Can`t install python3-dev , numpy
When I install the python3-dev with the command"sudo apt-get install python3-dev",it returns:
“The following packages have unmet dependencies:
python3-dev : Depends: dh-python but it is not installable
E: Unable to correct problems, you have held broken packages.”
But the package ‘dh-python’ has no installation candidate.
When I install numpy with the command""sudo pip3 instll -U numpy, it returns:
  File "/usr/bin/pip3", line 9, in <module>
    from pip import main
ImportError: cannot import name 'main'
Any help will be appreciated.
have a look here https://devtalk.nvidia.com/default/topic/1049071/jetson-nano/pytorch-for-jetson-nano/
search for “note on upgrading pip” for the solution for your problem
Thanks, I can install the pip3 successed.
But I must add sudo when install some wheels like tf,
And I cannot install python3-dev with the error:
I’ve just answered your subsequent repost @ Can`t install python3-dev - Jetson Nano - NVIDIA Developer Forums
HTH,
Simon
