Searching for a way to utilize OpenCL on my Jetson Xavier for MVTec Halcon library I’ve encountered a YouTube instructional video to install OpenCL on Jetson Nano . Alan seems to install some build tools and libraries and then compiles pocl.
Now I’ve followed the instructions and get some interesting output on my Jetson when typing clinfo:
Number of platforms 1
Platform Name Portable Computing Language
Platform Vendor The pocl project
Platform Version OpenCL 1.2 pocl 1.3 Release, LLVM 6.0.0, SLEEF, POCL_DEBUG, FP16
Platform Profile FULL_PROFILE
Platform Extensions cl_khr_icd
Platform Extensions function suffix POCL
Number of devices 1
Device Name pthread-0x004
Device Vendor 0x4e
Device Vendor ID 0x13b5
Device Version OpenCL 1.2 pocl HSTR: pthread-aarch64-unknown-linux-gnu-cortex-a57
Driver Version 1.3
Device OpenCL C Version OpenCL C 1.2 pocl
Device Type CPU
Device Profile FULL_PROFILE
Device Available Yes
Compiler Available Yes
Linker Available Yes
Max compute units 8
Max clock frequency 2265MHz
Device Partition (core)
Max number of sub-devices 8
Supported partition types equally, by counts
Max work item dimensions 3
Max work item sizes 4096x4096x4096
Max work group size 4096
Preferred work group size multiple 8
Preferred / native vector sizes
char 16 / 16
short 8 / 8
int 4 / 4
long 2 / 2
half 8 / 8 (cl_khr_fp16)
float 4 / 4
double 2 / 2 (cl_khr_fp64)
Half-precision Floating-point support (cl_khr_fp16)
Denormals No
Infinity and NANs No
Round to nearest No
Round to zero No
Round to infinity No
IEEE754-2008 fused multiply-add No
Support is emulated in software No
Single-precision Floating-point support (core)
Denormals No
Infinity and NANs Yes
Round to nearest Yes
Round to zero No
Correctly-rounded divide and sqrt operations No
Double-precision Floating-point support (cl_khr_fp64)
Denormals Yes
Round to zero Yes
Round to infinity Yes
IEEE754-2008 fused multiply-add Yes
Address bits 64, Little-Endian
Global memory size 31321673728 (29.17GiB)
Error Correction support No
Max memory allocation 8589934592 (8GiB)
Unified memory for Host and Device Yes
Minimum alignment for any data type 128 bytes
Alignment of base address 1024 bits (128 bytes)
Global Memory cache type Read/Write
Global Memory cache size 2097152 (2MiB)
Global Memory cache line size 64 bytes
Image support Yes
Max number of samplers per kernel 16
Max size for 1D images from buffer 536870912 pixels
Max 1D or 2D image array size 2048 images
Max 2D image size 16384x16384 pixels
Max 3D image size 2048x2048x2048 pixels
Max number of read image args 128
Max number of write image args 128
Local memory type Global
Local memory size 1048576 (1024KiB)
Max number of constant args 8
Max constant buffer size 1048576 (1024KiB)
Max size of kernel argument 1024
Queue properties
Out-of-order execution No
Profiling Yes
Prefer user sync for interop Yes
Profiling timer resolution 1ns
Execution capabilities
Run OpenCL kernels Yes
Run native kernels Yes
printf() buffer size 16777216 (16MiB)
Built-in kernels
Device Extensions **cl_khr_byte_addressable_store** cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_3d_image_writ
es cl_khr_fp16 cl_khr_fp64
NULL platform behavior
clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...) Portable Computing Language
clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...) Success [POCL]
clCreateContext(NULL, ...) [default] Success [POCL]
clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT) Success (1)
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU) Success (1)
clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM) No devices found in platform
clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL) Success (1)
ICD loader properties
ICD loader Name OpenCL ICD Loader
ICD loader Vendor OCL Icd free software
ICD loader Version 2.2.11
ICD loader Profile OpenCL 2.1
As @cdahms123 mentioned in a thread he started on the topic the device should be detected as compute device by Halcon under this condition:
At present, HALCON only supports OpenCL compatible GPUs supporting the OpenCL extension cl_khr_byte_addressable_store and image objects. If you are not sure whether a certain device is supported, please refer to the manufacturer.
cl_khr_byte_addressable_store is detected as seen in the clinfo output above.
Now I wonder why the hbench utility still doesn’t detect the GPU. As I’m on the limit of the device in terms of performance I also need all the acceleration I can get …
Do I understand something wrong about the OpenCL support on Jetson or is this “workaround” through pocl not actually working properly?
@dusty_nv Thanks for your great GitHub repos for Jetson ML BTW. They’ve helped me a lot!
