Hi Sir/Madam,
I know there are two antennas on TX2 module. One is for BT.
Can WiFi module use both antennas and support MIMO?
Can I determine which antenna WiFi uses?
Thank you
Hi Sir/Madam,
Thank you
It supports MIMO with two antennas. Don’t suggest to change the control logic to set antenna usage by yourself.
