Can SX6036 switches be configured to use TLS 1.2 only on the management port, and if so, how?
I manage multiple systems that include with SX6036 switches. The client uses Qualys to scan for security vulnerabilities, and it’s reporting that the IB Switches are using SSL and / or TLS 1.0 / 1.1.
Can these switches be configured to use TLS 1.2 only on the management port, and if so, how do I set that?
Note - the switches FW is at 3.6.6003, and cannot be changed (due to MRA restrictions).
You can use “config# web https ssl ciphers TLS1.2”
gso-sx6036 [standalone: master] (config) # show web
Web User Interface:
Web interface enabled: yes
Web caching enabled: no
HTTP enabled: yes
HTTP port: 80
HTTP redirect to HTTPS: yes
HTTPS enabled: yes
HTTPS port: 443
HTTPS ssl-ciphers: all
HTTPS ssl-renegotiation: yes
HTTPS ssl-secure-cookie: no
HTTPS certificate name: sf579469-3072
Listen enabled: yes
Listen Interfaces:
No interface configured.
Inactivity timeout: 1 hr
Session timeout: 2 hr 30 min
Session renewal: 30 min
Web file transfer proxy:
Proxy enabled: no
Web file transfer certificate authority:
HTTPS server cert verify: yes
HTTPS supplemental CA list: default-ca-list
gso-sx6036 [standalone: master] (config) # web https ssl ciphers ?
SSL mode used for HTTPS
all Use all ciphers
TLS Use only TLS ciphers
TLS1.2 Use only TLS1.2 ciphers
gso-sx6036 [standalone: master] (config) # web https ssl ciphers TLS1.2
Web User Interface:
HTTP enabled: yes
HTTP port: 80
HTTPS enabled: yes
HTTPS port: 443
HTTPS ssl-ciphers: TLS1.2
Listen enabled: yes
Listen Interfaces:
Proxy enabled: no
