I am using Logitech Gamepad F710 with Xavier. However, jstest does not work. When I pressed the buttons, jstest did not show any changes. How can I fix this? Here is my system config
should I set CONFIG_LOGITECH_FF=y or CONFIG_LOGITECH_FF=m?
Maybe you should firstly understand what is the difference between m and y in kernel config. This answer could be easily found over the internet. Then you decide which one do you need.
However, I do not know how where I can change the CONFIG_LOGITECH_FF in the instruction above.
Please search “tegra_defconfig” in the kernel source.
Is this Image the correct one to copy to /boot? Why it is arm64?
Because this binary is going to run on Jetson which is a ARM64 device.
