When I begin to consider integration of argus camera, Multimedia API and even Visionworks functionality into one project, I begin to doubt how readily Nsight will accommodate the configuration required. Here is an example of someone looking for the same type of clarification:
What IS the standard workflow to debug and run a more complex application like I described? Yeah, sure I can edit build and run all day long from the terminal (and I’ve been doing that) but I am not seeing a straightforward way to develop an application with camera & mmapi within Nsight. My guess is that it will require a lot of customization outside of the normal documented processes.
