Can the ConnectX-8 in DGX Station operate in InfiniBand mode and connect to a Q3200 InfiniBand switch?
I would like to clarify the networking capabilities of the ConnectX-8 SuperNIC integrated into NVIDIA DGX Station.
According to page 6 of the NVIDIA ConnectX-8 SuperNIC User Manual, some ConnectX-8 models support both Ethernet and InfiniBand.
For example, the C8240 supports:
- 400GbE
- NDR InfiniBand
- Dual-port QSFP112
and Ethernet is listed as the default configuration.
However, the DGX Station documentation describes the ConnectX-8 networking interface as 2 x 400GbE QSFP ports.
I could not find a clear statement confirming whether the ConnectX-8 integrated into DGX Station can also be configured to operate in InfiniBand mode.
The topology I am planning is:
DGX Station
ConnectX-8
NDR InfiniBand
NVIDIA Q3200 InfiniBand Switch
I would like to clarify the following points:
What is the exact ConnectX-8 model / OPN used in DGX Station?
Is the ConnectX-8 in DGX Station hardware-capable of operating in InfiniBand mode, or is it restricted to Ethernet only?
If the hardware supports InfiniBand, is changing the port link type from Ethernet to InfiniBand officially supported on DGX Station?
Can DGX Station be connected directly to an NVIDIA Q3200 InfiniBand switch using NDR InfiniBand?
If this configuration is supported:
- Is any specific firmware required?
- Is a specific cable / transceiver required?
- Is any additional configuration required on the Q3200 side, such as
connection-mode ndr?
I currently do not have physical access to the DGX Station, so I cannot verify the adapter OPN or LINK_TYPE using mlxfwmanager or mlxconfig.
Thank you.
