lewis15
September 12, 2024, 9:33am
1
https://docs.nvidia.com/jetson/archives/r35.3.1/DeveloperGuide/text/HR/ControllerAreaNetworkCan.html?highlight=pinmux#jetson-platform-details
If you set the pinmux above, you will get the following result.
How do I change the settings?
In the picture below, the busybox command is used to change pinmux, but I use pinmux.dtsi and want to change it.
How do I change the pinmux settings above?
Hi lewis15,
Please use pinmux spreadsheet instead of modifying pinmux dtsi directly in case you configure something wrong.
If you want to verify CAN interface, you can just use devmem tool to configure the register temporarily.
lewis15
September 23, 2024, 12:36am
5
Hi KevinFFF,
Sorry for the late reply.
I’m using custom board and Jetpack version is 5.1.2
How do I adjust the value in the spreadsheet as shown in the developer guide?
You can configure the column Customer Usage
to CAN .
Could you share the screenshot of your pinmux speadsheet with the part of those pins?
lewis15
September 26, 2024, 5:46am
7
Hi, KevinFFF.
Here is my pinmux speadsheet. And i’m not using STB pin.
Here is my circuit diagram.
lewis15:
image2477×41 15.5 KB
Your configuration looks good to me.
Or you can configure Output/Drive 0
for CAN0_DOUT , Input/Int PD
for CAN0_DIN .
Have you confirmed the pinmux/gpio dtsi been applied successfully?
system
Closed
October 23, 2024, 5:26am
12
