Can not restore nvme with Orin Nano
I am trying backup and restore functions on my custom board, the module is Jetson Orin Nano 8G, jetpack is 5.1.1.
I use the following command to flash my board
sudo BOARDID=3767 BOARDSKU=0003 ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme0n1p1 -c ./tools/kernel_flash/flash_l4t_external.xml -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" --showlogs --network usb0 p3509-a02+p3767-0000 nvme0n1p1
Then, I use the following command to backup
sudo ./tools/backup_restore/l4t_backup_restore.sh -b p3509-a02+p3767-0000
No problems until this step, I formatted the nvme on the custom board to ext4, and then restored nvme using the following command
sudo ./tools/backup_restore/l4t_backup_restore.sh -r p3509-a02+p3767-0000
It fails with partx: specified range <1:0> does not make sense
I have tried several times to restore, and replaced the USB cable, but it doesn’t work, can anyone help?
Here is some logs
flash_log.txt (92.1 KB)
device_log.txt (82.0 KB)
PS:I have changed mmcblk0 to nvme0n1 in nvrestore_partitions.sh and nvbackup_partitions.sh, changed mmcblk0p1 to internal in l4t_backup_restore.sh, before I did the restore and backup.
Apply this patch:
diff --git a/scripts/backup-restore/nvrestore_partitions.sh b/scripts/backup-restore/nvrestore_partitions.sh
index 78ae589..695a700 100755
--- a/scripts/backup-restore/nvrestore_partitions.sh
+++ b/scripts/backup-restore/nvrestore_partitions.sh
@@ -313,10 +313,18 @@
 			echo "${SCRIPT_NAME} Checksum of ${FIELDS[2]} does not match the checksum in the index file."
 			exit 1
 		fi
-		# partx delete must be called before flashing, and partx add after flashing.
-		partx -d "/dev/${INTERNAL_STORAGE_DEVICE}"
+		# Delete previous GPT if it exists.
+		if partx -s "/dev/${INTERNAL_STORAGE_DEVICE}" >/dev/null 2>&1; then
+			partx -d "/dev/${INTERNAL_STORAGE_DEVICE}"
+		fi
+		# Flash GPT image, refresh and validate.
 		dd if="${FIELDS[1]}" of="/dev/${INTERNAL_STORAGE_DEVICE}"
+		sync
 		partx -v -a "/dev/${INTERNAL_STORAGE_DEVICE}"
+		if ! partx -s "/dev/${INTERNAL_STORAGE_DEVICE}" >/dev/null 2>&1; then
+			echo "Error: GPT does not exist on the /dev/${INTERNAL_STORAGE_DEVICE}"
+			exit 1
+		fi
 		GPT_EXISTS=true
 		break
 	fi
Or manually download 35.5 and replace Linux_for_Tegra/tools/backup_restore/ with the one you get in the 35.5 BSP.
Thanks for your solution, I’ll test it later.
The nvme restore works fine, awesome!
