I refer to the following documents.
http://docs.nvidia.com/drive/nvvib_docs/index.html
(Conntents = Multimedia Programming -> NvMedia Image Domain -> Image 2D)
---- Excerpt ----
The NvMedia Image 2D component supports image surface processing features such as image copy, image scaling, image cropping. It operates on YUV/RGB input and output surfaces. It also performs format conversion to/from YUV to RGB and supports aggregated image handling.
So,I have read the description about the API of image2D.
http://docs.nvidia.com/drive/nvvib_docs/NVIDIA%20Vibrante%20Linux%20DPX%20Development%20Guide/baggage/index.html
(Conntents = API Modules -> NvMedia API for Tegra -> Image API)
I also checked the links of “Data Structures” and “Modules”.
But I could not find a description about the image scaling and API information
I will ask you 5 questions.
I want an answer as soon as possible. I hope that you will answer even one of them.
However, I would like you to finally answer everything.
Question 1. Can NvMedia’s 2D really do image scaling?
Question 2. If the answer to question 1 is Yes Please tell me which document to read.
Question 3. If the answer to question 1 is No, please tell me where the scaling is done and which document to read.
Question 4. I would like to specify the parameters for scaling and cropping. Is that possible?
Question 5. Are the documents I should read in DevZone and Vibrante SDK?
Notice
I do not have permission to refer bin files and documents yet in DevZone.
Best regards
