I use two Tesla K20c GPUs.
Until now I created a buffer objects for each GPU to use pinned memory. Like this:
// create host buffers in order to avoid data transfers
cl::Buffer _in_matrix_hst_buffer = cl::Buffer( _context,
CL_MEM_READ_ONLY | CL_MEM_ALLOC_HOST_PTR | CL_MEM_COPY_HOST_PTR,
_M * _N * sizeof(cl_float),
in_matrix.get(),
&err
); check_error(err);
But now I would like to create one pinned memory that both Tesla K20c can access. This way only one buffer exists in host memory. Since I found out, that pinned memory is allocated using the mmap function with the flag MAP_FIXED, I tried to create my own pinned memory compatible buffer like this:
size_t siz = (1024 * 512 * sizeof(float));
int fd= shm_open(“region”, O_CREAT | O_RDWR, S_IRUSR | S_IWUSR);
ftruncate(fd, siz);
void* pre = mmap(A, siz, PROT_READ | PROT_WRITE, MAP_SHARED|MAP_ANONYMOUS, fd, 0);
float* Asm = (float*) mmap(pre, siz, PROT_READ | PROT_WRITE, MAP_SHARED|MAP_FIXED|MAP_ANONYMOUS, fd, 0);
After that Asm gets filled with data and a buffer is created like this:
CL_MEM_READ_ONLY | CL_MEM_USE_HOST_PTR | CL_MEM_COPY_HOST_PTR,
in_matrix.get(),
&err
I receive correct results with this method but it does not use pinned memory.
Therefore I would like to know if it is possible to use one pinned memory region for two GPUs.
Thanks in advance!
Best regards,
Fabian
