I wanted to test few packages in jetson xavier nx with jetpack 5.0.2.
for this i do not wish to mess with jetson board so i decided to use an emulator like QEMU to emulate jetson arm in x86_64 host machine.
is this possible to do.
if possible is there any guides for this
We don’t support this. For testing software packages, you may consider get a Jetson Nano developer kit and give it a try. And if it can meet the requirement, you can then switch to Xavier NX.
The functionality should be same on Jetson Nano, although performance is worse.
