The command works fine:
nvaoi@nvaoi-jetson:~$ sudo docker run -it --rm --net=host --runtime nvidia nvcr.io/nvidia/l4t-base:r32.7.1
root@nvaoi-jetson:/#
However, the command below to bring up container using my docker image failed:
nvaoi@nvaoi-jetson:~$ sudo docker run -it --rm --net=host --runtime nvidia ads/tri:latest
docker: Error response from daemon: failed to create shim: OCI runtime create failed: container_linux.go:380: starting container process caused: process_linux.go:545: container init caused: Running hook #0:: error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: mount error: file creation failed: /var/lib/docker/overlay2/f5dcd945a10fe51402595835b9085ffb8f74c7d3ecb1a740752eecbd1eea8249/merged/usr/lib/aarch64-linux-gnu/tegra/libnvidia-fatbinaryloader.so.440.18: file exists: unknown.
From NVIDIA L4T PyTorch | NVIDIA NGC, the newest JetPack version is l4t-pytorch:r32.6.1-pth1.9-py3. Is there JetPack version for r32.7.1? If not, how to downgrade the nvidia package version to work with, say, r32.4.3?
