Hi forum,
I’m using jetson xavier, jetpack version is 4.4.
I tried to enable imx390 camera driver on xavier to support 8 cameras. Our hardware did not use mux. (So I did not find any example to modify the dtsi) And I tried to make it as a loadable module. But it just stuck after reading the dtb I replaced, which has a error, FDT_ERR_BADSTURCTURE.
[0009.204] I> Validate kernel-dtb ...
[0009.204] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0009.207] E> digest on binary did not match!!
[0009.208] C> OEM authentication of kernel-dtb payload failed!
[0009.208] W> Failed to validate kernel-dtb binary (err=1077936152, fail=0)
[0009.209] W> Security fuse not burned, ignore validation failure
[0009.212] I> Loading ramdisk from rootfs ...
[0009.216] I> rootfs path: /sdmmc_user/boot/initrd
[0009.274] I> Kernel hdr @0xa4ac0000
[0009.275] I> Kernel dtb @0x90000000
[0009.275] I> decompressor handler not found
[0009.275] I> Copying kernel image (34334736 bytes) from 0xa4ac0000 to 0x80080000 ... [0009.285] I> Done
[0009.286] W> "bpmp" doesn't exist, creating
[0009.287] I> Updated bpmp info to DTB
[0009.287] W> "chosen" doesn't exist, creating
[0009.288] I> Ramdisk: Base: 0x91000000; Size: 0x54ecaf
[0009.288] I> Updated initrd info to DTB
[0009.290] W> WARN: Fail to override "console=none" in commandline
[0009.296] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0009.303] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0009.310] W> No valid slot number is found in scratch register
[0009.316] W> Return default slot: _a
[0009.319] I> Active slot suffix:
[0009.322] I> add_boot_slot_suffix: slot_suffix =
[0009.327] I> Linux Cmdline: video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa069c000 lut_mem=0x2008@0xa0696000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0009.355] I> Updated bootarg info to DTB
[0009.358] W> MAC addr invalid!
[0009.361] E> Failed to get WIFI MAC address
[0009.365] W> MAC addr invalid!
[0009.368] E> Failed to get Bluetooth MAC address
[0009.373] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:13:4c:69
[0009.379] W> "plugin-manager" doesn't exist, creating
[0009.384] I> Adding /chosen/plugin-manager/cvm
[0009.388] W> "chip-id" doesn't exist, creating
[0009.392] I> Adding /chosen/plugin-manager/chip-id
[0009.397] W> "configs" doesn't exist, creating
[0009.401] I> Adding /chosen/plugin-manager/configs
[0009.406] W> "ids" doesn't exist, creating
[0009.410] I> Adding /chosen/plugin-manager/ids
[0009.414] W> "odm-data" doesn't exist, creating
[0009.419] I> Adding /chosen/plugin-manager/odm-data
[0009.425] W> "memory" doesn't exist, creating
[0009.427] I> [0] START: 0x80000000, END: 0xac000000
[0009.432] I> [1] START: 0xac004000, END: 0xf09d0000
[0009.437] I> [2] START: 0xf09dc000, END: 0xf09e0000
[0009.441] I> dram_block larger than 80000000
[0009.446] I> [3] START: 0x100000000, END: 0x880000000
[0009.450] I> added [base:0x80000000, size:0x2c000000] to /memory
[0009.456] I> added [base:0xac200000, size:0x44600000] to /memory
[0009.462] I> added [base:0x100000000, size:0x780000000] to /memory
[0009.469] I> Updated memory info to DTB
[0009.472] W> "reserved-memory" doesn't exist, creating
[0009.477] W> "fb0_carveout" doesn't exist, creating
[0009.482] E> add_disp_param: failed to get display params for du=1
[0009.488] W> "reset" doesn't exist, creating
[0009.492] W> "cpus" doesn't exist, creating
[0009.496] E> Couldn't find #address-cells for /cpus
[0009.500] E> tegrabl_linuxboot_update_dtb: 0xa063e0f4 failed
[0009.506] E> Error (724238349) extracting the kernel DTB
[0009.511] E> kernel boot failed
I changed the name of the module, because I don’t want to modify the Image, but only modify dtb.
Do anyone have ideas about how to modify the dtsi?
For now, I am testing my modification based only on 2 cams. I modified my dtsi as this : tegra194-p2822-0000-camera-imx996-a00.dtsi
#include <t19x-common-modules/tegra194-camera-imx996-a00.dtsi>
#include "dt-bindings/clock/tegra194-clock.h"
#define CAM0_RST_L TEGRA194_MAIN_GPIO(H, 3)
#define CAM0_PWDN TEGRA194_MAIN_GPIO(H, 6)
#define CAM1_RST_L TEGRA194_MAIN_GPIO(T, 6)
#define CAM1_PWDN TEGRA194_MAIN_GPIO(T, 5)
i2c@3180000 {
imx996_a@41 {
def-addr = <0x1a>;
clocks = <&bpmp_clks TEGRA194_CLK_EXTPERIPH1>,
<&bpmp_clks TEGRA194_CLK_EXTPERIPH1>;
clock-names = "extperiph1", "pllp_grtba";
mclk = "extperiph1";
reset-gpios = <&tegra_main_gpio CAM0_RST_L GPIO_ACTIVE_HIGH>;
pwdn-gpios = <&tegra_main_gpio CAM0_PWDN GPIO_ACTIVE_HIGH>;
vana-supply = <&p2822_avdd_cam_2v8>;
vif-supply = <&p2822_vdd_1v8_cvb>;
imx996_b@42 {
def-addr = <0x1a>;
and the tegra194-camera-imx996-a00.dtsi
host1x {
vi@15c10000 {
num-channels = <2>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
imx996_vi_in0: endpoint {
vc-id = <0>;
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&imx996_csi_out0>;
port@1 {
reg = <1>;
imx996_vi_in1: endpoint {
vc-id = <1>;
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&imx996_csi_out1>;
nvcsi@15a00000 {
num-channels = <2>;
#size-cells = <0>;
channel@0 {
reg = <0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
imx996_csi_in0: endpoint@0 {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&imx996_imx996_out0>;
port@1 {
reg = <1>;
imx996_csi_out0: endpoint@1 {
remote-endpoint = <&imx996_vi_in0>;
channel@1 {
reg = <1>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
imx996_csi_in1: endpoint@2 {
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&imx996_imx996_out1>;
port@1 {
reg = <1>;
imx996_csi_out1: endpoint@3 {
remote-endpoint = <&imx996_vi_in1>;
i2c@3180000 {
imx996_a@41 {
compatible = "nvidia,imx996";
/* I2C device address */
reg = <0x41>;
/* V4L2 device node location */
devnode = "video0";
/* Physical dimensions of sensor */
physical_w = "3.674";
physical_h = "2.738";
sensor_model = "imx390";
delayed_gain = "true";
mode0 { // imx996_MODE_1920X1080
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
vc_id = "0";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
dynamic_pixel_bit_depth = "12";
csi_pixel_bit_depth = "12";
mode_type = "bayer";
pixel_phase = "rggb";
active_w = "1936";
active_h = "1100";
readout_orientation = "0";
line_length = "2200";
inherent_gain = "1";
mclk_multiplier = "25";
pix_clk_hz = "74250000";
serdes_pix_clk_hz = "833333333";
gain_factor = "10";
min_gain_val = "0"; /* dB */
max_gain_val = "300"; /* dB */
step_gain_val = "3"; /* 0.3 */
default_gain = "0";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "30000000";
max_framerate = "30000000";
step_framerate = "1";
default_framerate = "30000000";
exposure_factor = "1000000";
min_exp_time = "10"; /*us, 2 lines*/
max_exp_time = "33333";
step_exp_time = "1";
default_exp_time = "33333";/* us */
embedded_metadata_height = "1";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
imx996_imx996_out0: endpoint {
vc-id = <0>;
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&imx996_csi_in0>;
imx996_b@42 {
reg = <0x42>;
devnode = "video1";
mclk_khz = "24000";
num_lanes = "4";
phy_mode = "DPHY";
vc_id = "1";
active_w = "1936";
active_h = "1100";
gain_factor = "10";
default_gain = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
imx996_imx996_out1: endpoint {
vc-id = <1>;
port-index = <0>;
bus-width = <4>;
remote-endpoint = <&imx996_csi_in1>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
num_csi_lanes = <4>;
max_lane_speed = <2000000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <750000>;
isp_peak_byte_per_pixel = <5>;
isp_bw_margin_pct = <25>;
modules {
module0 {
badge = "imx996_rear_liimx996";
position = "rear";
orientation = "1";
drivernode0 {
/* Declare PCL support driver (classically known as guid) */
pcl_id = "v4l2_sensor";
/* Driver v4l2 device name */
devname = "imx996 2-0041";
/* Declare the device-tree hierarchy to driver instance */
proc-device-tree = "/proc/device-tree/i2c@3180000/imx996_a@41";
module2 {
badge = "imx996_topright_liimx996";
position = "topright";
orientation = "1";
drivernode0 {
devname = "imx996 2-0043";
proc-device-tree = "/proc/device-tree/i2c@3180000/imx996_c@43";
