Can we change the same SSD for Orin NX 16GB and Orin Nano 8GB?
Hello Nvidia team,
Just curious about if I flash image into a SSD with Orin Nano 8GB SOM, can I change the SOM from Orin Nano 8GB to Orin NX 16GB? Does it work?
I’m currently having a Orin Nano 8GB and a Orin NX 8GB SOM。I flashed the image on a SSD with Orin Nano 8GB. And it can boot up well. Then I changed the SOM to Orin NX 8GB. Looks like the SSD can boot up well, too.
Also I can see the /proc/device-tree/model showes the corresponding model name with two SOMs.
However, I’m not sure if it works with Orin NX 16GB.
Can we do the same thing on Orin NX 16GB? Or do we need to prepare the image for Orin NX 16GB?
I’m working on Jetpack 6.2 with nano devkit.
Hi @ruei_chang,
Reusing the same SSD with Orin NX 16GB may also work. Orin NX 16GB is supported on the Orin Nano devkit carrier with JetPack 6.2.
Compatibility depends on the NX 16GB module having suitable QSPI boot firmware and loading the correct device tree for that module. Your successful NX 8GB test is encouraging, but the NX 16GB combination still needs validation.
Reference: JetPack 6.2 / L4T R36.4.3 module and device-tree configuration.
Hi Wichiu,
Thank you so much. Will confirm this concern once we get the Orin NX 16GB.
