This would be handy, I find myself to do lot of clicks before I actually start working. Also I’m asked to login from time to time, normal, but earlier today I had to wait some extra minutes to be able to login as the page couldn’t be loaded correctly, so this adds some extra time.
Yes, in Launcher click on the hamburger next to the Create version you’re using. Select Settings. Then select the folder icon in the list of Create versions you’d like to use. Then run omni.create.bat
Super thanks, this seems indeed to work, we only need to keep the command line window open, this would be a feature request to make it possible to make a shortcut for quick launch like other apps.
