Cannot boot after upgrade jetpack to r35.0.1
ubuntu 20.04, The original jetpack version is r34, after updating to r35.0.1, there is no video output from the dp port, and the output from the serial port is as follows:
serial.log (63.9 KB)
Is there any way to fix this without re-flash the system?
Why are you still considering such an old BSP version?
Back up the data and re-flash it with 35.5/36.3.
What may cause this problem? Is backing up data on jetson the same as backing up ubuntu? Is there a guide for this?
Maybe it’s a known bug that has been fixed in new versions.
Using a custom carrier board is also likely a cause.
You just manually copy data you need.
