We need to pass nvbuffer between processes, using sendmsg()…
But encountered the following error:
nvbuf_utils: dmabuf_fd 3 mapped entry NOT found
nvbuf_utils: Can not get HW buffer from FD... Exiting...
Full source code:
#include <stdio.h>
#include <unistd.h>
#include <sys/socket.h>
#include <sys/un.h>
#include <nvbuf_utils.h>
#define LOG(fmt, ...) printf(fmt "\n", ##__VA_ARGS__)
int main(char argc, char *argv[])
int sock[2];
if (socketpair(AF_UNIX, SOCK_STREAM, 0, sock))
LOG("[E] create sockpair failed!");
return -1;
int pid = fork();
char buf[100];
struct iovec iov;
if (pid != 0)
//create nvBuffer
int fd;
NvBufferCreateParams bufParams = {0};
bufParams.width = 1280;
bufParams.height = 720;
bufParams.layout = NvBufferLayout_Pitch;
bufParams.colorFormat = NvBufferColorFormat_NV12;
bufParams.payloadType = NvBufferPayload_SurfArray;
bufParams.nvbuf_tag = NvBufferTag_CAMERA;
if (NvBufferCreateEx(&fd, &bufParams))
LOG("[E] create buffer for camera failed! err=%d", errno);
return -1;
struct msghdr msg;
msg.msg_iov = &iov;
msg.msg_iovlen = 1;
msg.msg_control = buf;
msg.msg_controllen = sizeof(buf);
struct cmsghdr *cmsg;
cmsg = CMSG_FIRSTHDR(&msg);
cmsg->cmsg_level = SOL_SOCKET;
cmsg->cmsg_type = SCM_RIGHTS;
cmsg->cmsg_len = CMSG_LEN(sizeof(int));
memcpy(CMSG_DATA(cmsg), &fd, sizeof(int));
msg.msg_controllen = cmsg->cmsg_len;
if (sendmsg(sock[0], &msg, 0) <= 0)
LOG("[E] send fd to client failed, fd=%d! err=%d", fd, errno);
else
LOG("[I] sending fd=%d ok", fd);
else
struct msghdr msg;
msg.msg_iov = &iov;
msg.msg_iovlen = 1;
msg.msg_name = NULL;
msg.msg_namelen = 0;
msg.msg_controllen = CMSG_LEN(sizeof(buf));
if (recvmsg(sock[1], &msg, 0) <= 0)
LOG("[E] client recvmsg failed!");
return -1;
struct cmsghdr *cmsg = CMSG_FIRSTHDR(&msg);
if (cmsg->cmsg_type != SCM_RIGHTS)
LOG("[E] client recvmsg type wrong, type = %d", cmsg->cmsg_type);
return -2;
int fd = *(int *)(CMSG_DATA(cmsg));
LOG("[I] recv fd=%d ok", fd);
NvBufferParams bufParam;
//get nvBuffer param
if (NvBufferGetParams(fd, &bufParam))
LOG("[E] get buf param failed! err = %d", errno);
else
LOG("[I] buf info plane=%d, width=%d, height=%d, size=%d",
bufParam.num_planes, bufParam.width[0], bufParam.height[0], bufParam.psize[0]);
