Can you tell me where is wrong?
I write a cuda code, but there is something wrong: error: expected a member name
typedef struct
	//temp matrix, only read
	float *spec;  // save one particle image
	float *speq;
} cuMem;
cuMem GM;
int main()
	cudaMalloc((void **)&GM.spec, sizeof(float)*nsam*nsam);
	cudaMalloc((void **)&GM.speq, sizeof(float)*nsam*2);
	cudaFree(GM.spec);
	cudaFree(GM.speq);
Thank you very much.
What compiler are you using? To my eyes, that looks OK.
I have found the reason.
I defined a macro ahead: define speq SMTH
so, the speq was replaced by SMTH, when it is invoked.
Thank you for your reply.
