I cannot boot my TK1. When powers on, the fan works and the power light is on, but the HDMI has no output. Also, no power on the USB port and the LED light in the network port doesn’t blink, so I assume the network port still has no power. In one word, expect the power light is on and the fan works, there are no any differences when power is on and off.
I try to reinstall the JetPack, but failed. The log is:
RCM communication completed
BCT sent successfully
sending file: tegra124-jetson_tk1-pm375-000-c00-00.dtb
- 59637/59637 bytes sent
tegra124-jetson_tk1-pm375-000-c00-00.dtb sent successfully
odm data: 0x6009c000
downloading bootloader – load address: 0x83d88000 entry point: 0x83d88000
download command failed NvError 0x120002
command failure/warning: bootloader download failed (bad data)
Failed flashing ardbeg.
It seems the board cannot access the Internet, and also the LED light in the network port doesn’t blink. I have tried to connect the board directly to router or bridge by my computer. But always fails.
I have tried to only install the tegra-os, which doesn’t need to connect the network in the installation. In this case, no errors in the installation, but still, I cannot boot the board. Only fan works and power light is on when I power on the board.
I am assuming maybe I have a hardware failure, but not sure. Have you met this before. How can I make sure that this is a hardware failure?
