Can not drive GPIO10 LOW on XAVIER
We have a custom board in which AGX XAVIER module is used. When we drive GPIO10 pin low with the below commands, voltage level at that pin becomes 2.5Volts. If we drive logic-1 then it becomes 3.0 Volts.
echo 315 > /sys/class/gpio/export
echo 0 > /sys/class/gpio/PBB.02/value
cat /sys/class/gpio/PBB.02/value
Note that we can change the logic level of other pins(i.e. PBB.01) properly with these commands.
What can be the reason of this problem?
Best Regards,
Seyit
Have you checked the pinmux state?
