I am porting a C++ program previously compiled by G++.
I am not sure that pgCC support pread/pwrite.
Any help will be appreciated.
Hi W.Xue,
pgCC supports all standard Linux system calls, including pread/pwrite. However, since we can’t have PGI specific header files for everything, you sometimes need to add a bit of extra code in order to get the correct prototypes.
For example with pwrite/pread, I extracted the prototype definitions from “unistd.h” and placed them in an extern “C” block so C++ name mangling would not be applied.
#include <unistd.h>
extern "C" {
extern ssize_t pread(int __fd, void *__buf, size_t __nbytes,
__off_t __offset);
extern ssize_t pwrite (int __fd, __const void *__buf, size_t __n,
__off_t __offset);
Hope this helps,
Mat
