The PCIe x8 bus of the AGX Xavier (interface C5) is connected to the PCIe x16 connector on the dev kit carrier board. Can this x8 bus be split into 2 PCIe x4 busses?
Hi, C5 means controller #5, one controller can only support one port simultaneously.
Thanks. I was afraid, that this is the case. Do you have a recommendation for a PCIe bridge, to split the x8 bus into 2 x4 busses?
No such info can share.
