Does Jetson Nano support DisplayPort over USB interface ? I have a smart glasses that i wanna use as display for jetson nano but it doesn’t have direct HDMI or DP out. It says in the manual that it can be connected over USB if the device have DisplayPort over USB. So i was wondering if i could connect it to the USB port .
Sorry, not supported.
So can i change DisplayPort output of jetson nano to USB with adapters and will it work as DisplayPort over USB?
Basically it is still a displayport output signal from jetson side. If your adapter can convert signal correctly, then it may work.
