How about the same os system?
For example, I have two desktops which are all installed Ubuntu 18.04 system.
Can the engine which is generated from desktop A use on desktop B?
Hi @Chieh, you can share TensorRT engine as long as the GPU, OS version, and TensorRT version are the same. By association, CUDA and cuDNN versions should be the same too.
