Can not uninstall and install because no permition to remove /usr/bin/nvidia-smi
error about Driver Version: 535.183.01
I try to reinstall driver to new driver by ./NVIDIA-Linux-x86_64-550.127.05.run and it seem show ERROR: Unable to deleate ‘/usr/bin/nvidia-smi’ (operation not permitted) PC (Nvidia A5000)
I can not use rm -rf /usr/bin/nvidia-smi also
or even if do something by command and it show like this
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
You might want to run ‘apt --fix-broken install’ to correct these.
The following packages have unmet dependencies:
cuda : Depends: cuda-12-6 (>= 12.6.3) but it is not going to be installed
Depends: nvidia-open (>= 560.35.05) but it is not going to be installed
cuda-drivers-535 : Depends: nvidia-utils-535 (>= 535.54.03) but it is not going to be installed
nvidia-driver-535 : Depends: nvidia-utils-535 (= 535.216.03-0ubuntu1) but it is not going to be installed
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
