Can Not Operate With Two Cameras
Hello everyone,
I have two IMX678s connected to my Xavier NX. I have configured the dtsi as follows:
#define CAM0_PWDN	TEGRA194_MAIN_GPIO(Q, 5)
#define CAM1_PWDN	TEGRA194_MAIN_GPIO(Q, 3)
	i2c@3160000 {
	    imx678_a@1a {
			clocks = <&bpmp_clks TEGRA194_CLK_EXTPERIPH1>,
					 <&bpmp_clks TEGRA194_CLK_EXTPERIPH2>;
			clock-names = "extperiph1", "extperiph2", "pllp_grtba";
			mclk = "extperiph1", "extperiph2";
            clock-frequency = <37125000>;
			reset-gpios = <&tegra_main_gpio CAM0_PWDN GPIO_ACTIVE_HIGH>;
		imx678_c@10 {
			reset-gpios = <&tegra_main_gpio CAM1_PWDN GPIO_ACTIVE_HIGH>;
	gpio@2200000 {
		camera-control-output-low {
			gpio-hog;
			output-low;
			gpios = <CAM0_PWDN 0 CAM1_PWDN 0>;
			label = "cam0-pwdn","cam1-pwdn";
	pinmux@2430000 {
		exp-header-pinmux {
				phandle = <0x185>;
				linux,phandle = <0x185>;
				hdr40-pin32 {
					nvidia,lpdr = <0x00>;
					nvidia,io-high-voltage = <0x00>;
					nvidia,enable-input = <0x00>;
					nvidia,tristate = <0x00>;
					nvidia,pull = <0x00>;
					nvidia,function = "gp";
					nvidia,pins = "soc_gpio44_pr0";
	__symbols__ {
		jetson_io_pinmux = "/pinmux@2430000/exp-header-pinmux\0";
However, I get these errors once I try to get stream from both:
[   14.251813] imx678 0-001a: probing v4l2 sensor
[   14.254510] imx678 0-001a: tegracam sensor driver:imx678_v2.0.6
[   14.257974] imx678_fuse_id_setup fuse id0 0, fuse id1 0
[   14.258729] tegra194-vi5 15c10000.vi: subdev imx678 0-001a bound
[   14.267313] imx678 0-001a: Detected IMX678 sensor
[   14.267427] imx678 0-0010: probing v4l2 sensor
[   14.268085] imx678 0-0010: tegracam sensor driver:imx678_v2.0.6
[   14.276376] imx678_fuse_id_setup fuse id0 0, fuse id1 0
[   14.276747] tegra194-vi5 15c10000.vi: subdev imx678 0-0010 bound
[   14.279470] imx678 0-0010: Detected IMX678 sensor
[  112.709961] imx678_set_frame_rate val =  25
[  112.709989] imx678_set_frame_rate VMAX =  2250
[  112.710496] imx678_set_coarse_time val =  6750
[  112.710501] imx678_set_coarse_time reg_shr0 =  1871
[  112.710961] imx678_set_gain gain = 13 val = 48
[  112.751896] imx678_set_frame_rate val =  10
[  112.751902] imx678_set_frame_rate VMAX =  5625
[  112.752347] imx678_set_coarse_time val =  6750
[  112.752350] imx678_set_coarse_time reg_shr0 =  5246
[  112.752820] imx678_set_gain gain = 0 val = 0
[  112.753919] imx678_set_gain gain = 13 val = 48
[  113.361072] imx678_set_coarse_time val =  1099
[  113.361132] imx678_set_coarse_time reg_shr0 =  5564
[  113.461532] imx678_set_gain gain = 80 val = 240
[  114.061902] imx678_set_gain gain = 40 val = 129
[  114.236315] imx678 0-0010: imx678_write_reg: i2c write failed, 0x3034 = 1
[  114.249649] imx678 0-0010: imx678_write_reg: i2c write failed, 0x3034 = 1
[  114.253085] imx678_set_mode, mode =  0
[  114.254530] imx678 0-0010: Error writing mode
[  114.255819] imx678 0-0010: imx678_write_reg: i2c write failed, 0x3034 = 1
[  114.261080] imx678_set_mode, mode =  0
[  114.261693] imx678 0-0010: Error writing mode
[  114.302635] imx678 0-0010: imx678_write_reg: i2c write failed, 0x3034 = 1
[  114.307060] imx678_set_mode, mode =  0
[  114.307443] imx678 0-0010: Error writing mode
[  114.308021] imx678 0-0010: imx678_write_reg: i2c write failed, 0x3034 = 1
[  114.310777] imx678_set_mode, mode =  0
[  114.311254] imx678 0-0010: Error writing mode
[  115.789385] imx678_set_mode, mode =  0
[  115.789804] imx678 0-0010: Error writing mode
[  115.790445] imx678 0-0010: imx678_write_reg: i2c write failed, 0x3034 = 1
[  115.791175] imx678_set_mode, mode =  0
[  115.791539] imx678 0-0010: Error writing mode
[  115.832118] imx678 0-0010: imx678_write_reg: i2c write failed, 0x3034 = 1
[  115.835352] imx678_set_mode, mode =  0
[  115.835750] imx678 0-0010: Error writing mode
As you can see, they are both probed and I can even get visuals from CAM0. However I can’t get any stream from CAM1 (CAM0 is 0-001c and CAM1 is 0-0010).
As a side note, when I try to use gst-launch separately, the second camera always fails to stream. So I don’t believe the issue is particularly with CAM1. If I start from CAM0 then CAM1, CAM1 fails. If I start from CAM1 then CAM0, CAM0 fails.
I would appreciate any help, thank you for your time.
hello mehmetyusuf1414,
may I know which Jetpack public release version you’re working with.
please refer to developer guide, To verify the port binding result.
you may see-also Applications Using V4L2 IOCTL Directly to use V4L2 IOCTL to verify basic camera functionality.
