.726652] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[10:48:15:119] [ 3.726654] igb: Copyright (c) 2007-2014 Intel Corporation.
[10:48:15:119] [ 3.726706] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[10:48:15:128] [ 3.726709] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[10:48:15:137] [ 3.726764] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[10:48:15:147] [ 3.726767] Copyright(c) 1999 - 2017 Intel Corporation.
[10:48:15:147] [ 3.729345] r8168 0000:01:00.0: enabling device (0000 -> 0003)
[10:48:15:156] [ 3.729382] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[10:48:15:165] [ 3.750707] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Invalid ethernet address 00:00:00:00:00:00, trying device tree node
[10:48:15:177] [ 3.750855] r8168 0000:01:00.0 (unnamed net_device) (uninitialized): Found valid ethernet address 48:b0:2d:55:9a:a5 from device tree
[10:48:15:186] [ 3.751730] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[10:48:15:194] [ 3.751789] r8168 Copyright (C) 2017 Realtek NIC software team <nicfae@realtek.com>
[10:48:15:203] [ 3.751789] This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
[10:48:15:211] [ 3.751789] This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[10:48:15:223] [ 3.752422] PPP generic driver version 2.4.2
[10:48:15:233] [ 3.752647] PPP BSD Compression module registered
[10:48:15:233] [ 3.752652] PPP Deflate Compression module registered
[10:48:15:244] [ 3.752694] PPP MPPE Compression module registered
[10:48:15:244] [ 3.752702] NET: Registered protocol family 24
[10:48:15:254] [ 3.752779] usbcore: registered new interface driver r8152
[10:48:15:254] [ 3.752830] usbcore: registered new interface driver asix
[10:48:15:265] [ 3.752894] usbcore: registered new interface driver ax88179_178a
[10:48:15:265] [ 3.752932] usbcore: registered new interface driver cdc_ether
[10:48:15:275] [ 3.752962] usbcore: registered new interface driver net1080
[10:48:15:275] [ 3.752993] usbcore: registered new interface driver cdc_subset
[10:48:15:286] [ 3.753025] usbcore: registered new interface driver zaurus
[10:48:15:286] [ 3.753083] usbcore: registered new interface driver cdc_ncm
[10:48:15:297] [ 3.753266] VFIO - User Level meta-driver version: 0.3
[10:48:15:305] [ 3.754596] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[10:48:15:305] [ 3.754620] ehci-pci: EHCI PCI platform driver
[10:48:15:313] [ 3.754667] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[10:48:15:323] [ 3.754680] ohci-pci: OHCI PCI platform driver
[10:48:15:323] [ 3.754719] ohci-platform: OHCI generic platform driver
[10:48:15:336] [ 3.757464] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[10:48:15:336] [ 3.758083] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[10:48:15:347] [ 3.759264] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f93f5400 id
[10:48:15:347] [ 3.761579] usbcore: registered new interface driver uas
[10:48:15:359] [ 3.761650] usbcore: registered new interface driver usb-storage
[10:48:15:359] [ 3.761778] usbcore: registered new interface driver usbserial
[10:48:15:369] [ 3.762204] tegra-xusb 70090000.xusb: Firmware timestamp: 2019-10-17 15:58:59 UTC, Version: 50.25 release
[10:48:15:378] [ 3.762252] tegra-xusb 70090000.xusb: xHCI Host Controller
[10:48:15:378] [ 3.762280] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[10:48:15:387] [ 3.763039] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[10:48:15:398] [ 3.763146] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[10:48:15:398] [ 3.763365] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[10:48:15:408] [ 3.763372] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[10:48:15:418] [ 3.763377] usb usb1: Product: xHCI Host Controller
[10:48:15:418] [ 3.763382] usb usb1: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[10:48:15:428] [ 3.763386] usb usb1: SerialNumber: 70090000.xusb
[10:48:15:428] [ 3.764048] hub 1-0:1.0: USB hub found
[10:48:15:437] [ 3.764169] hub 1-0:1.0: 5 ports detected
[10:48:15:437] [ 3.765040] tegra-xusb 70090000.xusb: xHCI Host Controller
[10:48:15:447] [ 3.765055] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[10:48:15:455] [ 3.765159] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[10:48:15:465] [ 3.765262] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[10:48:15:465] [ 3.765268] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[10:48:15:476] [ 3.765273] usb usb2: Product: xHCI Host Controller
[10:48:15:476] [ 3.765277] usb usb2: Manufacturer: Linux 4.9.201-tegra xhci-hcd
[10:48:15:487] [ 3.765281] usb usb2: SerialNumber: 70090000.xusb
[10:48:15:487] [ 3.765787] hub 2-0:1.0: USB hub found
[10:48:15:497] [ 3.765823] hub 2-0:1.0: 4 ports detected
[10:48:15:497] [ 3.766542] tegra-xudc-new 700d0000.xudc: device count: 1
[10:48:15:507] [ 3.766702] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[10:48:15:507] [ 3.766708] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[10:48:15:517] [ 3.768357] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[10:48:15:517] [ 3.768370] tegra-xudc-new 700d0000.xudc: vbus state: 0
[10:48:15:527] [ 3.768887] tegra-xudc-new 700d0000.xudc: entering ELPG
[10:48:15:536] [ 3.769181] tegra-xudc-new 700d0000.xudc: entering ELPG done
[10:48:15:536] [ 3.769347] mousedev: PS/2 mouse device common for all mice
[10:48:15:544] [ 3.769461] usbcore: registered new interface driver xpad
[10:48:15:544] [ 3.867269] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[10:48:15:554] [ 3.867579] usb usb2: usb_suspend_both: status 0
[10:48:15:562] [ 3.900560] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[10:48:15:571] [ 3.903057] rtc rtc1: alarm rtc device
[10:48:15:571] [ 3.903076] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[10:48:15:580] [ 3.903159] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[10:48:15:580] [ 3.903797] i2c /dev entries driver
[10:48:15:589] [ 3.905920] i2c i2c-6: Added multiplexed i2c bus 7
[10:48:15:589] [ 3.906359] i2c i2c-6: Added multiplexed i2c bus 8
[10:48:15:599] [ 3.906366] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
[10:48:15:607] [ 3.906966] imx477 7-001a: tegracam sensor driver:imx477_v2.0.6
[10:48:15:607] [ 4.091141] usb 1-2: new full-speed USB device number 2 using tegra-xusb
[10:48:15:616] [ 4.114966] usb 1-2: New USB device found, idVendor=046d, idProduct=c52b
[10:48:15:624] [ 4.114971] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[10:48:15:631] [ 4.114976] usb 1-2: Product: USB Receiver
[10:48:15:631] [ 4.114980] usb 1-2: Manufacturer: Logitech
[10:48:15:640] [ 4.208942] imx477 8-001a: tegracam sensor driver:imx477_v2.0.6
[10:48:15:649] [ 4.343562] tegradc tegradc.0: DC initialized, skipping tegra_dc_program_mode.
[10:48:15:657] [ 4.350837] tegradc tegradc.0: hdmi: tmds rate:148351K prod-setting:prod_c_hdmi_75m_150m
[10:48:15:666] [ 4.359424] tegradc tegradc.0: hdmi: get RGB quant from REG programmed by BL.
[10:48:15:674] [ 4.366582] tegradc tegradc.0: hdmi: get YCC quant from REG programmed by BL.
[10:48:15:703] [ 4.399727] extcon-disp-state extcon:disp-state: cable 47 state 1
[10:48:15:709] [ 4.405850] Extcon AUX1(HDMI) enable
[10:48:15:721] [ 4.410303] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[10:48:15:721] [ 4.416756] tegradc tegradc.1: No lt-data, using default setting
[10:48:15:730] [ 4.422807] tegradc tegradc.1: No hpd-gpio in DT
[10:48:15:739] [ 4.430686] tegradc tegradc.1: DT parsed successfully
[10:48:15:748] [ 4.443184] tegradc tegradc.1: Display dc.ffffff800d500000 registered with id=1
[10:48:15:765] [ 4.451938] tegradc tegradc.1: dpd enable lookup fail:-19
[10:48:15:773] [ 4.461691] tegradc tegradc.1: probed
[10:48:15:773] [ 4.464339] tegradc tegradc.0: nominal-pclk:148351648 parent:148350781 div:1.0 pclk:148350781 146868084~161703244
[10:48:15:782] [ 4.475852] tegradc tegradc.1: fb registered
[10:48:15:791] [ 4.483260] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[10:48:15:799] [ 4.490412] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[10:48:15:808] [ 4.498255] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[10:48:15:808] [ 4.503751] tegradc tegradc.1: blank - powerdown
[10:48:15:818] [ 4.508383] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[10:48:15:828] [ 4.509211] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x1a
[10:48:15:828] [ 4.509282] imx477 8-001a: imx477_board_setup: error during i2c read probe (-121)
[10:48:15:839] [ 4.509316] imx477 8-001a: board setup failed
[10:48:15:839] [ 4.509388] imx477: probe of 8-001a failed with error -121
[10:48:15:849] [ 4.510385] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[10:48:15:859] [ 4.512371] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[10:48:15:859] [ 4.512376] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[10:48:15:868] [ 4.512681] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[10:48:15:877] [ 4.512694] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[10:48:15:886] [ 4.512700] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[10:48:15:894] [ 4.512827] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[10:48:15:904] [ 4.512836] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[10:48:15:914] [ 4.512843] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[10:48:15:923] [ 4.512989] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[10:48:15:933] [ 4.512997] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[10:48:15:943] [ 4.513001] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[10:48:15:954] [ 4.513178] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[10:48:15:954] [ 4.513712] tegra_aotag tegra-aotag: Registering sensor 0
[10:48:15:965] [ 4.513756] tegra_aotag tegra-aotag: Invalid temp readout
[10:48:15:965] [ 4.513776] tegra_aotag tegra-aotag: Invalid temp readout
[10:48:15:976] [ 4.513792] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[10:48:15:976] [ 4.513800] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[10:48:15:986] [ 4.514568] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[10:48:15:995] [ 4.514582] tegra_dfll_action dfll-cdev-cap: Tegra DFLL 'cap cooling device' registered
[10:48:16:003] [ 4.514727] tegra_aotag tegra-aotag: Invalid temp readout
[10:48:16:003] [ 4.514749] tegra_dfll_action dfll-cdev-floor: Tegra DFLL 'floor cooling device' registered
[10:48:16:013] [ 4.518256] parse_throttle_dt_data: Num cap clks = 6
[10:48:16:021] [ 4.518260] parse_throttle_dt_data: clk=cclk_g type=2
[10:48:16:021] [ 4.518267] parse_throttle_dt_data: clk=gpu type=4
[10:48:16:033] [ 4.518287] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[10:48:16:033] [ 4.518306] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[10:48:16:044] [ 4.518329] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[10:48:16:044] [ 4.518332] parse_throttle_dt_data: clk=emc type=3
[10:48:16:054] [ 4.518632] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[10:48:16:064] [ 4.518722] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[10:48:16:074] [ 4.518832] tegra_throttle_probe: probe successful. #cdevs=4
[10:48:16:074] [ 4.519433] FAN dev name: pwm-fan
[10:48:16:085] [ 4.519473] FAN:gpio request success.
[10:48:16:085] [ 4.519523] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[10:48:16:085] [ 4.519766] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[10:48:16:098] [ 4.519879] pwm_fan_driver pwm-fan: fan tach request irq success
[10:48:16:098] [ 4.519885] pwm_fan_driver pwm-fan: tach period: 1000
[10:48:16:108] [ 4.519961] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[10:48:16:118] [ 4.519965] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[10:48:16:118] [ 4.519970] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[10:48:16:130] [ 4.519974] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[10:48:16:140] [ 4.519978] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[10:48:16:149] [ 4.519981] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[10:48:16:149] [ 4.519985] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[10:48:16:159] [ 4.519989] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[10:48:16:168] [ 4.519993] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[10:48:16:176] [ 4.519996] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[10:48:16:185] [ 4.523212] device-mapper: uevent: version 1.0.3
[10:48:16:185] [ 4.523661] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[10:48:16:195] [ 4.526357] tegra210-cpufreq cpufreq: probe()...completed
[10:48:16:206] [ 4.527061] sdhci: Secure Digital Host Controller Interface driver
[10:48:16:206] [ 4.527062] sdhci: Copyright(c) Pierre Ossman
[10:48:16:215] [ 4.527064] sdhci-pltfm: SDHCI platform and OF driver helper
[10:48:16:215] [ 4.527436] sdhci-tegra sdhci-tegra.3: Client registration for eMC Successful
[10:48:16:226] [ 4.531645] sdhci-tegra sdhci-tegra.2: Client registration for eMC Successful
[10:48:16:236] [ 4.537054] tegra-se 70012000.se: tegra_se_probe: complete
[10:48:16:236] [ 4.537683] hidraw: raw HID events driver (C) Jiri Kosina
[10:48:16:248] [ 4.543348] usbcore: registered new interface driver usbhid
[10:48:16:248] [ 4.543350] usbhid: USB HID core driver
[10:48:16:257] [ 4.548084] tegra21x_actmon 6000c800.actmon: in actmon_register()...
[10:48:16:257] [ 4.548402] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[10:48:16:267] [ 4.550254] nvpmodel: initialized successfully
[10:48:16:275] [ 4.551350] usbcore: registered new interface driver snd-usb-audio
[10:48:16:275] [ 4.551404] No Device Node present for smmu client: snd-soc-dummy !!
[10:48:16:287] [ 4.551409] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[10:48:16:297] [ 4.551428] iommu: Adding device snd-soc-dummy to group 37
[10:48:16:297] [ 4.564392] OPE platform probe
[10:48:16:307] [ 4.564470] OPE platform probe successful
[10:48:16:307] [ 4.564494] OPE platform probe
[10:48:16:307] [ 4.564576] OPE platform probe successful
[10:48:16:318] [ 4.574396] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[10:48:16:318] [ 4.575133] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA 64-bit with 64 bit addr
[10:48:16:330] [ 4.583183] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA 64-bit with 64 bit addr
[10:48:16:338] [ 4.599302] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[10:48:16:347] [ 4.599443] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[10:48:16:358] [ 4.599565] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[10:48:16:358] [ 4.599686] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[10:48:16:370] [ 4.599808] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[10:48:16:370] [ 4.599928] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[10:48:16:379] [ 4.600056] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[10:48:16:379] [ 4.600179] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[10:48:16:388] [ 4.600299] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[10:48:16:388] [ 4.600418] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[10:48:16:397] [ 4.612525] u32 classifier
[10:48:16:397] [ 4.612527] Actions configured
[10:48:16:408] [ 4.612596] Initializing XFRM netlink socket
[10:48:16:408] [ 4.613298] NET: Registered protocol family 10
[10:48:16:418] [ 4.614091] NET: Registered protocol family 17
[10:48:16:418] [ 4.614102] NET: Registered protocol family 15
[10:48:16:418] [ 4.614175] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[10:48:16:430] [ 4.614223] Bluetooth: RFCOMM socket layer initialized
[10:48:16:439] [ 4.614231] Bluetooth: RFCOMM ver 1.11
[10:48:16:447] [ 4.614235] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[10:48:16:447] [ 4.614239] Bluetooth: HIDP socket layer initialized
[10:48:16:455] [ 4.614257] 9pnet: Installing 9P2000 support
[10:48:16:455] [ 4.614292] Key type dns_resolver registered
[10:48:16:464] [ 4.614639] Registered cp15_barrier emulation handler
[10:48:16:464] [ 4.614648] Registered setend emulation handler
[10:48:16:473] [ 4.615829] registered taskstats version 1
[10:48:16:473] [ 4.616414] Adding domain ve2-pd to PM domain host1x-pd
[10:48:16:485] [ 4.616651] Adding domain ve-pd to PM domain host1x-pd
[10:48:16:485] [ 4.620155] isp 54600000.isp: initialized
[10:48:16:498] [ 4.621396] isp 54680000.isp: initialized
[10:48:16:498] [ 4.623062] mmc1: new high speed SDXC card at address 1234
[10:48:16:498] [ 4.627609] mmcblk1: mmc1:1234 SA64G 58.0 GiB
[10:48:16:508] [ 4.631001] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[10:48:16:508] [ 4.632621] mmcblk1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14
[10:48:16:517] [ 4.635577] last reset is due to software reset
[10:48:16:525] [ 4.635579] KERNEL: PMC reset status reg: 0x3
[10:48:16:525] [ 4.635644] BL: PMC reset status reg: 0x3
[10:48:16:533] [ 4.635645] BL: PMIC poweroff Event Recorder: 0x0
[10:48:16:533] [ 4.637152] clk_cbus_recalc_rate: no gbus parent
[10:48:16:542] [ 4.637156] clk_cbus_round_rate: no gbus parent
[10:48:16:542] [ 4.637158] clk_cbus_round_rate: no gbus parent
[10:48:16:551] [ 4.637165] clk_cbus_recalc_rate: no gbus parent
[10:48:16:551] [ 4.637264] clk_cbus_recalc_rate: no gbus parent
[10:48:16:561] [ 4.637266] clk_cbus_round_rate: no gbus parent
[10:48:16:561] [ 4.637268] clk_cbus_round_rate: no gbus parent
[10:48:16:571] [ 4.637270] clk_cbus_recalc_rate: no gbus parent
[10:48:16:571] [ 4.637939] tegra_dvfs: GPU-cap: registered
[10:48:16:581] [ 4.637996] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[10:48:16:581] [ 4.637998] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[10:48:16:591] [ 4.637999] tegra dvfs: vdd-gpu: nominal 1048mV, offset 708000uV, step 10000uV, scaling enabled
[10:48:16:599] [ 4.638873] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[10:48:16:607] [ 4.639384] tegra_dvfs: vdd-gpu-vts: registered
[10:48:16:607] [ 4.640072] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS 'floor cooling device' registered
[10:48:16:617] [ 4.640667] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS 'cap cooling device' registered
[10:48:16:626] [ 4.641153] input: gpio-keys as /devices/gpio-keys/input/input1
[10:48:16:635] [ 4.643056] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[10:48:16:644] [ 4.643252] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[10:48:16:644] [ 4.647440] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[10:48:16:654] [ 4.649875] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17
[10:48:16:663] [ 4.674790] tegra_rtc 7000e000.rtc: setting system clock to 2022-02-22 02:48:16 UTC (1645498096)
[10:48:16:673] [ 4.675932] vi 54080000.vi: vi_probe: ++
[10:48:16:673] [ 4.678733] vi 54080000.vi: initialized
[10:48:16:673] [ 4.680743] vi 54080000.vi: subdev nvcsi--2 bound
[10:48:16:683] [ 4.680756] vi 54080000.vi: subdev imx477 7-001a bound
[10:48:16:683] [ 4.681387] vi 54080000.vi: subdev nvcsi--1 bound
[10:48:16:693] [ 4.681617] mmcblk mmc1:1234: Card claimed for testing.
[10:48:16:693] [ 4.681626] mmcblk mmc0:0001: Card claimed for testing.
[10:48:16:702] [ 4.682212] Disable partitions left on by BL
[10:48:16:702] [ 4.682214] disb
[10:48:16:711] [ 4.682260] bwmgr: missing cdev-type property
[10:48:16:711] [ 4.682352] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[10:48:16:721] [ 4.682358] DRAM derating cdev registered.
[10:48:16:721] [ 4.683309] ALSA device list:
[10:48:16:730] [ 4.683312] #0: tegra-hda at 0x70038000 irq 83
[10:48:16:730] [ 4.683313] #1: tegra-snd-t210ref-mobile-rt565x
[10:48:17:030] [ 5.429661] Extcon DP: HPD disabled
[10:48:17:034] [ 5.429664] hpd: hpd_switch 0
[10:48:17:043] [ 5.429667] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[10:48:17:051] [ 5.429682] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[10:48:17:051] [ 5.429687] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[10:48:17:061] [ 5.429707] tegradc tegradc.0: blank - powerdown
[10:48:17:061] [ 5.474332] extcon-disp-state extcon:disp-state: cable 47 state 0
[10:48:17:072] [ 5.474333] Extcon AUX1(HDMI) disable
[10:48:17:072] [ 5.555268] tegradc tegradc.0: unblank
[10:48:17:081] [ 5.595016] tegradc tegradc.0: nominal-pclk:594000000 parent:594000000 div:1.0 pclk:594000000 588060000~647460000
[10:48:17:089] [ 5.595066] tegradc tegradc.0: hdmi: tmds rate:594000K prod-setting:prod_c_hdmi_300m_600m
[10:48:17:097] [ 5.596105] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[10:48:17:106] [ 5.663250] extcon-disp-state extcon:disp-state: cable 47 state 1
[10:48:17:106] [ 5.663252] Extcon AUX1(HDMI) enable
[10:48:17:116] [ 5.679644] tegradc tegradc.0: sync windows ret = 246
[10:48:17:116] [ 5.810490] extcon-disp-state extcon:disp-state: cable 51 state 1
[10:48:17:127] [ 5.810491] Extcon HDMI: HPD enabled
[10:48:17:127] [ 5.810503] tegradc tegradc.0: hdmi: plugged
[10:48:17:138] [ 5.827614] Freeing unused kernel memory: 8576K
[10:48:17:160] [ 5.856651] Root device found: mmcblk0p1
[10:48:17:173] [ 5.862056] Found dev node: /dev/mmcblk0p1
[10:48:17:191] [ 5.887986] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[10:48:17:209] [ 5.898172] Rootfs mounted over mmcblk0p1
[10:48:17:223] [ 5.919960] Switching from initrd to actual rootfs
[10:48:17:326] [ 6.022922] ip_tables: (C) 2000-2006 Netfilter Core Team
[10:48:17:343] [ 6.039462] cgroup: cgroup2: unknown option "nsdelegate"
[10:48:17:357] [ 6.053543] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[10:48:17:389] [ 6.075859] systemd[1]: Detected architecture arm64.
[10:48:17:410] [ 6.106379] systemd[1]: Set hostname to <astri-desktop>.
[10:48:17:492] [ 6.188013] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[10:48:17:509] [ 6.205181] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[10:48:17:618] [ 6.314540] random: systemd: uninitialized urandom read (16 bytes read)
[10:48:17:637] [ 6.321462] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[10:48:17:637] [ 6.329371] random: systemd: uninitialized urandom read (16 bytes read)
[10:48:17:645] [ 6.337749] systemd[1]: Created slice User and Session Slice.
[10:48:17:654] [ 6.343774] random: systemd: uninitialized urandom read (16 bytes read)
[10:48:17:654] [ 6.350565] systemd[1]: Reached target Swap.
[10:48:17:663] [ 6.356520] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[10:48:17:672] [ 6.367118] systemd[1]: Created slice System Slice.
[10:48:17:726] [ 6.418011] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[10:48:17:814] [ 6.505929] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[10:48:17:836] [ 6.527970] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[10:48:17:855] [ 6.542531] cpu-throttle-alert cooling device registered.
[10:48:17:866] [ 6.553029] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[10:48:17:886] [ 6.553045] gpu-throttle-alert cooling device registered.
[10:48:17:897] [ 6.553244] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[10:48:17:912] [ 6.553257] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[10:48:17:926] [ 6.553272] hot-surface-alert cooling device registered.
[10:48:19:113] [ 7.805956] using random self ethernet address
[10:48:19:133] [ 7.825924] using random host ethernet address
[10:48:19:525] [ 8.218311] random: crng init done
[10:48:19:538] [ 8.225229] random: 7 urandom warning(s) missed due to ratelimiting
[10:48:19:994] [ 8.687425] using random self ethernet address
[10:48:20:008] [ 8.695633] using random host ethernet address
thanks in advance
