With regards to licensing of GPLv3 components and things like gstreamer etc: Is it safe to use NVIDIA’s Ubuntu-Based Jetpack Packages including OS in embedded systems that are sold to customers? Will docker need licensing per device then?
When looking at the contents of the JP images, it does not seem they are meant for production use anyway. Or do i see this wrong?
users/developers are expected to deploy Jetson with software pre-installed and configured for use in end products, so what you describe should be fine. If you have further questions, please consult the EULA’s included in JetPack or the Software License Agreement
Thank you for the answer. Does that license agreement only apply for the parts of jetpack developed by nvidia or also for the Ubuntu OSS packages includeded in the image?
NVIDIA JetPack includes a reference file system derived from Ubuntu. This reference file system includes packages bundled with their corresponding copyrights and licenses terms. Review the open source license terms and the Canonical Intellectual property rights policy before use. Contact Canonical for any questions regarding the Canonical Intellectual Property Rights Policy.
I am not a lawyer, but the typical licensing for GPL in Linux and Ubuntu tends to allow distribution if the source code is available for the GPL licensed code, plus it means you could not hijack ownership of that software.
Ubuntu itself, and the kernel source, are freely available through third party URLs you could mention, or else provide copies of. There typically isn’t any restriction on using that software for any purpose, e.g., hobby drone, or selling a drone for a commercial profit. If you intend to remove the Ubuntu and Linux branding and hide it, then this would violate the licensing. If you’re just building something which runs Linux, then it probably won’t matter what its purpose is. See a lawyer and ask specifics, the above are just a ballpark idea.
Afaik, gplv2 is not a problem as long as you do not change code and - to be more secure - not link against GPLv2 libraries (which nvidia helps us with by providing adapters to dynamically load libs and integrate them into gstreamer). But with GPLv3 there is this “tivoization” clause (hope i got spelling right) which explicitlty demands devices that are delivered with code under GPL v3 being open to the user to change the software installed on them. I.e. if you use ONE GPLv3 licensed library you need to give customers root access to your hardware so they can replace your software. I wonder if there are any GPL v3 libs included in the JetPack. Because this is jot between NVIDIA and us, this is between the original license giver (i.e. open source project) and us.
GPL-3 Packages in Jetpack 4.6.2:
ii haveged 1.9.1-6 arm64 Linux entropy source using the HAVEGE algorithm GPL-3+ permissive-mconf permissive-nist public-domain
ii libhavege1:arm64 1.9.1-6 arm64 entropy source using the HAVEGE algorithm - shared library GPL-3+ permissive-mconf permissive-nist public-domain
ii dh-strip-nondeterminism 0.040-1.1~build1 all file non-deterministic information stripper — Debhelper add-on GPL-3+
ii grep 3.1-2build1 arm64 GNU grep, egrep and fgrep GPL-3+
ii libfile-stripnondeterminism-perl 0.040-1.1~build1 all file non-deterministic information stripper — Perl module GPL-3+
ii make 4.1-9.1ubuntu1 arm64 utility for directing compilation GPL-3+
ii networkd-dispatcher 1.7-0ubuntu3.3 all Dispatcher service for systemd-networkd connection status changes GPL-3+
ii screen 4.6.2-1ubuntu1.1 arm64 terminal multiplexer with VT100/ANSI terminal emulation GPL-3+
ii dconf-gsettings-backend:arm64 0.26.0-2ubuntu3 arm64 simple configuration storage system - GSettings back-end GPL-3 LGPL-2+
ii dconf-service 0.26.0-2ubuntu3 arm64 simple configuration storage system - D-Bus service GPL-3 LGPL-2+
ii libdconf1:arm64 0.26.0-2ubuntu3 arm64 simple configuration storage system - runtime library GPL-3 LGPL-2+
ii libutempter0:arm64 1.1.6-3 arm64 privileged helper for utmp/wtmp updates (runtime) GPL-3 LGPL-2.1 LGPL-3
ii libgupnp-igd-1.0-4:arm64 0.2.5-1 arm64 library to handle UPnP IGD port mapping GPL-3 LGPL-2
ii bash 4.4.18-2ubuntu1.2 arm64 GNU Bourne Again SHell GPL-3
ii coreutils 8.28-1ubuntu1 arm64 GNU core utilities GPL-3
ii less 487-0.1 arm64 pager program similar to more GPL-3
ii libksba8:arm64 1.3.5-2 arm64 X.509 and CMS support library GPL-3
ii libparted2:arm64 3.2-20ubuntu0.2 arm64 disk partition manipulator - shared library GPL-3
ii parted 3.2-20ubuntu0.2 arm64 disk partition manipulator GPL-3
ii rsync 3.1.2-2.1ubuntu1.4 arm64 fast, versatile, remote (and local) file-copying tool GPL-3
ii sed 4.4-2 arm64 GNU stream editor for filtering/transforming text GPL-3
ii ssh-import-id 5.7-0ubuntu1.1 all securely retrieve an SSH public key and install it locally GPL-3
I can’t comment this further, you’re better to consult with a lawyer for the SW license agreement above. Thanks
