Can not get the right printf of tid
I’m testing long long numbers before adding more code, the kernel should print the last tid based on the grid and blocks dimension, but I can not get the right results. Dim3 grid(2147483647,1,1) and dim3 blocks(1024,1,1), so I should get the last tid, based on 1D grid and 1D blocks, as (2147483647 * 1024) - 1, but it does not go further then 4294967295 (tid > 4294967294) (found out by trial and errors). What am I doing wrong?
// System includes
#include <stdio.h>
#include <stdlib.h> // For exit()
#include <string.h>
#include <math.h>
#include <ctype.h>
//#include <inttypes.h>
//#include <stdint.h>
// CUDA runtime
#include <cuda_runtime.h>
// helper functions and utilities to work with CUDA
#include <helper_functions.h>
#include <helper_cuda.h>
// Kernel definition
// Run on GPU
__global__ void add() {
	// 1D grid of 1D blocks
	unsigned long long tid = blockIdx.x * blockDim.x + threadIdx.x;
	if (tid == 2199023254527)
	  printf("%lld \n",tid);
int main(void) {
        dim3 grid(2147483647, 1, 1);
        dim3 blocks(1024, 1, 1);
        // Launch add() kernel on GPU
        add<<<grid,blocks>>>();
	getLastCudaError("Kernel execution failed");
	checkCudaErrors( cudaPeekAtLastError() );
	checkCudaErrors( cudaDeviceSynchronize() );
        return 0;
threadIdx.x, blockDim.x, and blockIdx.x are unsigned 4-byte quantities.
If you combine them like this:
You will end up with an unsigned 4-byte quantity.
You need to do something like this:
unsigned long long tid = (size_t)blockIdx.x * blockDim.x + threadIdx.x;
Thanks, is that the wrong way to combine them?
if yes, is there any other way?
Also I know that the maximum number of threads in the block is limited to 1024, is it right to have:
dim3 grid(2147483647,65535,65535) and dim3 blocks(1024,1,1)?
I already indicated another way to combine them.
I believe that should be “legal”. It will take very long to execute. And by very long I mean something like 1000 years to execute. Furthermore, the product of the block dimension quantities may no longer fit in a unsigned long long in that case, depending on how you combine or use them.
Yes, sorry I saw that, I thought that there was another way other than size_t.
