Can not connect Camera.
Please advise
nvidia@tegra-ubuntu:~$ lsusb
Bus 002 Device 002: ID 05e3:0612 Genesys Logic, Inc.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 046d:0826 Logitech, Inc. HD Webcam C525
Bus 001 Device 004: ID 04ca:008a Lite-On Technology Corp.
Bus 001 Device 003: ID 046d:c31c Logitech, Inc. Keyboard K120
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
nvidia@tegra-ubuntu:~$ v4l2-ctl -d /dev/video0 --all
Driver Info (not using libv4l2):
Driver name : tegra-video
Card type : vi-output, ov5693 2-0036
Bus info : platform:15700000.vi:2
Driver version: 4.4.15
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
It shown Driver name : tegra-video not Logitech, Inc. HD Webcam C525
Please advise
Apichat
nvidia@tegra-ubuntu:~$ gst-launch-1.0 v4l2src device=/dev/video1 ! video/x-raw, width=1280, height=720 ! xvimagesink
It work when i run above.How can i use web-camera directly such as cheese Webcam Booth.
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 2: no power)
Format Video Capture:
Width/Height : 2592/1944
Pixel Format : ‘RG10’
Field : None
Bytes per Line : 5376
Size Image : 10450944
Colorspace : sRGB
Transfer Function : Default
YCbCr Encoding : Default
Quantization : Default
Flags :
nvidia@tegra-ubuntu:~$ v4l2-ctl -d /dev/video1 --all
Driver name : uvcvideo
Card type : HD Webcam C525
Bus info : usb-3530000.xhci-2.4
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 1: ok)
Width/Height : 640/480
Pixel Format : ‘YUYV’
Field : None
Bytes per Line : 1280
Size Image : 614400
Colorspace : sRGB
Flags :
Can i change /dev/device1 to /dev/device1? How?
The video_register_device is the function to register as videox, You can try to modify the kernel/drivers/media/platform/tegra/camera/channel.c to try. -1 means auto
For how to build apply kernel you can search in this forum to find it.
ret = video_register_device(&chan->video, VFL_TYPE_GRABBER, -1);
	if (ret < 0) {
		dev_err(&chan->video.dev, "failed to register video device\n");
		goto video_register_error;
