Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
[√] DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Host Machine Version
[√] native Ubuntu 18.04
other
Hi NV experts.
Can the input image and resolution differ from the resolution of the encoded video stream when using an encoder for encoding?
The original image resolution is 1920 × 1216, the resolution of the encoded video stream is 720x480, but there is a problem with the resolution after encoding.
Dear @liuq1,
Are you using nvmimg_enc sample. If so, could you please share config file and input file for reproduce the issue. I am still not clear what is the issue here? Do you see output resolution is different than values in config file or output image looks bad?
Hi @SivaRamaKrishnaNV
We are not using the nvmimg_enc sample. The problem is, the input image is 1920*1216, we set the output resolution is 720x480. The output image is abnormal. The output image appears to be only a part of the pre encoded image.
