Hi
I have been developing media display using raspi.
I would like to explore using jetson nano for my project, hopefully to incorporate some AI components to the media display
At raspi, I am using omxplayer at raspi which allow me to play video without the X11 desktop environment.
May I know whether nvgstplayer can do that?
I would appreciate it if someone could point me to the right resource to investigate… I have been reading through the forum but could not find similar topic.
Many thanks in advance
Regards,
James
DaneLLL
December 10, 2019, 2:53am
#2
Please utilize nvoverlaysink:
$ nvgstplayer-1.0 -i file:///home/nvidia/deepstream_sdk_v4.0.1_jetson/samples/streams/sample_720p.mp4 <b>--svs=nvoverlaysink</b>
Thanks DaneLL
the command works. But it is full-screen
I tried
nvgstplayer-1.0 -i file:///home/nvidia/deepstream_sdk_v4.0.1_jetson/samples/streams/sample_720p.mp4 --svs=nvoverlaysink --window-x 0 --window-y 0 --window-width 1024 --window-height 768
it still show fullscreen. Anyway to specify the display area?
James
DaneLLL
December 10, 2019, 5:24am
#4
For this function, you need to customize nvgstplayer-1.0 to use nvdrmvideosink. nvdrmvideosink has the properties:
offset-x : Sets offset x
flags: readable, writable
Integer. Range: 0 - 2147483647 Default: 0
offset-y : Sets offset y
Source code of nvgstplayer-1.0 is in
https://developer.nvidia.com/embedded/r32-2-3_Release_v1.0/Sources/T210/public_sources.tbz2
Please follow README to build/run the app.
@DaneLLL
Thanks for the prompt response. Great support from Nvidia
@DaneLLL
I am a GStreamer NOOB.
I downloaded the public_sources.tbz2 and found nvgstplayer-1.0_README.txt. It is to give instruction on how to compile the nvgstplayer-1.0 for armhf and the command syntax.
I totally got no clue how to customise the source code “nvgstplayer.c”. Would appreciate it if you could give some clues / instructions on how to go about customising the nvgstplayer app.
how do i incorporate
gst_video_overlay_set_render_rectangle
(GstVideoOverlay *overlay,
gint x,
gint y,
gint width,
gint height);
into :
if (GST_IS_VIDEO_OVERLAY (vsink)) {
gst_video_overlay_set_window_handle (GST_VIDEO_OVERLAY (vsink),
(gulong) window);
gst_video_overlay_expose (GST_VIDEO_OVERLAY (vsink));
Many thanks
James
DaneLLL
December 19, 2019, 8:43am
#7
It is open source and we would encourage users on customization and integration. Please check
nvgstapps_src\README.txt
Hi DaneLLL
I tried the following and gotten success.
gst-launch-1.0 filesrc location=video5.mp4 !
qtdemux name=demux ! h264parse ! omxh264dec !
nvvidconv flip-method=0 !
‘video/x-raw(memory:NVMM), width=1280 height=720 format=(string)I420’ !
nvdrmvideosink conn_id=0 plane_id=1 set_mode=0 offset-x=100 offset-y=100 -e
I am still trying to figure out how to port the above pipeline (render chain) using nvgstplayer-1.0.
What are the key differences between nvgstplayer-1.0 and gst-launch-1.0? Is there any advantage to play the video in nvgstplayer-1.0?
Also, would appreciate it if you could point me to the documentation of nvoverlaysink and nvdrmvideosink. I would like to explore what are the properties available … many thanks
James
DaneLLL
December 30, 2019, 3:23am
#9
nvgstplayer-1.0 is a reference app to demonstrate how to program gstreamer pipelines in C code. If gst-launch-1.0 is good in your usecase, you may run simply run gst-launch-1.0 commands.
You may check gstreamer user guide for more sample pipelines:
https://developer.nvidia.com/embedded/dlc/l4t-accelerated-gstreamer-guide-32-2
Hi DaneLLL
Thanks for the prompt reply. Will work on gst-launch-1.0.
Just to close the loop in case someone looking for the same solution:
working solution:
nvgstplayer-1.0 -i video5.mp4 --svs="nvvidconv # flip-method=1 ! nvoverlaysink # overlay-x=100 # overlay-y=100 # overlay-w=720 # overlay-h=1280 "
I could not get the nvdrmvideosink to work the same way …
Cheers,
James
@DaneLLL
I tried the following audio decode example given in the gstreamer user guide, but could not get audio.
Any pointers on what could possibly went wrong?
gst-launch-1.0 filesrc location=video1.mp4 !
qtdemux name=demux demux.audio_0 !
queue ! avdec_aac ! audioconvert ! alsasink -e
I could play the mp4 file with audio using the following:
nvgstplayer-1.0 -i video1.mp4 --svs=nvoverlaysink
I tried all the audio decode examples in the guide using gst-launch-1.0 and could not get any audio.
DaneLLL
December 30, 2019, 7:01am
#12
You can run ‘aplay -l’ to list all audio playback devices and set it to alsasink like:
$ gst-launch-1.0 filesrc location=a.mp4 ! qtdemux ! avdec_aac ! audioconvert ! alsasink device="hw:2,0"
Hi DaneLLL
Thanks for the help. I managed to piece together the gst-launch-1.0 pipeline together. But I got the following error messages. I googled them but seems like it is a bug…
qtdemux name=demux
demux.audio_0 ! queue !
alsasink device=“hw:0,3”
demux.video_0 ! queue !
‘video/x-raw(memory:NVMM), width=1280, height=720, format=(string)I420’ !
Setting pipeline to PAUSED …
Pipeline is PREROLLING …
(gst-launch-1.0:5571): GStreamer-CRITICAL **: 18:00:46.114: gst_caps_is_empty: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:5571): GStreamer-CRITICAL **: 18:00:46.114: gst_caps_truncate: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:5571): GStreamer-CRITICAL **: 18:00:46.114: gst_caps_fixate: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:5571): GStreamer-CRITICAL **: 18:00:46.114: gst_caps_get_structure: assertion ‘GST_IS_CAPS (caps)’ failed
(gst-launch-1.0:5571): GStreamer-CRITICAL **: 18:00:46.114: gst_structure_get_string: assertion ‘structure != NULL’ failed
(gst-launch-1.0:5571): GStreamer-CRITICAL **: 18:00:46.114: gst_mini_object_unref: assertion ‘mini_object != NULL’ failed
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Allocating new output: 1280x720 (x 12), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3605: Send OMX_EventPortSettingsChanged: nFrameWidth = 1280, nFrameHeight = 720
Redistribute latency…
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstAudioSinkClock
solved. replaced “omxh264dec” with "nvv4l2decoder ". But I do not know why. Maybe you can enlighten me. For learning purpose.
Many thanks
qtdemux name=demux
h264parse !
nvv4l2decoder !
nvoverlaysink
overlay-x=100 overlay-y=100 overlay-w=1280 overlay-h=720
Opening in BLOCKING MODE
Got EOS from element “pipeline0”.
Execution ended after 0:04:21.438113040
Setting pipeline to READY …
Setting pipeline to NULL …
Freeing pipeline …
DaneLLL
December 31, 2019, 1:20am
#15
We are deprecating omx plugins, so if nvv4l2decoder works fine, please use it.
@DaneLLL
I have a dell-G7 with GTX1060.
I installed gstreamer on it but realised that it does not come with nvidia’s plugins.
May I know whether these nvidia plugins (which came with jetpack4.3) can be used on my dell-G7 with GTX1060, and if yes how I could install those gst plugins on my dell-G7?
DaneLLL
February 6, 2020, 11:35am
#17
For PC with NVIDIA desktop GPU, please use video codec SDK to leverage hardware acceleration.
https://developer.nvidia.com/nvidia-video-codec-sdk/download
nvgstplayer is for Jetson platforms.
@DaneLLL
Seems like the nvidia-video-codec sdk is based on FFMPEG.
Is there a GStreamer based sdk for Nvidia desktop GPU?
