I’m unable to flash the Jetson TX2 NX despite following several steps on the forum. So far, I’ve:
- Bought a new hard drive to install Ubuntu 18 with SDK manager, this took some time
- Bought a new USB cable in case it was the USB cable
This is a vanilla install and I am able to successfully flash my Jetson Xavier NX module so it seems to be that specific card. Any suggestions would be appreciated.
Here’s the error message I’m seeing:
09:28:22 INFO: command finished successfully
09:28:22 DEBUG: Flash Jetson TX2 - flash: using adapter to install NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP@JETSON_TX2_TARGETS to /home/nile/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS
09:28:22 INFO: Flash Jetson TX2 - flash: Installing component ‘Flash Jetson TX2’ (NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP)
09:28:22 INFO: Flash Jetson TX2 - flash: exec_command: /tmp/tmp_NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP.sh
09:28:22 INFO: Flash Jetson TX2 - flash: sudo ./nvautoflash.sh
09:28:22 INFO: Flash Jetson TX2 - flash: *** Checking ONLINE mode … OK.
09:28:22 INFO: Multimedia API - target: Found file /home/nile/Downloads/nvidia/sdkm_downloads/nvidia-l4t-jetson-multimedia-api_32.6.1-20210726122859_arm64.deb with correct checksum, skip downloading.
09:28:22 INFO: NVIDIA Nsight Systems - target: Found file /home/nile/Downloads/nvidia/sdkm_downloads/nsight-systems-cli-2021.2.3_2021.2.3.8-1_arm64.deb with correct checksum, skip downloading.
09:28:22 INFO: Flash Jetson TX2 - flash: *** Checking target board connection … 1 connections found.
09:28:23 INFO: TensorRT on Target - target: Found file /home/nile/Downloads/nvidia/sdkm_downloads/libnvinfer-samples_8.0.1-1+cuda10.2_all.deb with correct checksum, skip downloading.
09:28:23 INFO: Flash Jetson TX2 - flash: *** Reading ECID … FUSELEVEL=fuselevel_production hwchipid=0x18 bootauth=NS
09:28:23 INFO: Flash Jetson TX2 - flash: *** Reading EEPROM … “/home/nile/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py” --chip 0x18 --applet “/home/nile/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin” --skipuid --cmd “dump eeprom boardinfo cvm.bin; dump eeprom baseinfo bbd.bin; reboot recovery”
09:28:23 INFO: CUDA Toolkit for L4T - target: Found file /home/nile/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-10-2-local_10.2.460-1_arm64.deb with correct checksum, skip downloading.
09:28:23 INFO: Flash Jetson TX2 - flash: [ 0.0247 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/nile/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
09:28:23 INFO: Flash Jetson TX2 - flash: [ 0.0428 ] Assuming zero filled SBK key
09:28:23 INFO: Flash Jetson TX2 - flash: [ 0.0911 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
09:28:24 INFO: Flash Jetson TX2 - flash: [ 0.0983 ] RCM version 0X180001
09:28:26 INFO: Flash Jetson TX2 - flash: [ 2.4684 ] tegrarcm_v2 --isapplet
09:28:27 INFO: Flash Jetson TX2 - flash: [ 2.8351 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/nile/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
09:28:27 INFO: Flash Jetson TX2 - flash: [ 2.8371 ] Applet version 01.00.0000
09:28:27 INFO: Flash Jetson TX2 - flash: [ 3.2877 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/nile/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
09:28:27 INFO: Flash Jetson TX2 - flash: [ 3.2896 ] RCM 0 is saved as rcm_0.rcm
09:28:27 INFO: Flash Jetson TX2 - flash: [ 3.2946 ] Assuming zero filled SBK key
09:28:27 INFO: Flash Jetson TX2 - flash: [ 3.3132 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
09:28:32 INFO: Flash Jetson TX2 - flash: [ 3.3192 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml
09:28:34 INFO: Flash Jetson TX2 - flash: [ 9.8002 ] tegrarcm_v2 --isapplet
09:28:34 INFO: Flash Jetson TX2 - flash: [ 10.5424 ] tegrarcm_v2 --oem platformdetails eeprom cvb /home/nile/nvidia/nvidia_sdk/JetPack_4.6_Linux_JETSON_TX2_TARGETS/Linux_for_Tegra/bootloader/bbd.bin
09:28:34 INFO: Flash Jetson TX2 - flash: [ 10.5441 ] Applet version 01.00.0000
09:28:35 INFO: Flash Jetson TX2 - flash: UnicodeDecodeError: ‘utf-8’ codec can’t decode byte 0xa4 in position 16: invalid start byte
09:28:35 INFO: Flash Jetson TX2 - flash: [ Component Install Finished with Error ]
09:28:35 ERROR: Flash Jetson TX2 - flash: command terminated with error
09:28:35 SUMMARY: DateTime Target Setup - target: Depends on failed component
