log.txt (96.2 KB)
[ 665.2320 ] Coldbooting the device
[ 665.2325 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 665.2328 ] MB2 version 01.00.0000
[ 665.6181 ] Coldbooting the device
[ 665.6185 ] tegrarcm_v2 --chip 0x23 0 --reboot coldboot
[ 665.6188 ] MB2 version 01.00.0000
*** The target generic has been flashed successfully. ***
Reset the board to boot from internal eMMC.
The system cannot start properly as the video shows!!!! After a few minutes, the system turns black screen
feel shy
What does it mean?
feel shy
What does it mean
Please dump the log like this so we know what’s going on:
log.txt (124.7 KB)
This is log from Serial port
Is this a DevKit or a custom carrier board?
Do you have any peripherals like cameras plugged in?
This is a DevKit.It have not any peripherals.
Is this a hardware problem?
Jetson UEFI firmware (version 36.3.0-gcid-36191598 built on 2024-05-06T16:58:)
��ERROR: camera-ip/isp5/isp5.c:2031 [isp5_pm_init] "ERROR: Failed to turn isp1 "
BUG: core/init/init.c:86 [init_all] "*** FIRMWARE INIT FAILED AT LEVEL 95 ***"
This error should not happen on a DevKit.
Can you please check if the situation is similar to this post?
Can you say what caused it?
How do I modify this error?
The actual issue comes here:
FATAL ERROR [FILE=platform/drivers/emc/drv/emc-init-train.c, ERR_UID=2954]: EMC5
This is related to DRAM initialization, so it may be hardware defect.
Can you please try if you are able to flash this device with JetPack 5?
system
Closed
16
