Can two Jetson T5000s be directly connected via XFI? MAC to MAC,MGBE Controller Direct Connection
Thanks !
Thanks !
No, this is not supported.
So, two Jetson T5000s can be connected only via switch or PHYs, right?
The other question, there are four MGBE controller for T5000 , and one MGBE controller connect to switch, the other MGBE controller connect to PHYs, it’s ok?
thanks a lot!
Currently we don’t support XFI on T5000 in software.
hi Wayne
我们当前方案是thor 通过MGBE0 连接到switch, 想请问再通过其它MGBE controller (1~3)可以连接到以太网phy吗? 同时工作。谢谢!
This use case is not able to work because XFI is not supported.
However, our solution has already enabled the interconnection between two T5000s via XFI(MGBE0) to connect to a switch, and the actual operation is okay.
4个MGBE controller 是独立的吗? 其中MGBE0 连接switch, MGBE1~3 选择一个controller 连接以太网phy芯片吗?类似ORIN,连接10G 以太网phy芯片。
和devikit 用法不同,不是4路MGBE直接连接到光口。
