After I modified the DTS to enable USB3_1 and ODMDATA bit 1 set to 1 and flash the image.
The USB hub connect to PEX_RFU can work.
But when I try flash DTB or kernel or whole image again will stack at “CPU Bootloader is not running on device.”
If I disconnect USB hub power suppy to disable the hub then can flash successfully.
These are the fail log.
nvidia@nvidia-X299-UD4:~/jetpack/jetpack_download/Linux_for_Tegra$ sudo ./flash.sh -r -k kernel jetson-tx2 mmcblk0p1
./tegraflash.py --chip 0x18 --applet "/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin" --cmd "dump eeprom boardinfo cvm.bin" --skipuid
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0018 ] Generating RCM messages
[ 0.0041 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm /home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0057 ] RCM 0 is saved as rcm_0.rcm
[ 0.0061 ] RCM 1 is saved as rcm_1.rcm
[ 0.0061 ] List of rcm files are saved in rcm_list.xml
[ 0.0061 ]
[ 0.0062 ] Signing RCM messages
[ 0.0099 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0116 ] Assuming zero filled SBK key
[ 0.0179 ]
[ 0.0180 ] Copying signature to RCM mesages
[ 0.0195 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.0217 ]
[ 0.0218 ] Boot Rom communication
[ 0.0239 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml --skipuid
[ 0.0255 ] RCM version 0X180001
[ 0.0270 ] Boot Rom communication completed
[ 1.0338 ]
[ 1.0359 ] tegrarcm_v2 --isapplet
[ 1.0377 ] Applet version 01.00.0000
[ 1.0502 ]
[ 1.0522 ] Retrieving EEPROM data
[ 1.0524 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/cvm.bin
[ 1.0541 ] Applet version 01.00.0000
[ 1.0786 ] Saved platform info in /home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/cvm.bin
[ 1.1565 ]
Board ID(3310) version(B02)
odmdata 0x7090000
PMIC_CONFIG tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg
copying bctfile(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/t186ref/BCT/P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg)... done.
copying misc_config(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)... done.
copying pinmux_config(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg)... done.
copying pmic_config(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg)... done.
copying pmc_config(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg)... done.
copying prod_config(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg)... done.
copying scr_config(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/t186ref/BCT/minimal_scr.cfg)... done.
copying scr_cold_boot_config(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)... done.
copying bootrom_config(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg)... done.
copying dev_params(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)... done.
Existing bootloader(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating extlinux.conf.emmc to rootfs... done.
populating /home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb to rootfs... done.
done.
Making Boot image... done.
Existing sosfile(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/t186ref/nvtboot.bin)... done.
Existing mb2blfile(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/t186ref/tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb)... done.
Existing scefile(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/camera-rtcpu-sce.bin) reused.
Existing spefile(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/spe.bin) reused.
copying wb0boot(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)... done.
Existing tosfile(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/tos.img) reused.
Existing eksfile(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)... done.
Reusing existing system.img...
done.
Existing tbcfile(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/cboot.bin) reused.
copying tbcdtbfile(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/kernel/dtb/tegra186-quill-p3310-1000-c03-00-base.dtb)... done.
copying cfgfile(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml... done.
Existing flasher(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/tegraflash.py) reused.
*** Updating :kernel with boot.img ***
./flash.sh: line 1617: [: -eq: unary operator expected
./tegraflash.py --bl nvtboot_recovery_cpu.bin --chip 0x18 --applet mb1_recovery_prod.bin --sdram_config P3310_A00_8GB_Samsung_8GB_lpddr4_204Mhz_A02_l4t.cfg --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-quill-p3310-1000-c03.cfg --pmic_config tegra186-mb1-bct-pmic-quill-p3310-1000-c04.cfg --pmc_config tegra186-mb1-bct-pad-quill-p3310-1000-c03.cfg --prod_config tegra186-mb1-bct-prod-quill-p3310-1000-c03.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-quill-p3310-1000-c03.cfg --dev_params emmc.cfg --cfg flash.xml --bins "mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb; tlk tos.img; eks eks.img; bootloader_dtb tegra186-quill-p3310-1000-c03-00-base.dtb" --cmd "write kernel-dtb tegra186-quill-p3310-1000-c03-00-base.dtb; write kernel boot.img;"
version 1.0.0
[ 0.0061 ] Generating RCM messages
[ 0.0074 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0089 ] RCM 0 is saved as rcm_0.rcm
[ 0.0092 ] RCM 1 is saved as rcm_1.rcm
[ 0.0093 ] List of rcm files are saved in rcm_list.xml
[ 0.0094 ]
[ 0.0094 ] Signing RCM messages
[ 0.0141 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0155 ] Assuming zero filled SBK key
[ 0.0216 ]
[ 0.0219 ] Copying signature to RCM mesages
[ 0.0231 ] tegrarcm_v2 --chip 0x18 --updatesig rcm_list_signed.xml
[ 0.0247 ]
[ 0.0248 ] Boot Rom communication
[ 0.0261 ] tegrarcm_v2 --chip 0x18 --rcm rcm_list_signed.xml
[ 0.0274 ] BootRom is not running
[ 1.0263 ]
[ 1.0283 ] tegrarcm_v2 --isapplet
[ 1.0301 ] Applet version 01.00.0000
[ 1.0449 ]
[ 1.0469 ] tegrasign_v2 --key None --getmode mode.txt
[ 1.0486 ] Assuming zero filled SBK key
[ 1.0488 ]
[ 1.0488 ] Parsing partition layout
[ 1.0508 ] tegraparser_v2 --pt flash.xml.tmp
[ 1.0530 ]
[ 1.0531 ] Creating list of images to be signed
[ 1.0551 ] tegrahost_v2 --chip 0x18 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 1.0683 ]
[ 1.0684 ] Generating signatures
[ 1.0704 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 1.0720 ] Assuming zero filled SBK key
[ 1.1597 ]
[ 1.1598 ] Reading BCT from device for further operations
[ 1.1599 ] Generating blob
[ 1.1615 ] tegrahost_v2 --align blob_nvtboot_recovery_cpu.bin
[ 1.1632 ]
[ 1.1645 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery_cpu.bin zerosbk
[ 1.1660 ]
[ 1.1675 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_cpu_sigheader.bin_list.xml
[ 1.1687 ] Assuming zero filled SBK key
[ 1.1724 ]
[ 1.1745 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_cpu_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_sigheader.bin.hash zerosbk
[ 1.1762 ]
[ 1.1779 ] tegrahost_v2 --align blob_nvtboot_recovery.bin
[ 1.1792 ]
[ 1.1805 ] tegrahost_v2 --appendsigheader blob_nvtboot_recovery.bin zerosbk
[ 1.1823 ]
[ 1.1838 ] tegrasign_v2 --key None --list blob_nvtboot_recovery_sigheader.bin_list.xml
[ 1.1851 ] Assuming zero filled SBK key
[ 1.1892 ]
[ 1.1910 ] tegrahost_v2 --updatesigheader blob_nvtboot_recovery_sigheader.bin.encrypt blob_nvtboot_recovery_sigheader.bin.hash zerosbk
[ 1.1926 ]
[ 1.1945 ] tegrahost_v2 --align blob_preboot_d15_prod_cr.bin
[ 1.1960 ]
[ 1.1975 ] tegrahost_v2 --appendsigheader blob_preboot_d15_prod_cr.bin zerosbk
[ 1.1993 ]
[ 1.2010 ] tegrasign_v2 --key None --list blob_preboot_d15_prod_cr_sigheader.bin_list.xml
[ 1.2024 ] Assuming zero filled SBK key
[ 1.2055 ]
[ 1.2074 ] tegrahost_v2 --updatesigheader blob_preboot_d15_prod_cr_sigheader.bin.encrypt blob_preboot_d15_prod_cr_sigheader.bin.hash zerosbk
[ 1.2090 ]
[ 1.2107 ] tegrahost_v2 --align blob_mce_mts_d15_prod_cr.bin
[ 1.2122 ]
[ 1.2136 ] tegrahost_v2 --appendsigheader blob_mce_mts_d15_prod_cr.bin zerosbk
[ 1.2201 ]
[ 1.2221 ] tegrasign_v2 --key None --list blob_mce_mts_d15_prod_cr_sigheader.bin_list.xml
[ 1.2235 ] Assuming zero filled SBK key
[ 1.2745 ]
[ 1.2765 ] tegrahost_v2 --updatesigheader blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt blob_mce_mts_d15_prod_cr_sigheader.bin.hash zerosbk
[ 1.2818 ]
[ 1.2834 ] tegrahost_v2 --align blob_bpmp.bin
[ 1.2848 ]
[ 1.2863 ] tegrahost_v2 --appendsigheader blob_bpmp.bin zerosbk
[ 1.2889 ]
[ 1.2906 ] tegrasign_v2 --key None --list blob_bpmp_sigheader.bin_list.xml
[ 1.2919 ] Assuming zero filled SBK key
[ 1.3148 ]
[ 1.3162 ] tegrahost_v2 --updatesigheader blob_bpmp_sigheader.bin.encrypt blob_bpmp_sigheader.bin.hash zerosbk
[ 1.3189 ]
[ 1.3200 ] tegrahost_v2 --align blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb
[ 1.3211 ]
[ 1.3221 ] tegrahost_v2 --appendsigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2.dtb zerosbk
[ 1.3239 ]
[ 1.3251 ] tegrasign_v2 --key None --list blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb_list.xml
[ 1.3262 ] Assuming zero filled SBK key
[ 1.3463 ]
[ 1.3484 ] tegrahost_v2 --updatesigheader blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.hash zerosbk
[ 1.3510 ]
[ 1.3526 ] tegrahost_v2 --align blob_tos.img
[ 1.3541 ]
[ 1.3556 ] tegrahost_v2 --appendsigheader blob_tos.img zerosbk
[ 1.3572 ]
[ 1.3591 ] tegrasign_v2 --key None --list blob_tos_sigheader.img_list.xml
[ 1.3603 ] Assuming zero filled SBK key
[ 1.3633 ]
[ 1.3654 ] tegrahost_v2 --updatesigheader blob_tos_sigheader.img.encrypt blob_tos_sigheader.img.hash zerosbk
[ 1.3674 ]
[ 1.3690 ] tegrahost_v2 --align blob_eks.img
[ 1.3711 ]
[ 1.3725 ] tegrahost_v2 --appendsigheader blob_eks.img zerosbk
[ 1.3742 ]
[ 1.3759 ] tegrasign_v2 --key None --list blob_eks_sigheader.img_list.xml
[ 1.3773 ] Assuming zero filled SBK key
[ 1.3775 ]
[ 1.3797 ] tegrahost_v2 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[ 1.3813 ]
[ 1.3831 ] tegrahost_v2 --align blob_tegra186-quill-p3310-1000-c03-00-base.dtb
[ 1.3846 ]
[ 1.3862 ] tegrahost_v2 --appendsigheader blob_tegra186-quill-p3310-1000-c03-00-base.dtb zerosbk
[ 1.3884 ]
[ 1.3903 ] tegrasign_v2 --key None --list blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb_list.xml
[ 1.3918 ] Assuming zero filled SBK key
[ 1.4055 ]
[ 1.4076 ] tegrahost_v2 --updatesigheader blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.hash zerosbk
[ 1.4103 ]
[ 1.4122 ] tegrahost_v2 --generateblob blob.xml blob.bin
[ 1.4138 ] number of images in blob are 9
[ 1.4143 ] blobsize is 3736856
[ 1.4144 ] Added binary blob_nvtboot_recovery_cpu_sigheader.bin.encrypt of size 184576
[ 1.4167 ] Added binary blob_nvtboot_recovery_sigheader.bin.encrypt of size 78080
[ 1.4172 ] Added binary blob_preboot_d15_prod_cr_sigheader.bin.encrypt of size 61472
[ 1.4179 ] Added binary blob_mce_mts_d15_prod_cr_sigheader.bin.encrypt of size 2077088
[ 1.4189 ] Added binary blob_bpmp_sigheader.bin.encrypt of size 528800
[ 1.4195 ] Added binary blob_tegra186-a02-bpmp-quill-p3310-1000-c04-00-te770d-ucm2_sigheader.dtb.encrypt of size 466160
[ 1.4203 ] Added binary blob_tos_sigheader.img.encrypt of size 58880
[ 1.4207 ] Added binary blob_eks_sigheader.img.encrypt of size 1488
[ 1.4211 ] Added binary blob_tegra186-quill-p3310-1000-c03-00-base_sigheader.dtb.encrypt of size 280160
[ 1.4234 ]
[ 1.4235 ] Sending bootloader and pre-requisite binaries
[ 1.4250 ] tegrarcm_v2 --download blob blob.bin
[ 1.4267 ] Applet version 01.00.0000
[ 1.4406 ] Sending blob
[ 1.4407 ] [................................................] 100%
[ 2.2506 ]
[ 2.2527 ] tegrarcm_v2 --boot recovery
[ 2.2545 ] Applet version 01.00.0000
[ 2.2699 ]
[ 2.2723 ] tegrarcm_v2 --isapplet
[ 2.8998 ]
[ 2.9018 ] tegradevflash_v2 --iscpubl
[ 2.9035 ] CPU Bootloader is not running on device.
[ 2.9041 ]
[ 33.4997 ] Writing partition
[ 33.5016 ] tegradevflash_v2 --write kernel-dtb /home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/tegra186-quill-p3310-1000-c03-00-base.dtb
[ 33.5033 ] Cannot Open USB
[ 33.5037 ]
Error: Return value 8
Command tegradevflash_v2 --write kernel-dtb /home/nvidia/jetpack/jetpack_download/Linux_for_Tegra/bootloader/tegra186-quill-p3310-1000-c03-00-base.dtb
Failed to flash/read t186ref.
