Can not load USD when Isaac Sim 4.0 headless mode
I am trying to use Isaac Sim 4.0 with headless mode.
The specified USD file is not loaded when I launch Isaac Sim with the following script.
the USD file is loaded when I set SimulationApp({“headless”: False}).
Why is the USD file not loaded when in headless mode?
import sys
import time
import signal
from omni.isaac.kit import SimulationApp
real_frame_per_second = 0.0
internal_frame_per_second = 60.0
time_steps_per_second = 360
kit = None
is_processing = False
def scheduler(signum, frame):
    global kit
    global is_processing
    if is_processing == False:
        is_processing = True
        kit.update()
def main():
    global kit
    args = sys.argv
    usd_path = args[1]
    if len(args) >= 3:
        internal_frame_per_second = float(args[2])
    if len(args) >= 4:
        time_steps_per_second = float(args[3])
    if len(args) >= 5:
        real_frame_per_second = float(args[4])
    else:
        real_frame_per_second = internal_frame_per_second
    # URDF import, configuration and simulation sample
    kit = SimulationApp({"renderer": "RayTracedLighting", "headless": True, "hide_ui": False, "open_usd": usd_path})
    #kit = SimulationApp({"renderer": "RayTracedLighting", "headless": False, "open_usd": usd_path})
    import omni
    from omni.isaac.core.utils.extensions import enable_extension, disable_extension
    from omni.isaac.core import SimulationContext, World
    enable_extension("omni.isaac.ros2_bridge")
    kit.update()
    enable_extension("omni.isaac.repl")
    kit.update()
    enable_extension("omni.isaac.sim.headless.native")
    my_world = World(stage_units_in_meters = 1.0, physics_dt = 1.0 / internal_frame_per_second, rendering_dt = 1.0 / internal_frame_per_second)
    import omni.kit.commands
    from pxr import Sdf, Gf, UsdPhysics, PhysxSchema
    # Get stage handle
    stage_handle = omni.usd.get_context().get_stage()
    # Enable physics
    scene = UsdPhysics.Scene.Define(stage_handle, Sdf.Path("/physicsScene"))
    # Set gravity
    scene.CreateGravityDirectionAttr().Set(Gf.Vec3f(0.0, 0.0, -1.0))
    scene.CreateGravityMagnitudeAttr().Set(9.81)
    # Set solver settings
    PhysxSchema.PhysxSceneAPI.Apply(stage_handle.GetPrimAtPath("/physicsScene"))
    physxSceneAPI = PhysxSchema.PhysxSceneAPI.Get(stage_handle, "/physicsScene")
    physxSceneAPI.CreateEnableCCDAttr(True)
    physxSceneAPI.CreateEnableStabilizationAttr(True)
    physxSceneAPI.CreateEnableGPUDynamicsAttr(False)
    physxSceneAPI.CreateBroadphaseTypeAttr("MBP")
    # Refer to https://forums.developer.nvidia.com/t/wheeled-robot-incorrect-behavior/245133
    #physxSceneAPI.CreateSolverTypeAttr("TGS")
    physxSceneAPI.CreateSolverTypeAttr("PGS")
    physxSceneAPI.CreateTimeStepsPerSecondAttr(time_steps_per_second)
    # Start simulation
    #omni.timeline.get_timeline_interface().play()
    signal.signal(signal.SIGALRM, scheduler)
    signal.setitimer(signal.ITIMER_REAL, 1/real_frame_per_second, 1/real_frame_per_second)
    try:
        while True:
            time.sleep(1)
    except KeyboardInterrupt:
        # Shutdown and exit
        omni.timeline.get_timeline_interface().stop()
        kit.close()
if __name__ == '__main__':
    main()
