• Hardware Platform (Jetson / GPU) : GPU
• DeepStream Version :6.3
• NVIDIA GPU Driver Version (valid for GPU only) : 525.125.06
• Issue Type( questions, new requirements, bugs) : Question
I am following the documentation as provided in:
When i followed the steps, i had an error at the make step in below script:
cd deepstream_python_apps/bindings
mkdir build
cd build
cmake …
make -j$(nproc) **
The error is
Scanning dependencies of target pyds [ 6%] Building CXX object CMakeFiles/pyds.dir/src/bindtrackermeta.cpp.o [ 31%] Building CXX object CMakeFiles/pyds.dir/src/bindanalyticsmeta.cpp.o [ 43%] Building CXX object CMakeFiles/pyds.dir/src/custom_binding/bindcustom.cpp.o [ 43%] Building CXX object CMakeFiles/pyds.dir/src/pyds.cpp.o [ 43%] Building CXX object CMakeFiles/pyds.dir/src/bindfunctions.cpp.o [ 43%] Building CXX object CMakeFiles/pyds.dir/src/bindgstnvdsmeta.cpp.o [ 50%] Building CXX object CMakeFiles/pyds.dir/src/bindmeta360.cpp.o [ 37%] Building CXX object CMakeFiles/pyds.dir/src/utils.cpp.o [ 56%] Building CXX object CMakeFiles/pyds.dir/src/bindnvbufsurface.cpp.o [ 62%] Building CXX object CMakeFiles/pyds.dir/src/bindnvdsmeta.cpp.o [ 68%] Building CXX object CMakeFiles/pyds.dir/src/bindnvosd.cpp.o [ 75%] Building CXX object CMakeFiles/pyds.dir/src/bindopticalflow.cpp.o [ 81%] Building CXX object CMakeFiles/pyds.dir/src/bindschema.cpp.o [ 87%] Building CXX object CMakeFiles/pyds.dir/src/bindnvdsinfer.cpp.o In file included from /opt/nvidia/deepstream/deepstream-6.3/sources/deepstream_python_apps/bindings/src/utils.cpp:26: /opt/nvidia/deepstream/deepstream/sources/includes/gstnvdsmeta.h:43:10: fatal error: gst/video/video.h: No such file or directory 43 | #include <gst/video/video.h> | ^~~~~~~~~~~~~~~~~~~ compilation terminated.
When i tried to search the issue in platform i found this step Unable to run deepstream_python _apps deepstream_test_1.py (and others...) - #8 by Amycao
But this solution couldnt help as well.
I didnt encounter this problem with Deepstream version 6.2 but has this issue in 6.3. I need version 6.3 because i need to use my custom onnx model for deepsort tracker.
Can you please help me on this?? It’s a little urgent! Sorry for the inconvenience.
Regards
