Can there be 2 decider network on same cortex world with 2 different robot
Isaac Sim Version
2023.1.1
Operating System
Ubuntu 22.04
GPU Information
  • Model: NVIDIA GeForce RTX 3090
  • Driver Version: 570.124.04
Can there be 2 decider network in same cortex world with 2 different robot and different work ?
I have been trying to run 2 UR10 robot in cortex world. i have created 2 different DfState and 2 different CortexUr10 robot. i want to pick and place 2 cube at same time but with different robot.
But i am getting is only one decider network is working but the moment is copied by both the robot.
Below i have attached the code and video.
Can somebody from official team help, if this could be achievable or not. and if yes what i am missing.
CODE
> from omni.isaac.kit import SimulationApp
> simulation_app = SimulationApp({"headless": False})
> import numpy as np
> from omni.isaac.core.objects import DynamicCuboid
> from omni.isaac.cortex.cortex_world import CortexWorld
> from omni.isaac.cortex.df import DfNetwork, DfState, DfStateMachineDecider
> from omni.isaac.cortex.dfb import DfRobotApiContext, DfBasicContext
> from omni.isaac.cortex.robot import CortexUr10, add_ur10_to_stage
> from omni.isaac.universal_robots import UR10
> from omni.isaac.core.utils.types import ArticulationAction
> from omni.isaac.core.utils.stage import add_reference_to_stage
> class PickState(DfState):
>     @property
>     def robot(self):
>         return self.context.robot
>     @property
>     def pick_cube(self):
>         return self.context.robot.pick_cube
>     def enter(self):
>         self.gripper_has_cube = False
>         # self.robot.set_joints_default_state(positions=np.array([0.0,1.57, 1.57, 0.0, 1.57, 0.0]))
>         self.robot.suction_gripper.open()
>         self.target_pos, self.target_ort = self.pick_cube.get_world_pose()
>         print("Target Position: ", self.target_pos)
>         pass
>     def step(self):
>         self.eff_p = self.robot.arm.get_fk_p()
>         self.new_target = self.target_pos + np.array([0,0,0.1/2])
>         print("New Target for pick cube: ", self.new_target)
>         self.robot.arm.send_end_effector(target_position=self.new_target)
>         if not self.gripper_has_cube and  np.linalg.norm(self.new_target - self.eff_p) < 0.01 :
>             self.robot.suction_gripper.close()
>             self.gripper_has_cube = True
>             print("Gripper has cube")
>         if self.gripper_has_cube:
>             self.robot.arm.send_end_effector(target_position=np.array([0.4, 0.8, 0.15]))
>             if np.linalg.norm(np.array([0.4, 0.8, 0.15]) - self.eff_p) < 0.01 :
>                 self.robot.arm.send_end_effector(target_position=np.array([0.0, 0.8, 0.1]))
>                 return None
>         return self
> class PickState1(DfState):
>     @property
>     def robot(self):
>     @property
>         return self.context.robot.pick_cube1
>     def enter(self):
>         pass
>     def step(self):
>         print("New Target for pick cube 1: ", self.new_target)
>         # self.robot.arm.send_end_effector(target_position=self.new_target)
>         # if not self.gripper_has_cube and  np.linalg.norm(self.new_target - self.eff_p) < 0.01 :
>         #     self.robot.suction_gripper.close()
>         #     self.gripper_has_cube = True
>         #     print("Gripper has cube")
>         # if self.gripper_has_cube:
>         #     self.robot.arm.send_end_effector(target_position=np.array([0.4, 0.8, 0.15]))
>         #     if np.linalg.norm(np.array([0.4, 0.8, 0.15]) - self.eff_p) < 0.01 :
>         #         self.robot.suction_gripper.open()
>         #         self.robot.arm.send_end_effector(target_position=np.array([0.0, 0.8, 0.1]))
>         #         return None
>         return self
> def main():
>     world = CortexWorld()
>     add_reference_to_stage(usd_path="/home/user/warehouse_defect_detection_pipeline/usd/Test.usd", prim_path="/World/Robot1")
>     add_reference_to_stage(usd_path="/home/user/warehouse_defect_detection_pipeline/usd/Test.usd", prim_path="/World/Robot2")
>     robot1 = world.add_robot(CortexUr10(name="Ur10_1", prim_path="/World/Robot1/UR10/ur10"))
>     robot2 = world.add_robot(CortexUr10(name="Ur10_2", prim_path="/World/Robot2/UR10/ur10", position=np.array([1.0,1.5,0.0]), orientation=np.array([0.0, 0.0, 0.0, -1.0])))
>     robot1.pick_cube = world.scene.add(
>          DynamicCuboid(
>              name="pick_cube", prim_path="/World/PickCube",position=np.array([0.0, 0.8, 0.1 / 2]), scale=np.array([0.1, 0.1, 0.1]), color=np.array([0.7,0.0,0.7])
>     robot2.pick_cube1 = world.scene.add(
>          DynamicCuboid(
>              name="pick_cube1", prim_path="/World/PickCube_1",position=np.array([1.0, 0.8, 0.1 / 2]), scale=np.array([0.1, 0.1, 0.1]), color=np.array([0.7,0.0,0.0])
>     world.scene.add_default_ground_plane()
>     world.add_decider_network(DfNetwork(DfStateMachineDecider(PickState()), context=DfBasicContext(robot1)))
>     world.add_decider_network(DfNetwork(DfStateMachineDecider(PickState1()), context=DfBasicContext(robot2)))
>     world.run(simulation_app)
>     simulation_app.close()
> if __name__ == "__main__":
>     main()
VIDEO:
Hi @samarth.shukla! Have your checked out the curobo example? I think this is pretty similar to what you are trying to do.
But please switch to Isaac Sim 4.0+. The latest stable version is Isaac Sim 4.5
@zhengwang thank you for replying but what i want framework through which i can create a warehouse application with multiple robot and multiple conveyor belt. What i am confused of is using cortex a right idea for my application or should i move with curobo. ?
@samarth.shukla Let me reach out to the internal about about usnig cortex.
@samarth.shukla unfortunately currently this is not doable in Isaac Sim. I just submitted a feature request to the internal team and hopefully this is will be available in the future.
