Can’t power on the Jetson AGX Orin Dev Kit
Our Jetson AGX Orin Devkit is experiencing a power issue where it no longer boots up, and the LED indicators remain off when power is applied via both USB-C and the DC barrel connector. This same devkit has successfully booted in the past, so this is an unexpected failure.
Interestingly, we were able to detect the Jetson on the serial console through the USB debug port, suggesting that some parts of the board may still be operational. However, with no LED activity and no visible signs of the system fully powering up, we suspect an issue with the power delivery circuitry.
We’ve attempted troubleshooting but haven’t been able to isolate the exact cause. Given these symptoms, we’d appreciate any recommendations for further debugging. If the issue points to a hardware failure, we’d like to move forward with the RMA process.
Thank you for your assistance!
Please follow developer guide to let the AGX Orin developer kit enter recovery mode and flash latest Jetpack 6.2:
Quick Start — NVIDIA Jetson Linux Developer Guide
If this fails, it is very likely to be hardware defect and please go RMA process.
I tried flashing the latest Jetpack but it failed. I will go ahead and do the RMA process. Thanks!
