Can TX2 module run with TX1 carrier board 180-82597-DAAF-B02
I have TX1 carrier board 180-82597-DAAF-B02 and I just received one TX2 module, can it run with that carrier board?
Hi ruih,
Jetson TX1 and Jetson TX2i modules are pin and software compatible, that means you TX2 module can on that carrier board, if any issue found, please update here to let us help you.
Hi Kayccc,
Thanks for your reply.
I will try and let you know if there is any issue with that.
Best regards,
ruih
