On our custom board with AGX Xavier Industrial SOM, system fails to boot up to Desktop if power is removed for a while(about 90 seconds) and reconnected. This issue does not happen on the same custom board with AGX Xavier(non-industrial version).
The HDMI screen shows kernel panic message in the end. System will try to reboot; however, every reboot ends with the same kernel panic message. Please help advise.
Here is the part of log, it refers to some CBB errors.
[ 22.358051] **************************************
[ 22.360081] CPU:0, Error:CBB-NOC
[ 22.362087] Error Logger : 0
[ 22.364073] ErrLog0 : 0x80030000
[ 22.366047] Transaction Type : RD - Read, Incrementing
[ 22.368099] Error Code : SLV
[ 22.370097] Error Source : Target
[ 22.372070] Error Description : Target error detected by CBB slave
[ 22.374145] AXI2APB_0 bridge error: SFIFONE - Status FIFO Not Empty interrupt[ 22.374352] AXI2APB_0 bridge error: SFIFOF - Status FIFO Full interrupt
[ 22.376479] AXI2APB_0 bridge error: TIM - Timer(Timeout) interrupt[ 22.376639] Packet header Lock : 0
[ 22.378752] Packet header Len1 : 3
[ 22.380874] NOC protocol version : version >= 2.7
[ 22.383052] ErrLog1 : 0x320022
[ 22.385164] ErrLog2 : 0x0
[ 22.387250] RouteId : 0x320022
[ 22.389357] InitFlow : ccroc_p2ps/I/ccroc_p2ps
[ 22.391506] Targflow : axis_satellite_grout/T/axis_satellite_grout
[ 22.393607] TargSubRange : 0
[ 22.395655] SeqId : 0
[ 22.397657] ErrLog3 : 0x1404000c
[ 22.399598] ErrLog4 : 0x0
[ 22.401541] Address : 0x1404000c -- /cv-noc@14040000 + 0xc
[ 22.403572] ErrLog5 : 0x889f851
[ 22.405597] Non-Modify : 0x1
[ 22.407615] AXI ID : 0x11
[ 22.409564] Master ID : CCPLEX
[ 22.411556] Security Group(GRPSEC): 0x7e
[ 22.413578] Cache : 0x1 -- Device
[ 22.415602] Protection : 0x2 -- Unprivileged, Non-Secure, Data Access
[ 22.417735] FALCONSEC : 0x0
[ 22.419716] Virtual Queuing Channel(VQC): 0x0
[ 22.422046] **************************************
I attach the full log as below.
cbb_error_isr.log (61.8 KB)
