I am using a custom nvdsparsebbox_Yolo.cpp with custom nms algorithm in [https://github.com/DanaHan/Yolov5-in-Deepstream-5.0/blob/master/Deepstream%205.0/nvdsinfer_custom_impl_Yolo/nvdsparsebbox_Yolo.cpp], everything runs well, the num_obj_meta is correct. But when I replace the nms with libtorch version like vision::ops::nms to speed up, in most cases the num_obj_meta is 0. Moreover, even if I add some libtorch operations that don’t affect nms results in the code that uses the original nms, the problem remains. However, the libtorch-version nms result is the same as the orginal nms, so I am confused with these behavior.
Part of code is as follows:
Blockquote
num_obj_meta is correct:
static pool NvDsInferParseYoloX(
std::vector const& outputLayersInfo,
NvDsInferNetworkInfo const& networkInfo,
NvDsInferParseDetectionParams const& detectionParams,
std::vector& objectList
std::vector res;
float *prob = (float *)outputLayerInfo[0].buffer;
// auto options = torch::TensorOptions().device(torch::kCUDA); // add some libtorch operation in orignial code also raises the problem
decode(prob, img_w, img_h);
nms(res, prob, CONF_THRESH, NMS_THRESH);
for(auto &r:res)
// put res result in objectList
Blockquote
Blockquote
num_obj_meta is 0 or little:
std::vector res;
auto options = torch::TensorOptions().device(torch::kCUDA); // same problem using kCPU
auto out = torch::from_blob(prob, {sizes of model output});
// extract bboxes from out tensor after CONF_THRESH filter
// extract confs from out tensor after CONF_THRESH fliter
auto nms_index = vision::ops::nms(bboxes, confs, NMS_THRESH); // libtorch-version nms
// put output tensor into objectList
Blockquote
• Hardware Platform (Jetson / GPU) : GPU TITANXP
• DeepStream Version : 5.1
• TensorRT Version : 8.2.0.6
• NVIDIA GPU Driver Version (valid for GPU only): 460.67
• Issue Type( questions, new requirements, bugs): questions
