CAN not working for Jetson Orin Nano for Jetpack 6.1
I have installed Jetpack 6.1+b123 on my Jetson Orin Nano. However, it looks like CAN is not working on the device. I am able to perform a Loopback test as specified in CAN Network Tutorial, but beyond that I am unable to interact with real devices.
I have also setup the pinmux registers as per the instructions specified in the above link, and I have loaded the kernel drivers specified in the instructions.
I did notice that the following command cat /proc/device-tree/mttcan\@c310000/status returns an error “No such file or directory”.
I have followed the same setup process as I did for versions of Jetpack 5.x.x.x, and am unable to get the CAN network working. I would appreciate any help here.
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
3. Tutorial
Startup deep learning tutorial:
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
The commands you have provided run properly on my Jetson, but they do not fix my problem.
I solved my problems, I think my devmem was set incorrectly.
